Question about Maytag Neptune FAV6800AW Top Load Washer
My Maytag fav9800aa keeps giving me the error code "flash memory error, disconnect from power source for thirty seconds. If problem continues call a 1800 #. Does anyone have any idea what might cause this except calling Maytag for $600.00. Thanks
  • 335 Answers
Yes the LCD flavor of the machine is a bit more expensive to replace.
Have you checked Ebay?
Here is a used one Maytag washer LCD control 25001218 (used)
New MAYTAG CONTROL BOARD 25001218
FAV6800A/FAV9800A Service Manual for reference. Sears Parts Direct for reference.
Rich
Posted on May 15, 2010
I have a maytag 5000 series washer. We are getting an f21 error code. I unscrewed the white drain filter and cleared it. There was little in it. I keep getting the f21 error though. Can you help?
Search Results
    whirpool f21 error code - YouTube
    ? 3:04
    https://www.youtube.com/watch?v=b24PVv-ORqg
    Jul 1, 2012 - Uploaded by davidmontabon
    whirpool f21 error code. ... Maytag , Whirlpool Washer Repair - Drain pump error, no drain - F9E1- MHWE201YW00 - Duration: 4:29.
    My maytag 5000 series steam washer stopped and said Sud ...
    www.fixya.com/support/t8682656-maytag_5000_series_steam
    Mar 17, 2011 - my maytag 5000 series steam washer stopped and said Sud and now says ... Clicking this will make more experts see the question and we will .... I bought aMaytag 3000 seris in 2008 and I am getting these messages: F21 ... Maytag 5000 Series washer F21 error code was flashing and door will not open.
    Whirlpool/Kenmore/Maytag & more-F02/F21 & Sd error codes
    fixedappliance.blogspot.com/.../whirlpoolkenmoremaytag-more-f02f21-...
Feb 09, 2016 | Maytag Washing Machines
How do I clear the fault codes ?
How To Fix Maytag Washer Error Code F9 E1 ...
www.appliancerepairlesson.com/2013/.../maytag-washer-error-code-f9-e...
Dec 10, 2013 - The error code F9 E1 will be displayed on most newer Maytag washers and ..... My whirlpool duet wfw94heaw0 gives the error code F09 E01.
KitchenAid f09 error code Dishwashers Questions ... - Fixya
Nov 29, 2015 | Dishwashers
What does Error code F06 mean
Try this:
Possible Causes / Procedure1. Verify the shipping system including shipping bolts, spacers
and cables are removed.
2. Unplug washer or disconnect power.
3. Check wire harness connections between the drive motor and
the Motor Control Unit (MCU), and between the MCU and the
Central Control Unit (CCU).
4. Plug in washer or reconnect power.
5. Check the MCU by looking for operations of the drive motor.
6. Check the drive motor for powered rotations.
Read more: http://forum.appliancepartspros.com/washer-repair/11384-front-load-maytag-what-error-code-f06.html#ixzz33vFGkt1n
Apr 23, 2014 | Maytag Dryers
Maytag washer giving error code A0
Maytag Neptune Priority One Service
(888) 462-9824 call to the company to due the error code.
God bless you
Aug 01, 2012 | Maytag Neptune MAH5500B Front Load Washer
My Maytag washer will not complete a cycle. The code Lr is display on the front of the washer. I have pulled the plug and reset the breaker.
Hi.
LR stands for locked rotor. The code is returned by the Motor Control Unit (an electronic module connected to the motor and to central control unit). The code is returned when no motion from motor rotor is detected. With many models LR may be due to a factory defect. Please call Maytag and check if any recall has been issued for error LR concerning your washer model. If recall has been issued you will get a kit comprising a new motor and wiring harness.
You can also try temporarily resetting the error by disconnecting power at circuit breaker (or unplugging power cord). If the error message is prompted again call Maytag.
Regards.
Ginko
Aug 08, 2011 | Maytag Washing Machines
My Maytag Neptune Dryer stopped running & is
as per heatman The most common cause of your appliance giving you the PF error code is a problem with the power coming in from your utility company. Of course if there is an interruption of power, and then the power comes back on you will get the PF code Loose wires going to the circuit board or the control can also be a cause of the error code. If a wire terminal end happens to get corroded or loose, the vibration from the machine can cause slight power problems and this can cause the PF code to be displayed. Finding the cause of this type of problem is like finding a needle in a haystack. Sometimes you can cause it to be displayed by banging on the side of the appliance or slightly moving the wiring harness, to see if you can get the error code to display.
The bottom line about this power failure error code, is that it is power related. Finding the exact cause can be difficult. If you are continually having to reset the appliance then check to see if all of your appliances are giving the same code. This will indicate utility power problems. If only one appliance is giving the PF code then it is probably internal to the appliance.
Jul 12, 2011 | Maytag Neptune MDE5500AY Electric Dryer
My maytag neptune Model #: MAH5500BWW is flashing
The error code you describe is not listed in Maytag's book of codes. The link below will take you to Maytag's website error code page where you might be able to match it up.
http://maytag.custhelp.com/app/answers/detail/a_id/2885/session/L3NpZC8yY3lEMjNEag==/sno/0
Jul 15, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Electric range F1-1 persistant fault code
F1-E1 - EEPROM Checksum Error - Disconnect power for at least 30 seconds and then reconnect.
Allow at least a minute after power has been restored and if error code reappears, replace control board (clock).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
#$%^Y
Jun 25, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Maytag Neptune FAV6800AW Top Load Washer Logo
185 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
