Question about Kitchen Appliances - Others
I have black stuff coming out around the paddle. Can I get a replacement part or something to fix this? Thanks.
2 Suggested Answers
  • 110 Answers
SOURCE: How do i fix my nook hd if the black stuff around it is coming off
Super glue
Posted on Apr 08, 2015
I have this machine for 4 years now and I was happy with The central shaft does not turn now and I lost all my stuff... It makes the noise like if it works, but nothing happen... and there is a...
Hi.. The "central shaft" could mean the motor shaft is not turning or the "central shaft" could be the paddle shaft in the bread pan is not turning. If it's the motor shaft then tighten or replace belt. Since you "lost all your stuff" it could be the sealed bearing in the bottom of the bread pan has broken. The paddle doesn't turn and is leaking. If this is the case the bread pan needs replacement. Hank
Jan 18, 2011 | Black & Decker B1561 Bread Maker
Black stuff is coming up from the center mixing part and getting into my bread. Is it grease? How can I get rid of it? Thanks for any advice. Leanne
Hi, Yes it is a form of grease. The sealed bearing that the paddle shaft fits through has failed and is leaking out the lubrication. You will need a new bread pan. (Sorry it took so long for you to get a reply). Hank
Nov 08, 2010 | Cuisinart CBK-200 Bread Maker
I need to replace bread maker paddle
Your model number for the all in one pro should be a B1650 (single paddle model)
If that is correct then this is one source for the paddle:
http://www.abtecparts.com/commerce/search/products/?product_id=01XBD42959200&merchant_id=1933
An informationl note about Black and Decker products is that there are replacement parts for anything they make as long as they have no discontinued the model number. Once the model number is discontinued they have aftermarket replacement parts for 5 years only.
(your replacement paddle is starting to show up as no longer available)
The orignal paddle part number is: 429592-00
Here is a 2nd source for the paddle:
(96 in stock)
http://www.radioequip.com/servlet/the-Home-Appliances-cln-Black-and-Decker-cln-Bread-Makers/Categories
Thanks for using FixYa:
Kelly
Apr 23, 2010 | Black & Decker B1561 Bread Maker
Hi, I love my Black&Decker bread maker, but recently it has black swirl stuff on the bottom of the bread. I found it was from the center mixer. The mixer is getting loose and it can be moved up and...
Hi Jenny,
The black swirl stuff is the lubrication from the bearing that used to be sealed on the bottom center of the bread pan. (The paddle fits onto this bearing shaft). That bearing is broken and is leaking, causing the whole bearing and shaft to move. Time for a new bread pan.
Hank
Oct 27, 2009 | Kitchen Appliances - Others
Kneading blade will not cone out toastmaster 1171
I also had a breadmaker where the paddle didn't want to come out. (I acquired it that way.) After trying to take it apart, using a pliers (wrapped a cloth around the paddle), squirting WD-40, and a few other things, I finally had my male friend try getting it loose. He finally did, using the pliers with a cloth around the paddle. After that incident, I oil all of my paddles (cooking oil or butter). I buy and sell bread makers so I've had dozens but only one with that problem. Usually, soaking does the trick. Hope this helps.
Nov 22, 2008 | Toastmaster 1148X FastBake Bread Maker
Blades stuck inside bread
Unfortunately trying to stick the paddles in the pan just tends to leave half the loaf in the bottom with them. The best method i have found is to cut the crust around the outside of the paddles, carefully avoiding the bit where the actual paddle blade is, then you insert a rod into the centre of the paddle and tilt it towards the blade. They normally come free pretty easily. Another method you can use if you are around the machine when it is making bread, is to remove the paddles at the end of the mixing/kneading cycle, just before the baking cycle starts. Most machines have a small pause allowing you to do this - sometimes with a "beep" or screen message to tell you that you can do this. Sorry i couldn't find the exact info for your model, it will vary for different baking programs also. If you check the cycle to determine at which stage it starts actually baking, then you can do this quite safely so long as you are careful of the machine heating up while you are removing the paddles - usually you would have around 20 minutes at least to remove the paddles before baking. Hope this helps :)
Apr 11, 2007 | Black & Decker B2000 Bread Maker
Kitchen Appliances - Others Logo
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
