Question about Jl Audio CVR12 Kicker 12" CompVR Series 2005 Car Subwoofer (800 Watts) Car Speaker
Dont know how to wire subwoofers to my mutant amplifier
  • Bobinger79 May 17, 2010
    First of all, we need to know the specs of the amp and the woofers. What's the model number, manufacture, size, dual voice coil (DVC)/single voice coil (SVC). As for the amp, it's mainly the model number
    Guru:
  • 256 Answers
I take it that you have two woofers to connect. That said, you need to bridge your speakers to your amplifier to get them to really thump. Firstly, check on you amplifier where the bridging connections are, ie. you will have connecting screws for two speakers +-, and +-. There should be a mark indicating the bridged output, normally the first + and the last -. Now, connect the + of your one speaker to the - on the other speaker. The two un used terminals will go to the amp ie. the one - onthe one speaker and the + on the other one.
Posted on Jun 08, 2010
WHAT AMP DO I NEED TO RUN MY MUTANT 120 SR AMP MANUAL
60-100 amp fuse should be plenty i run my ssl 850 monoblock of 60amp no problem
Feb 27, 2013 | Mutant Car Audio & Video
I dont know how to conect my subwoofer to the box,, because it has 2 coils
Friend,
Please visit rockford foshgate web site and look for wiring wizard.
From there you will know as to how to connect the wire to your speaker.
Using the 2 voice coil is a must in order for you to get the best result and best performance of your speaker.
Before connecting the wires of your speaker please see the load required from your Power Amplifier.
Please take note that most of the Power Amp. (CAR) need 4ohms load.
Regards,
peybols
Feb 12, 2011 | Cerwin Vega Stroker 12 Car Subwoofer
Where can i get the wiring diagram for the mutant nw280sp car amp thanks
Here is a direct link to the wiring diagram for this amp.
http://www.crutchfield.com/S-liATTbX39zU/learn/learningcenter/car/amplifiers_wiring.html
Hope it helps you? please comment for more information and thank you foe using fixya.
Jan 27, 2011 | Car Audio & Video
I have a subwoofer with standard speaker wire connection, how to I attach to a receiver with a subwoofer cable?
The Subwoofer is Likely Passive....meaning no amplifier is within the enclosure itself....the incompatible connectors mean you cannot connect the subwoofer itself to your surround sound system.
look for a Suitable stand-alone (1 Channel) Amplifer with sufficent power.....connect the RCA Imputs (subwoofer cable) to the Recievers RCA subwoofer output....then connect the amplifier's output to the the wire going into the subwoofer enclosure....if there is a plastic connector simply cut it off and strip the wires down a sufficent lenght....then secure the wires to the output of the amplifier.
if you do this make sure you know the ohm rating of the subwoofer and the minimum ohm rating of the amplifier your using.
Nov 24, 2009 | Sony BRAVIA DAV-HDX267W Theater System...
Mutant amp protection off
this is caused by a shorted output transistor(s) in the main amp.
Jun 12, 2009 | Car Audio & Video
4 chanel amp I dont know how to conected,to radioand one subwoofer
Hello canelo63,
Your question appears under the product listing for the Dual XPA4100 but the in the text you say the amp is actually a Jensen, so it's not possible to provide specific connection information.
But most bridgeable amps can be connected to a single subwoofer and the other two channels used to drive a set of regular speakers. I'd connect the front speakers to channels 1 and 2 and wire the subwoofer to the bridge connections of channels 3 and 4. On the XPA4100, the bridge terminals are the first (negative) terminal on channel 4 and the last (positive) terminal on channel 3.
Hope this helps.
Jun 01, 2009 | Dual 2-Channel Bridgeable MOSFET Amplifier...
I need instructions connecting my car subwoofers
Bridging your amplifier @ 4 ohm will yield the most power.... with the subwoofers you have.
You must wire them in Parallel.
Positive on both subwoofers to + on amplifier.
Negative on both subwoofers to - on amplifier.
The lowest impedence possible with 8 ohm woofers is 4 ohms.
Thank you for using FixYa - a FixYa rating is appreciated for taking the time to answer your FREE question.
Mar 28, 2009 | Pioneer TS-W307D2 12" 1200 Watt Champion...
How to wire 2 dvc subs to a orion 2150sx ? dont know the wire colors or how to hook um to my amp.
what impedence are the voicecoils?
Dual 4 - Dual 2 - Dual 1 ??
Orion SX / GS / HCCA amp Wiring guide:
Orange = Right Positive
Black/ Orange = Right Negative
Yellow = Left Positive
Black/ Yellow = Left Negative
Blue = 1+1
Bridging of SX or HCCA Amps:
1. Use the Orange wire for Positive.
2 Use the Black/ Yellow wire for Negative
3. Push "in" the Mono Button
That amplifier is only 4ohm mono stable - so assuming the subs are dual 4 ohm voicecoils...
First wire both in Parallel Independently So each subwoofer is now a 2 ohm load. (combine + and + - and- on both subwoofers)
Now Take a positive on one voicecoil of sub #1 and attach to amplifier+(orange)
Take a - on that same subwoofer and attach it to a + on the OTHER subwoofer.
Finally, take a - from the second woofer to the amplifier -(black/yellow)
Now you have a 4 ohm load on your bridged channels.
Thanks for using FixYa - a FixYa rating is appreciated!!
Feb 23, 2009 | JBL 1200GTi Car Speaker
Car Speakers
YOUR POWER WIRE IS NOT STRONG ENOUGH TO HANDLE THE POWER. GET A BIGGER POWER WIRE AND SEE IF THAT HELPS
Jun 30, 2008 | Car Audio & Video
Car Audio & Video Logo
140 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
Tygh Duval
Tygh Duval
hoyzee1
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
