Question about Linksys Wireless-G WRT54G Router
I can't access the internet using the router and wireless adapter
The main computer can access the internet, however the other computers on the network can not. I have the Etherfast cable from the modem going into the WAN port on the router. And Ethernet cable from port-4 going to the computer. Is this correct? I tried other arrangments but nothing works.
My other computers are connected [local] only...no internet. Thanks for any help.
SOURCE: configure WRT300N wireless Router to connect internet using PPPoE
Often the nets and subnets are NOT the same.. ie The Fixed connection often uses 192.168.0.1, 192.168.1.1, however sometimes the wifi is setup 10.1.1.1, or 10.0.0.1 etc, have you checked this? Esentially tho ya router is an "Acess Point" and ya Lappy etc is ya "Client" the links below has a lot of tutorials to help have a look. http://portforward.com/routers.htm http://portforward.com/guides.htm
Posted on Aug 05, 2007
cyrylthewolf
  • 143 Answers
SOURCE: hookup with Vonage device
I am going to attempt to give you a solution here. But you must understand a few things before I begin.
First, I would like to clarify that if you have Time Warner internet service, you are on Cable Internet. Not DSL. (This makes a world of difference when it comes to using a router.)
Secondly, you did not specify model numbers of your devices. Therefore I am assuming that you are using the following devices:
If this is not the correct equipment, continue to follow the instructions but be dynamic and adapt my instructions to the equipment you have. It should be similar enough that you shouldn't have any problem easily doing this.
This instruction set is going to begin from a point that is assuming that we're installing all of this equipment from the standpoint of a completely new installation. From the ground up.
Let's begin.
UNPLUG AND POWER DOWN ALL OF YOUR EQUIPMENT INCLUDING THE CABLE MODEM, ROUTER, PC AND VONAGE BOX. Do not power on any of the devices until instructed to do so.
1.) Connect your cable modem to the cable from the wall.
2.) Find the ethernet port on your cable modem. Connect the blue ethernet (CAT5) cable to the ethernet port.
3.) Plug the other end of the blue ethernet cable into the "Internet" port of the router. (Older routers used to also call this a "WAN" port.) It is the only port that is seperated from the rest of them.
4.) Connect another ethernet cable to port 1 of the router.
5.) Connect the other end of the ethernet cable to the network port of your PC.
6.) Connect yet another ethernet cable to port 2 of the router.
7.) Connect the other end of this ethernet cable to the ethernet port of the Vonage box.
8.) Plug in the power adapter of the cable modem. Wait 1 minute for the cable modem to acquire it's signal and set up the connection to Time Warner.
9.) Plug in the power adapter of the Linksys router. It should only take 15-20 seconds to set itself up. (If you have made any configurations to the router prior to this, I recommend pressing and holding the RESET button for at least 10 seconds to give you a fresh configuration state to start with.)
10.) Plug in the power adapter to the Linksys PAP2 VOIP Phone Adapter.
11.) Power on your PC. You should have an internet connection with it.
You see... As I read the configuration you described, I don't think that you're using a PAP2 phone adapter. You said that you connected the "vonage device" to both your modem and your PC. This is not possible with the PAP2 adapter as it only has ONE ethernet port.
I am led to believe that you are actually using the Linksys WRTP54G which is essentially the same thing as the WRT54G, but with Vonage support built-in.
If that is the case, then you will not need to use the WRT54G router. Instead, follow the instructions that I gave you assuming that the router and the phone device are combined into one device. (The ports will still be labeled the same.)
Download the installation guide for the WRTP54G from the product page link I just gave you. You'll find the link to the User Guide on the right-side panel. This will make everything clearer for you if you do indeed have that router instead of the PAP2 phone adapter.
If you continue to be confused, please let me know. DO NOT just give me a poor rating without asking more questions. I am here to help you solve your issue. Not have my rating decreased just because someone is too confused or lazy to ask more questions.
I'm happy to help you. :)
Good luck and let me know what the outcome is. (And please be sure to list your exact model numbers in the future!)
Cyryl
Posted on Nov 11, 2007
bpcs
  • 112 Answers
SOURCE: Linksys Wireless WRT54G vs. WET54G
For what it is worth, I fhave found streaming video does not function well using a wireless connection. The options of multipale routers will work as long as you configure them as to not have conflicting IP address assignment's via DHCP, and the routers do not have matching IP address's. Never fear all is possible with paticence. BPCS
Posted on Jan 20, 2008
SOURCE: Connecting my westell 6100 modem to my router
linkseys Wireless G broadband router need to hook up to Verizon router/modem
Posted on Jun 22, 2008
  • 30 Answers
SOURCE: error 321 'ethernet not connected' on LINKSYS WRT54GS
Dont go with the error , i came across such instances on a few occasions while users were installing it from CD . (Sounds lamme?right)
Try doing the set up manually , by accessing the web Gui of router .
***FOLLOW THIS********
The GS comes set to 192.168.1.1 as its factory default and with its built-in DHCP server enabled. So all you'll need to do is plug in a client that's set to obtain its IP address information automatically, maybe do a DHCP release / renew (or reboot your client computer), and enter the default password into the login box that pops up. If all goes well, you'll get the main Setup screen.
The Internet Configuration Type selector automatically refreshes the browser screen to present settings appropriate to the choices of Automatic Configuration - DHCP, Static IP, PPPoE, PPTP and Heartbeat Signal (for Australian users) Internet connection types.
MAC address cloning gets its own page in the Setup section, as does setting up either dynamic DNS service from dynDNS.org or TZO, setting up static routes or disabling NAT features and converting the GS to a non-NAT router.
The interface is generally quick, with quick mini-reboots needed to get the changes you make on each page to take. Multiple admin logins are allowed, with no warning given when two or more admins log on. Once you're logged in, there's no idle timeout, and you just need to remember to quit your browser when you're done, because there's no logout button.
Enabling Remote Management for the first time still pops up a message telling you to change the router's default password and you can now enable secure (HTTPS) admin access. You can also change the default remote admin port from 8080, but can't restrict access by IP address or domain. Also of note is that you can't reboot the GS from the Admin interface.
Let me know if you require any more assistance.
Posted on Apr 19, 2009
Wi fi is on but still can't connect to the internet
Not only does Wi-Fi have to be on, but it has to be connected to a wireless access point (sometimes called a wireless router), and the wireless access point has to be properly connected to the internet.If the wireless access point/router has empty ports on it, plug your computer into one of those ports, and see if you can connect to ther internet then. If you can, the problem is somewhere between the wireless access point/router and the computer. Could be the transmitter part of the wireless router, could be the wireless network adapter on your computer, or could be the driver that runs the wireless adapter on the computer. If you cannot access the internet when you plug into the wireless ap/router, then you need to go one step "upstream." This would likely be the cable modem or DSL modem. Plug directly into that with your computer, and reboot both the modem and the computer (just unplug the power from the modem and then plug it back in to reboot the modem). If you can connect to the internet then, the problem is the wireless router/ap. If you cannot connect to the internet then, contact your ISP.
Feb 09, 2012 | Gateway 7330GZ Notebook
Can't Connect to the internet
is there any other computer online using the router.
If not then check the Internet through the router.
check the Ip address on the wireless computer .
make sure that it is not static .
Click Here for more information about routers and wireless network
Jan 08, 2010 | ASUS (WL-167G) 802.11g/b (wl167g) Wireless...
One computer not able to access internet
you got to make sure the wireless settings of the wireless adapter is the same with the router. usually this problem happens if the wireless encryption or password you used in the computer is not the same wireless password in the router.
May 29, 2008 | Linksys BEFW11S4 Wireless-B Broadband...
You are connected to access point but the internet cannot be found.
Do you have a connection wizard that you can run on your computer? Linksys offers them for downloading at their website. Try that -
have you named your home network so your wireless connection can "find" it? You don't mention how your main computer is networked in. A wireless adapter for a notebook will need to have a Linksys connection wizard run on the laptop.
If you have a Linksys router connected to your main computer, it should already have the piece of software you need. Most likely, you'll need to put it on a flash drive and install it from that onto your laptop. the wizard helps also to diagnose the right settings.
If you want to post what you are using for your main network (linksys router?) and which operating systems you are using, that will help.
For example, in Vista, you'll need to enable the option for "network discovery" under your laptop's control panel/network and sharing center.
You also need to have certain settings on your main computer for the wireless to work - there are two main types of wireless connections - B and G. Most of today's routers and cards will do both, but if you have an older router, it might not be set up to handle the newer or combined types. They run on different frequencies, so your laptop might not be "reading" your router's frequency.Also, if you have other wireless/radio frequency equipment near your laptop, it can interfere with the signal being received right.
You also need to be sure that your firewall allows the linksys system to access your computer (allowed programs).
Dec 10, 2007 | Linksys WPC54G Wireless-G Notebook Adapter...
Drivers 4 Linksys BEFW11S4 ver. 4
Your wired network adapter will talk to a wired router without a driver for the router on your computer. Your wireless adapter likewise will talk to your wireless router without a driver for the wireless router on your computer. Your wired and wireless adapters however do require drivers and the wireless adapter can require configuration. Please provide the manufacturer and model of your computer so I can learn about your wireless adapter and we can work to get it connected to the router.
Do you currently have your router connected to your internet service providers connection and do you have another wired or wireless computer successfully using this device to access the internet?
Dec 09, 2007 | Linksys BEFW11S4 Wireless-B Broadband...
Can't connect
First if your computer has an ethernet port attempt to connect through the router to the internet with a wire. If that works the next question is did you buy this device new or used? If used we can work to assure we know the configuration of the device. Second what is the manufacturer and model of your computer? Third, if the wireless adapter is not built into the computer what do you know about the make and model of the wireless adapter? Armed with the above information we should be able to resolve the issue.
Thanks
Dec 04, 2007 | NetGear WGR614 Wireless Router
Linksey wireless-g usb adapter and router
lose internet connection from my second computer that is linked to main computer (main computer has internet connection). Tried to click repair and it said couldn't be repaired contact internet provider?
Nov 01, 2007 | Linksys Wireless-G WAP54G 802.11g/b...
I cannot connect my laptop computor to my main computor
Bluetooth is not WiFi,   they are two seperate technologies.
you need a Wireless adapter 802.11b/g for your laptop,
you would connect the two to each other using an adhoc connection,
If you had a wireless router for your internet you could connect directly to the router, (and then you would not have to have your main computer on for you to access the internet.
BTW if your Main machine is near your phone point (for internet connection) you would not need a wireless card for your pc, as you could connect via LAN cable to the wireless router (make sure you get one with lan ports)
Oct 15, 2007 | NetGear - WG311 - 54Mbps 802.11g/b...
Linksys Wireless-G WRT54G Router Logo
53 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
