Question about Philips Magnavox MWR20V6 DVD Recorder/VCR
Cannot time record on dvd+r dvd's Magnavox Recorder Model MWR20V6
  • 4 more comments
  • whipperwill May 17, 2010
    the previous expert decided my problem was a glitch in the original programing of my recorder. he checked with magnavox and funai but found no upgrades available that were applicable.
  • whipperwill May 19, 2010
    still looking for assistance
  • whipperwill May 25, 2010
    unable to time record on my recorder. Error message is E40.Any suggestions?
  • whipperwill Jun 02, 2010
    cannot time record on my Magnavox MWR20v6 Combination vcr/dvd recorder
    Cannot time record on Magnavox combo recorder model MWR20v66
  • whipperwill Jun 05, 2010
    unable to time record on my magnavox combo dvd/vcr recorder model MWR20V6 (all other functions ok}
  • 4,889 Answers
Is the time record function not working? If not then are you not able to figure out how to do it?
Posted on Jun 05, 2010
  • 3 more comments
    I believe I know how to go through the set up ok but it does'nt work---like there is something wrong with the program.
  • whipperwill Jun 07, 2010
    I have the manual that came with unit when I purchased it several years ago.It works fine in every way except timed record(works fine when recording manually).I've gone through the recommended procedure for timed recording many times, but when the time for it to turn comes nothing happens. The error message is always E40.
  • eagle338
    eagle338 Jun 08, 2010
    Verify whether you have followed all the steps correctly that are page 30 of the manual below This one is more detailed than the one you get with the unit. If problem persists let me know.
    http://www.funai-corp.com/6pdf/om/MWR20V...
  • whipperwill Jun 11, 2010
    I downloaded the Funai manual & read & reread chapter 30 regarding timed recording. I've run the recording program several times using various start, finish & mode times with always the same result---will not record. The program seems to work up to the point where it tuns on. Two minutes before time to turn on the dvd symbol goes to blinking but when turn on time comes nothing happens. Any suggestions?
  • eagle338
    eagle338 Jun 12, 2010
    Looks like you have a disobiedient firmware. Time to upgrade it. There is a firmware upgrade disk that can be obtained from philips. Apparently it has a lot of recording bugs fixed. So I suggest you try it and see if it works.
    Sai.
  • 11,896 Answers
Go to menu, timed recording/recording, set the date, the channel to record (usually input or av channel if you are using rca jacks) (channel 4 if you are using coaxil cable) then set the time for the recording to start, the time for the recording to end, then press exit. It should now be all set.
Posted on Jun 03, 2010
  • Nate Stansfield
    Nate Stansfield Jun 07, 2010
    You can get the manual here if you need it:
    http://tv.manualsonline.com/manuals/mfg/...
    The recording options are on page 27 If you need more help, let me know
  • Nate Stansfield
    Have you followed the steps in the manual for timed recording? Are you making sure to use the auto frame rate setting as well? At what part is it not cooperating?
  • Philips Master
  • 5,138 Answers
Alot of the time when these units quit working correctly its cheaper to buy another one, you could have Bad IC in unit.
Posted on Jun 02, 2010
  • 566 Answers
Hi whipperwill
It would seem that your not the first that has problems with the timer recording.
So here`s what i`d like you to do;
Set your timer as you usually would and if recording on disk , use a blank that has`nt been in another machine as the recorder has to format it using it`s own system.
Once the program is done press the "timer set" button on the remote and make sure the unit goes into standby mode, otherwise use the power button to power it down.
In otherwords the unit has to be in standby mode when the selected time comes around.
So if you`re using it in the mean time , make sure to power it down with the timer set or power button.
Let me know how it goes
Posted on May 25, 2010
  • 1 more comment
  • whipperwill May 26, 2010
    I've done as you suggested: put a fresh dvd in the recorder. Programed it for a 30 minute session with a 1 hour mode time. Hit time set and the standby symbol came up with a dvd symbol (steady state). In 2 minutes the dvd symbol went to blinking. When time came for recorder to come on nothing happened. This is what occurs every time I've run a program.
    any more suggestions?
  • Jacques Marin
    Jacques Marin Jun 02, 2010
    hi again
    The only other suggestion that i might have is to download the owner`s manual here:
    And if all of this doesn`t work then you dvd/vcr is defective and needs to be serviced or replaced.
    Good luck
  • 4,472 Answers
Have you followed all the steps on p. 30 of the manual. You can download and view the pdf at this link:
http://www.funai-corp.com/6pdf/om/MWR20V6.pdf
If so and there is a problem recording it should give you a specific error number. If your having problems with the one of the steps let me know.
Thank you,
Lee
Posted on May 19, 2010
  • 3 more comments
    I went through the entire timed setup and hit timer set. The standby symbol & dvd symbol (steady state) came up. Two minutes before the timer was to turn the recorder on the dvd symbol started blinking. When the timer should have turned the unit on it did not (after the two minutes of blinking).There was nothing recorded therefore no error symbol.
    Any suggestions?
  • whipperwill May 20, 2010
    May 19, 2010 - I went through the entire timed setup and hit timer set. The standby symbol & dvd symbol (steady state) came up. Two minutes before the timer was to turn the recorder on the dvd symbol started blinking. When the timer should have turned the unit on it did not (after the two minutes of blinking).There was nothing recorded therefore no error symbol.
    Any suggestions?
  • Lee A.
    Lee A. May 20, 2010
    If the timer program did not complete correctly, the error number appears in the Timer Programming list.
  • whipperwill May 21, 2010
    I've run the timer program several times using different mode times and checked back after each program had finished. The result each time said the error was E 40. What do I do now?
  • whipperwill May 24, 2010
    Do you have any further words of wisdom for me ?
Hello. I have done some reasearch on your MWR20V6 device, and have found the following steps which will enable you to "Timer Record." At the bottom is a picture of your remote, so that you know what buttons to press.
1. Press [TIMER]. Timer Programming list will appear.
2. Using the up and down arrows, select a program number. Press [OK].
3. Using the up and down arrows, enter the date. Press the right arrow.
4. Using the up and down arrows, enter the start and end time. Press the right arrow.
5. Using up and down arrows, select the channel number to record. Press the right arrow.
*To record from external input, select E1 or E2.
6. Using the up and down arrows, select a recording media. Press the right arrow.
* To record on a videotape, select VCR, and to record on a disc, select DVD.
7. Using the up and down arrows, select a recording mode.
8. Press [OK] when the information is entered. Your program setting will be stored at this time.
9. Press [TIMER SET] to set a Timer Programming. The clock icon and the words 'DVD RW' will appear on the front panel.
Buttons:
Source: http://www.funai-corp.com/6pdf/om/MWR20V6.pdf
Posted on May 17, 2010
  • whipperwill May 18, 2010
    this would be the normal way if my recorder was programmed correctly but i have been down this road so many times this isn't the solution. you can't do the same thing over & over again & expect a different result. do you have another thought?
  • 476 Answers
You say that you can not time record a DVD, but can you record a program manually? If you can not record at all, either while using the timer or trying to record manually, then the problem is in the burner portion of the optical assembly, the optical assembly consists of two sections, the playback or reader and the burner or recorder, and they are both included in one assembly. So if the recording side is not working at all then the whole assembly needs to be replaced.
If you are able to record manually, then there is a problem in setting up the different program for the start and end times or the main clock is not set correctly.
Posted on May 14, 2010
  • 3 more comments
  • whipperwill May 15, 2010
    I can record manually. I've checked and reset the clock over over again. When I set up the timed program all goes well until the time comes for the recorder to come on but it doesn't. I've tried using the various programs ( today's date,daily,mon-fri ) etc but cannot get any of them to work. I agree it sounds like a clock problem but it's got me buffalod.
    Where to now?
  • jaime vargas May 15, 2010
    When you set the different program times and after you press the timer set key, do you get the timer record icon? If you do get the icon, The problem might be a firmware glitch, but before going further, try resetting the whole unit by unpluging it from the AC outlet and reset the clock and timer record program, see what will happen.
    Unplugged unit to reset. Reset clock. Ran new program---still same problem (will not record).
    whipperwill, I can not think of anything else to try, I was thinking that maybe some type of factory change or an update in the dvd recording process, but both the Magnavox and Philips web sites do not recognize this model number, I managed to locate the owners manual for this model under the funai corporation's site, but they do not show any firmware updates for this. I do not think I can help you any further, so you might keep the post open for somebody else that might have ran into this problem before, I will keep searching for an answer in the meanwhile for you.
    Good Luck!
    kbzon
    Thanks for all your efforts. I've had this unit for several years and never been able to time record with it. It works well in every other way. Probably had glitch in original programing.
    Thank you,
    whipperwill
Have philips univerasal remote need codes for my panasonic dmr-ez28 dvd recorder
Panasonic DMR-ES30VS DVD Recorder/VCR Universal ...
www.fixya.com > ... > Panasonic DMR-ES30VS DVD Recorder/VCR
Panasonic DMR-ES30VS DVD Recorder/VCR, universal remote related issues. Getfree help ... My remote does not work anymore. what is the code for a universal remote? Thanks in ... Question about Philips DVD & Blu-Ray Players ... How do I getremote code for GE universal remote control Need remote code? How to ...
Philips Magnavox MWR20V6 DVD Recorder/VCR Remote ...
www.fixya.com > ... > Philips Magnavox MWR20V6 DVD Recorder/VCR
Dec 20, 2015 | Panasonic Televison & Video
The antenna out for the coaxial broke off.Can it be fixed?Or do you still sell this model?It is the Magnavox/video cassette recorder/dvd recorder,model#MWR20v6,searil#D25642475A.Or do you sell a newer...
sure it can, just a bit of soldering. unplug and open up the unit. the outside of the coaxial housing is the ground side, and there should be a very small pin that will insert to circuit board. you just need to reconnect them. Ive used hot glue in a pinch before.
Mar 14, 2011 | Philips Magnavox MWR20V6 DVD Recorder/VCR
I have a phillips magnavox vcr dvd recorder combo model number mwr20v6 that i have had fo about 2 years and here lately every time i try to record on to a dvd it pops up with error code e454037380.i have...
I have a phillips magnavox Problem with the Philips Magnavox MWR20V6 DVD Recorder / VCR Combo I have a phillips magnavox vcr dvd recorder combo model number mwr20v6 that i have had fo about 2 years and here lately every time i try to record on to a dvd it pops up with error code e454037380.i have cleaned the lens with a disc cleaner and still didnt help,same thing is happening. i am also using the same type of disc that I have been since day 1. Can you help??
Mar 09, 2011 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Magnavox DVD/VCR Recorder ZV457MG9 How do I finalize my DVD on this player/recorder?
http://www.ehow.com/how_8623235_do-finalize-magnavox-dvd.html is how to finalize a disk on Magnovoz! I have the ZV457MG9 - its model takes with
1) loading disk
2) select the set up button
3) select DVD edit
4) select finalize DVD
Then you finalize the DVD!!!
Jan 31, 2011 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Is there a remote control code for model zv427mg9?
For my direct tv remote, 20675 worked for me :) magnavox zv427mg9 combo vcr, dvd
Sep 27, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Dont know how to finalize dvd after recording on magnavox vcr/dvd
You can find a copy of the manual on the web link provided here:http://tv.manualsonline.com/manuals/mfg/magnavox/mwr20v6_1.html Print a pdf copy for yourself. If you need more help the customer care for you dvd/vcr player is at this telephone number. 1-800-605-8453 give them the model number of your dvd/vcr unit and they will be able to help you. I hope this information helps you with your problem.
May 10, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Unable to view recorder movie
unplug 10 min then try from start...somtimes they freeze up!
Dec 09, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
My vcr won't play back
I have a Magnavox zv457mg9 DVD&VCR combo ,and the vcr records for a short period(10minutes) and then cuts off. This happens each time I try to record on the VCR. Any suggestions??
Feb 26, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Magnavox MWR20V6 problem
on my magnavox mwr20v6 i cant record my vhs to dvd i get black screen every time and my DVD are new and I just open my magnavox after a long long time and ecsup for get my VHS record to DVD it is fine I would like to fix this issue :(
Jan 01, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Philips Magnavox MWR20V6 DVD Recorder/VCR Logo
156 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
