Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Wash goes silent at the rinse and spin cycle
Washer stops at the rinse and spin cycle, no sound or hum at all.  Turn wash over and found a gray rubber gasket in side of clutch area.
  • 2 more comments
  • wally1980 Mar 30, 2008
    washer goes silent at the rinse and spin cycle.
    only if wash water level is low bot nothing else.
  • anglerdad Mar 31, 2008
    Washer stopped dead at the rinse cycle and won't drain or spin. Rotating the timer switch through the cycles sometimes creates a hum inside the washer but not always.
  • robert samples May 11, 2010
    does it fill for rinse dont worry about the rubber peice no biggie
    President:
  • 1,314 Answers
If the wash water isn't draining you have a bad lid switch back out the two screws at the bottom of the control panel in the back pull the control panel forward tilt it back on its hinges on the body of the washer you will see a connector with three wires grey green purple make sure the knob is in disconnect the connector and put a jumper wire from gray to purple where it goes to the control panel pull out the knob and see what happens
Posted on Mar 30, 2008
My 5 year old Roper washing machine fills up, washes/agitates the cloths, drains them when the washer get to the rinse line to start the rinse cycle it stops, and all I hear is a humming. The machine will...
I'm not familiar with roper washing machines so I'll ask the question does it have two fill hoses. Most European machines now only have one fill. If it has two then it sound like the machine takes the initial water from the one fill and the rinse cycle water from another. The humming sounds like the valve for the other fill needs replacing. These are quite inexpensive and easy to fit. Power off.. remove lid ....switch of water...take out valve when you establish which one is affected and replace
Oct 17, 2013 | Whirlpool WTW5700S
SM 8525492A whirlpool washer rinse cycle no water comes out, just hums
when the washer goes into rinse cycle it only uses cold water so clothes don't rinkle,so most likey you have a problem with your cold water,do this,shut down the water to the washer,remove the water lines from the back of washer and mark them so you know how they came off,stick the hoses into the washer if they reach or a bucket,turn on the cold water to see if water is coming out of hose,if water does come out of hose good then stick the cold water hose back on the washer and run it only on cold,if it doesn't fill then you know you have a problem with the water valve on the washer and it's not the house water valve that's bad,and usually if you have a problem with the washer water valve it will just hum and no water will enter the washer so if you hear a humming sound it will be the water valve.tried looking up the model number you sent but it doesn't come up on the parts lookup
Apr 25, 2013 | Washing Machines
Whrilpool modle #lsq9544kq0 washer works in
Humming could mean a stalled motor. These machines also have a coupling between motor and gearbox which can fail. However, the pump is attached to the motor, so if it's not pumping it probably means the motor isn't spinning. Check motor and/or gearbox.....Nomess
Apr 18, 2010 | Whirlpool LSQ9544K Top Load Washer
Kenmore 80's series top loader only works on wash and rinse cycle
This is a problem with the pump being stuck so the motor cant turn the whole thing. Turn the washer on its side, underneath you can acces the pump, which is connected to the motor by two long clips. remove the pump and take out the colg that caused it to get stuck.
Jul 01, 2009 | Washing Machines
Ge front load washer won't go into rinse cycle.
Check the cold water hose. My brand new machine had this behavior until I discovered a kink in the cold water hose - works great now.
Jun 03, 2009 | GE WSXH208A Front Load Washer
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
GE Top Load washing machine not draining
  • to me it sound as if waterpump is not working
Apr 09, 2008 | GE WDSR2080D Top Load Washer
Frigidaire Front Load Washer Problem
Plug off the wall, open up the back to check your belt, might have come off. Place around motor pulley & turn the drum wheel to slip on the belt gently from either the right or left. If too loose you have to replace with new belt.
Rate if helped pl..................
Jan 04, 2008 | Washing Machines
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
61 people viewed this question
Dan Webster
Dan Webster
Sal De
