Question about Coleman Propane Grill Stove 9921-700
Need pressure regulator for portable grill that swilves with bottle of propane
  • Coleman Master
  • 2,557 Answers
Try national energy or propane company , home hardware,
Posted on May 16, 2010
When I turn on the grill the gas flame does not go beyond about 1/3 of the way along the connector tube to the rear burner.
It could be a partially blocked gas jet or insufficient gas pressure is reaching the jet.
Clearly the pipes and valve should be checked if cleaning the jet doesn't provide a cure.
It is a good idea to compare the jet size and air bleed size with specifications. If it is set up for propane and being used with butane it will display the inefficiency you described.
There have been a few appliances designed for use with bottled gas that weren't intended to be used with a pressure regulator and lots of propane appliances that need a higher pressure than the standard fixed regulator can supply and an adjustable regulator should be used instead.
Sep 04, 2015 | Weber Genesis Silver B Grill
Where can i find a LP gas pressure regulator OR can any one advice where can i buy one /which brand /model no etc.
If you have a standard LP portable grill, they all use a silver colored single stage propane regulator. You can buy a combo regulator/hose at most local propane retailers (look it up in your local yellow pages) like Amerigas, Ferrellgas or some major retailers carry them, like Wal-Mart, Target, K-Mart, etc.
May 06, 2015 | Grilling
On a kenmore 5 burner grill when lighting the fourth burner all of the grill shuts down, regardless of which is the fourth burner?
Sounds like the pressure regulator is malfunctioning. Try disconnecting your gas line. Open/Close all burners then reconnecting gas. If propane, don't turn bottle off before burners. Always turn burners off first, then bottle. then bottle on before burners. This primes the regulator to the proper pressure.
Jan 09, 2012 | Kenmore Grilling
Why is propane shooting out of the small whole on the regulator when I put a new tank on. Do I need a new regulator?
shut the valve on the bottle and re-assemble whole system, this usually happend when regulator is not screwed in properly.
another reason can be that it is too hot weather and bottle was in full sun, this increase greatly internal pressure and regulator was just venting it.
if none of the above worked or is true, then yes, replace regulator. UNDER NO CIRCUMSTANCES DIS-ASSEMBLE THE REGULATOR!!!
Jul 16, 2010 | Weber Q Grill
One burner barely lights; others don't light at all.
This is a common problem with grills purchased after 2001 or with a full propane tank with a lot of pressure in it. There is a new safety feature inside the regulator called a 'surge protector'. If you open your propane bottle valve too quickly or if you try attaching a tank with the tank valve in the 'open' position, the propane wants to 'surge' into the grill.
When the propane surges into the regulator (located on the grill hose) the 'surge protector' (inside the regulator) kicks on. When this happens you will not be able to get your grill lit, and if you do, it will be a small blue flame and the grill will not heat up.
So what to do if you trip the surge protector and can't get your grill to light or heat up?
Shut the tank off and shut the valves on the grill off. Disconnect the tank from the grill hose. When you disconnect the tank from the hose you will hear the excess pressure of propane release. This is an indication that you have re-set the regulator's surge protector.
Now that you have deactivated or reset the surge protector, reconnect the tank. Make sure the valve on the tank and the valves on the grill are in the closed and in the off position. After you reconnect the tank to the hose, SLOWLY open the tank valve (making sure the valves on the grill are in the OFF position).
Since you have slowly opened the valve on the tank, the propane did not surge into the regulator and the surge protector did not activate.
Now open 1 valve on the grill and light it. You should get a nice flame. If your grill has more than one valve, open each following valve in sequential order to extend the flames to the other burners.
Thanks for reading and I hope this helps.
Ben Gaetani
Tanks 2 You Propane
propanetanks2you.com
Tanks2youpropane@gmail.com
Feb 23, 2010 | Weber Genesis Silver B Grill
My grill would not preheat to proper temperature for several uses.Then it would not light,there was no gas smell from the burners.
Sounds like your propane bottle is empty...or maybe you have a bad regulator. Disconnect your propane bottle and pick it up; if it is very light, you need to get the bottle filled (or exchange it for a full one, depending on the type of bottle you have). If the bottle has plenty of gas, change out your regulator.
Dec 03, 2009 | Grilling
Very little gas getting to burners Full bottle of propane Acts the same way as when the propane bottle is getting empty This grill is only about 6 months old
You either have clogged burners and they need to be cleaned. Clogged inlet line to the burners. (This can come from trash, spiderwebs etc in the connection, kinked line etc.) or the regulator is malfunctioning.
Aug 24, 2009 | Weber Genesis E-310 Gas Grill
No propane flow to grill using bulk bottle system.
the office that is open on the bottom of the burner sound like a spider has taken home to.. the hole.... This happened to mine. a small pipe cleaner or wire will break it up...try that. also did you feel the top of the tank regulator and see if it has froze. try turning the tank upside down and turn the unit on.... this may also help by forcing the spider debris out.
Jun 05, 2009 | Coleman Roadtrip Grill LXE 9949-750
Propane Regulator Adjustment
Remove the plastic cover on the center of the regulator. To increase pressure setting, turn the plastic disk beneath with a screw driver. 1 turn clockwise increases the pressure 1/2" water column.
Nov 19, 2007 | Grilling
Coleman Propane Grill Stove 9921-700 Logo
290 people viewed this question
Top Coleman Grilling Experts
Dan Webster
Dan Webster
Paul Carew
Raymond Ramirez
Raymond Ramirez
Are you a Coleman Grilling Expert? Answer questions, earn points and help others
