Kenmore 80 series washer wont drain - Washing Machines
  • oldguy5 May 14, 2010
    Can you provide the exact Make, Model and Kenmore model number? .......... Kenmore model numbers use the format ###.######## with the first three digits of 110 for Whirlpool manufactured machines......... The model number on top load washers is usually found by lifting the lid and looking above the tub. The Fixya numbers are Stock Numbers. Since basic top load direct drive, top load electronic and front load washers are very different, the actual Model Numbers are necessary to correctly diagnose the problem. WILL IT SPIN???? HAVE YOU TRIED A DIFFERENT CYCLE???? WILL IT AGITATE WELL???? CAN YOU HEAR / SMELL ANYTHING UNUSUAL????
  • Washing Mach... Master
  • 43,501 Answers
Here is a tip that I wrtoe about washing machineskenmore 80 series washer wont drain - 2_bing.gif that don't drain out right..
Washing Machine does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
heatman101
Posted on May 15, 2010
How do I check and replace the water level sensor on my Kenmore 80 Series Hvy Dty Washer?
Try eserviceinfo.com/index as per your 80 series. There are various downloads there that may help access the water level sensor which is most likely the problem.
Aug 08, 2014 | Kenmore Washing Machines
My kemnore 80 series washer machine wont spin or drain
Check in this order: belt, water pump, motor, drum shaft/bearing. Most of the parts will be either under the unit or inside. Most units require popping the top up in the front and removing the front panel.
Nov 11, 2012 | Kenmore Series 80 Creme Top Panel
Kenmore washer 80 series wont stop draining
Not sure if you have already done this, but is the drain hose higher than the washer?
Jul 08, 2012 | Kenmore Washing Machines
Kenmore Washer Series 80. The cycle stops before
check to see if you have it set on drip dry
Feb 06, 2010 | Kenmore Washing Machines
Kenmore 80 Series washer wont spin or drain at end of cycle
POST ME THE MODEL NUMBER. AND ALWAYS POST MODEL NUMBERS WHEN NEEDING ASSISTANCE PLEASE:)))
Apr 17, 2009 | Washing Machines
Kenmore Series 80 wont do anything.
Check the coupling/transmission.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 15, 2009 | Washing Machines
Kenmore washer 80 series 110 model not spinning.
unless your washer is over 20 years old, then it wont have a belt. the temperature of the water wont have anything to do with it spinning or not.
need to know if it agitates or drains and just wont spin.
if it agitates but no spin or drain, then you have a bad lid switch.
if it wont agitate or spin, but will drain, then you have a broken drive coupling.
Jan 08, 2009 | Kenmore 24032\24036 Top Load Washer
Washer trouble
Broken motor coupling. They are cheap and easy to install. Even paying a tech to do it will sure beat buying a new one, and these are great designed washers!!!!!!!!!!!!!!!!
Jan 14, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
163 people viewed this question
Top Washing Machines Experts
