Question about Toshiba Satellite Pro 6000 Notebook
Toshiba Satellite-Pro 6000 (PS600U-01RCV9)
Turn on power but no startup...green indicator lights flashing and battery light is steady green.
What can be the problem for not booting up
Do I switch hard drives?
User Manual has no remedies
  • 3 Answers
SOURCE: Toshiba Satellite P200 doesn't boot
Try pressing FN/F5 keys simultaneously, or the key that toggles internal/external Display. Look for the double screen Icons on the keys.
Tap the Pause Key.
Restart and press and hold F8 key when Toshiba logo appears. When the boot Menu appears, select Last Known Good Configuration.
If all else fails ther should be a reset button on the side of the LT. Consult owners Manual for location
Posted on Aug 16, 2008
  • 39 Answers
SOURCE: Toshiba Satellite Pro 6000 ps600e
You might want to go to the computer manufacturers web site and see if they have a list of error codes for you computer. If not, you might also try to do a Google search for error codes pertaining to your particular computer.
If you can't find a list of error codes, keep in mind that some computers can be very finicky about the type of RAM that is installed. If you haven't already, check to make sure that the RAM you are trying to install is 100% compatible with the computer that you have. If so, you might try installing the RAM one stick at a time and rebooting with each chip individually. This will help to determine whether one of the chips might be bad or not. If the RAM is 100% compatible - AND - it will not boot with a single stick installed, there is a distinct possibility that all of the RAM sticks could be bad.
Posted on Nov 09, 2008
  • 3 Answers
SOURCE: Toshiba Satellite P200 RT2 won't startup but is
Hook up an external monitor and see if windows loads up, if so it might be a backlight or inverter. if you dont see anything then it might be a hardware failure
Posted on Mar 20, 2009
tbirdfan1
  • 3051 Answers
SOURCE: power on but no screen oor hard disk motion
Hello there:
i would suggest using a spare monitor and connect the cord that would normally go into a computer and connect it to the laptop and then plug in the power cord for the monitor and turn on the computer if this works and everything is ok then you know that the laptop screen may be faulty or there may be a loose connection somewhere ok?
best regards michael
Posted on Sep 11, 2009
peepnklown
  • 175 Answers
SOURCE: unlock bios Toshiba Satellite Pro A60FR !
This WEBSITE should help you out:
http://www.tech-faq.com/reset-bios-password.shtml
Posted on Dec 08, 2009
Toshiba satellite A100 dead. orange steady battery light with mains connected and power button lights shift key and 2 function lights - that's it.
It will turn GREEN when the battery is fully-charged.
Is there a problem with the battery not accepting a charge?
Remove the battery, to see if the computer will start without it.
Do these 2 lights just "blink" once, and then go out?
Does a "power" button stay lit?
Have you hired a professional computer technician to trouble-shoot?
Sep 17, 2010 | Toshiba Satellite A100-S8111TD Notebook
My toshiba satellite pro 6100 will not turn on. The battery light and power light turns green but it will not turn on.
The problem could be your display. Use the VGA port on the side of your laptop to connect it to a computer monitor, this will let you know if your system is posting or not. (If you see the Boot Screen it is posting).
May 19, 2010 | Toshiba Satellite Pro 6100 Notebook
Dell 6000 power problem?
Troubleshooting a power problem is fairly simple:
1 Try a different AC adapter, see if there is any change 2 If system will not power on with a known good or new AC adapter, then the power connection on the motherboard is likely damaged and the motherboard will need to be replaced.
Mar 24, 2010 | Dell Inspiron 6000 Notebook
My toshiba A210 laptop will not power up all neons lighting wont power up with or without battery
It looks like you are saying that you can't power up the computer at all.
First, check the power adapter to see if it is putting out the voltage it is supposed to--about 18 volts.
If it is putting out the voltage and you hook it to the computer, your battery should charge and the computer should start. If it does not, then you have a bigger problem. It could indicate bad memory (but probably not, as there should be some flashing of the lights on startup) or a motherboard problem.
Feb 08, 2010 | Toshiba Satellite Pro A210-EZ2202X...
Toshiba satellite pro 6000 power
Sounds like a bad motherboard to me - assuming that it has memory installed.
Nov 29, 2009 | Toshiba Satellite Pro 6000 Notebook
When connecting up to charge red light comes on 'power on' button on front and no charging happens - any ideas? thanks
What does indicator light mean?
  • Steady red light: Battery is charging.
  • Steady green light: Battery is fully charged.
  • Flashing red light: Battery needs charging.
  • Flashing green light: The music receiver is switched on.
  • Flashing red/green light: The music receiver is available to be added to your phone.
Aug 24, 2009 | Sony Ericsson T303 Mobile Phone (Shadow...
When I plug in my ac adapter into my computer to charge it the green light turns off and won't charge my computer
The diagnostic procedures from the Dell User Guide are as follows:
Total Power Failure When Using a Battery
If an AC adapter is not connected to your computer, the computer's power source
is a battery. If the battery indicator flashes amber or is a steady amber, the
battery needs to be charged. If the battery is flashing green and amber, the
battery may be defective. To troubleshoot this problem, use the following
procedure.
1. Turn off the computer and peripherals, and disconnect them from AC power.
2. Reseat each installed battery by removing it and then replacing it.
3. Turn on the computer. Does the green power indicator light up?
Allow one minute for the computer to initialize its components before checking
for signs of power.
Yes. Continue to step 4.
No. Use the AC adapter to connect your computer to AC power. If the computer
operates normally when using AC power, go to step 7. If the computer does not
boot when using the AC adapter, see the previous subsection, "Total Power
Failure When Using the AC Adapter."
4. Does the battery indicator flash amber or show a a steady amber light?
Yes. The battery needs to be charged. Go step 5.
No. Go to step 7.
5. Connect the computer to AC power, and fully charge the battery.
For instructions, see the topic titled "Charging the Battery" in the online
System User's Guide.
6. As the battery charges, does the green battery indicator light up?
Yes. Go to step 9.
No. Go to step 7.
7. Is the battery indicator flashing green and amber?
Yes. Your computer may be in a hot environment. Charging the battery in this
condition may affect the life span of the battery. Continue to step 8.
No. The problem is resolved.
8. Disconnect the computer from AC power. Is the the battery indicator still
flashing amber?
Yes. You may have a defective battery. Continue to step 9.
9. Remove the battery, and press its test button. Is the uppermost indicator in
the charge gauge of the battery flashing?
Yes. You have a defective battery. Continue to step 9.
10. If a spare battery is available, fully charge it, and then install it in the
computer.
11. Turn on the computer. Is the power indicator off?
Yes. Your original battery is defective
good luck
Apr 05, 2009 | Dell Inspiron 6000 Notebook
Toshiba satellite pro 4200 wont start,just 1 flashing amber light
I had a similar problem on SatPro6100. Mine was LSSSLSSL (10010001).
Thinking that the laptop was buggered I decided I would take it apart and have a look at the insides.
Whilst it was apart I also disconnected the BIOS battery.
Couldn't find anything that looked like it had burnt out so put it all back together again.
When I turned it on again the darn thing was working fine!!!
Go figure!!
The whole thing was apart for about 2 hours or so.
I don't know if it was removing the main battery and leaving it out for that time or whether it was resetting the BIOS (by disconnecting its battery) that fixed the problem.
Anyway, I have managed to get all my data off the laptop so not too worried if it screws up again.
I do however always disconnect the power source BEFORE shutting down the laptop and only reconnect it after I have pressed the on button. Seems to be working fine (for now!)
Hope that helps someone out there!
Mar 11, 2009 | Toshiba 20GB 5400 RPM NOTEBOOK HARD DRIVE...
Looking for vga display drivers for toshiba satelitte sp 6000 with xp
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=135844&rpn=PS600U&modelFilter=6000&selCategory=3&selFamily=1073768667&selModel=135844|PS600U
Mar 10, 2009 | Toshiba Satellite Pro 6000 Notebook
Toshiba Satellite Pro 6000 Notebook Logo
193 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
