Question about Infinity PS-10 Subwoofer
My Infinity ps-10 subwoofer makes crackling sounds. I took it to a repair shop and they say it needs a new power supply and a new amplifer and that it will be over $200 to repair it. I only paid $400 (6 years ago new). Is it worth repairing? Can I fix it myself? Can I buy parts?
    Brigadier General:
  • 8,546 Answers
Probably not, but you could make it into a passive subwoofer by disconencting its internal amp and powewring the driver directly by an external amp being fed by an LFE channel.
I did this with a problematic Klipsch SW.
Posted on May 15, 2010
  • doncakes Dec 04, 2010
    Thanks, I will try this as It will help me determine if the speaker or the amp is bad on my ps-12.
    I get a speaker hiss even with sound disconnected and can replace the speaker for $75 or the amp for $154 (when ordered from infinity). I want to be sure which it is before I order.
Once my sub warms up it makes a noise which occurrs every 8-10 seconds apart. It sounds like an amplified ark
You should power the system off right away when you hear that because the thermo shut down does not kick in. The temperature will eventually damage your semiconductors and capacitors and the system will be completely damaged. You need to ventilate the system better and even upgrade the heat material if you can.
Sep 24, 2011 | Infinity PS-12 Subwoofer
My Infinity sub-woofer for my home surround sound system will not turn on. The power light wont even turn on. What can I do to repair this? It seems that no electronic place with repair infinity speakers...
Open it up and see what is in there! You might find a fuse blown. It might have just blown, without a fault, if you are lucky. If not check out the part numbers on the amp board. All semiconductors numbers, then put the numbers into google. You will soon find out if they are obtainable!
Jan 19, 2010 | Infinity PS-10 Subwoofer
Sub goes full blown loud when plugged in to wall
It sounds like a power supply failure. It needs to go to a repair shop.
May 05, 2009 | Infinity BU-2 Speaker
Infinity ps-10 powers up but no boom
Try hooking up a different signal input to your powered sub, another stereo or even a dvd players audio output to the sub will work for a test. Just make sure the subs gain is down before starting. If it still not producing sound, the subwoofers amplifier is bad. I hope this helps.
Oct 10, 2008 | Infinity PS-10 Subwoofer
PS-12 subwoofer problem - Infinity Customer Support number?
Fixed the problem...I just purchased another one online (from a store that has a good return problem) and will return the one that doesn't work! Cheers! :)
Jun 26, 2008 | Infinity PS-10 Subwoofer
Inifinity Entra Sub not working
The hum can be from the power supply not properly filtering, and or the output stage also has a short.
There is the chance that the speaker driver coil is now burned, or the power supply is now dead. If ther output stage is shorted and was putting DC on to the speaker cone, this will burn it very easily.
You should sent the unit out and have it serviced, unless you are properly trained, have the service and engineering manuals, and the test equipment to follow up on a proper repair and calibration.
Jerry G.
Apr 27, 2008 | Infinity PS-10 Subwoofer
Infinity PS-12 Subwoofer clicking in and out of standby
Unfortunately your subwoofers amplifier circuitry will need to be repaired ,the amplifier is bad and kicking in to protect mode. This mode is designed for safety of the unit and user and sub should not be operated until repaired as it may incur more damage to the components. I hope this helps.
Feb 18, 2008 | Infinity PS-10 Subwoofer
Infinity PS-10 quit working
I think the electronics have a 3 years warranty and the drivers have a five years warranty for this product, maybe you can have it replaced. Maybe the auto on/off signal detector is the culprit.
Dec 09, 2007 | Infinity PS-10 Subwoofer
Polk subwoofer making crackling noises
Yea, now its time to replace it! the magnetic effect is weaken which makes the very bass low frequency sound to be distorted! You should re engergise the magnet of the subwoofer or should buy the new!
Dec 08, 2007 | Infinity BU-120 Subwoofer
Infinity PS-10 Subwoofer Logo
1,512 people viewed this question
Top Infinity Audio Players & Recorders Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Matthew Spark
Matthew Spark
Are you an Infinity Audio Player and Recorder Expert? Answer questions, earn points and help others
