Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
I have whirepool model lsr6232jqo. it stop at certain point and do not continue the washing cycle
  • 51 Answers
SOURCE: WMA 54 Hotpoint Aquarius washing machine lights flashing
the problem here is the machine is not emptying when its supposed to, you will find it is stopping at the rinse cycles. there is a sump underneath the machine that needs to be emptied. From my experiences, 9 out of 10 hotpoints that i would of repaired with the same problem as you are having is usualy caused by using the color catcher sheets, they are a disaster.
appliancesdav@hotmail.com
pallesappliancerepairs.com
Posted on Feb 03, 2010
  • 1073 Answers
SOURCE: Washer continuously fills but drains at the same time during rinse cycle.
you have the drain pipe too low into tthe house drain pipe, raise the washers drain pipe up , you only need four inches down into the hous drain
also the house drain pipe needs to be as high as the lid of the machine before you put the washer drain tube into the house drain
you have a syphoning effect
Posted on Apr 20, 2008
onthejob5130
  • 640 Answers
SOURCE: Frigidaire stackable front load washing machine
ok we have to take bottom front panel off,,theres three torex head screws..now straght in front of you is the pump ,,remove the filter turn it counterclockwise,,theres always a little water in it so be prepared...remove clogg and we should be good all coins are mine,,onthejob
Posted on Feb 07, 2009
FAV6800AWDIY
  • 526 Answers
SOURCE: The machine will start a cycle normally, but after
Thank you for verifying the model type so many folks post non FAV6800A/FAV9800A questions in this forum machine specific topic area.
FAV6800A/FAV9800A Service Manual for reference. Sears Parts Direct for reference.
You will need the Service Manual for support. I’m an owner like you with a solid repair skills on the machine and will try to help you DIY the repair if we can ID the issue through troubleshooting.
Do you have this condition in all wash cycles? Will a Quick Wash cycle complete? Do you see the Cycle Status LED ever indicate the machine has moved to the Spin Cycle during the wash cycle? This could be a Control Board failure but we need to troubleshoot.
I want to make sure the Wash basket will spin up with a Spin Only cycle selection. Can you select a Spin Only cycle with a empty wash basket. I would release the washer top so you can observe this test. I want to rule out a broken Clutch large wrap spring.
Page 33 of the Service Manual will show you how to release the washer top from the base. In Spin Only cycle raise the top just enough to make sure the wash basket is rotating Counter Clock Wise – CCW with the Spin Only cycle selected and operated.
If the above test doesn’t indicate an issue I would like you to try the Quick Service Cycle test on page 15 of the Service Manual and see if your FAV6800A will pass that test with no clothes in the washer. When you put the machine in Service Mode press and hold simultaneously the Enviro Plus and Spin Only keys until the machine beeps and the LED display reads 00. Then press Wash/Rinse Temp to start Quick Service Cycle test. Did the test complete with a PA indication in the display? It will only display the PA code for a few seconds. End of cycle will beep washer will unlock and Cycle Status LED will indicate complete.
Waiting for your reply….Rich
Posted on Dec 24, 2009
cpldw48
  • 202 Answers
SOURCE: My washer has been through the wash cycle but
try turn the timer to spin an see if will drain an spin but you may need a timer also
Posted on Apr 25, 2010
Hoover six 1100 stops at certain points during the cycle until i turn the dial to skip to next part of cycle?
see this causes and fix it. God bless you
If the washer stops mid cycle the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
f the washer stops mid-cycle the main control board might be defective. This is not common. Check other causes first such as the lid or door switch and other components.
If the washer stops mid cycle the water inlet valve cold water side may have failed. Most washers have a cold water rinse and so if they can't fill with cold water they just sit indefinitely waiting for the cold water to enter. If there is cold water to the water inlet valve and the cold water works in other parts of the cycle - or to make warm water - the valve is not the problem.
If the washer stops mid cycle the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
If the washer stops mid cycle the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Sep 25, 2012 | Washing Machines
My washer stops at a certain minute and won't proceed (i.e., it stops at 11 minutes for the low extract spin only cycle). Very frustrated! It worked fine for the service guy yesterday!
it may be in its pause cycle the washer pauses for about 2 minutes during certain cylce allow the cycle to continue some cycles go between agitation and soak
Jul 17, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Display goes blank at certain points during wash cycle
replace the timer.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 07, 2009 | Washing Machines
Zanussi ZWF16581W Washing Machine
I believe there is a setting where you can turn the beeping alarm off completely. Read the manual and you should find it.
Mar 04, 2008 | Washing Machines
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
70 people viewed this question
Dan Webster
Dan Webster
Sal De
