Question about Sage Colorado Pontoon Boat
MY (PLAYBOUY PONTOON) HAS A SMALL PINHOLE LEAK. IS THIS SOMETHING I CAN FIX? IF YES, WHAT MUST I DO?
  • 3 Answers
Marine JB Weld works well
Posted on Jun 14, 2010
How do I fix a pinhole leak in the water dispenser tubing of a GE refrigerator freezer model TFX25KR TFX22KR?
You can repair those pinhole leak with a solvent used on pvc water tubing.
You can also use a epoxy that are specifically use on marine vehicle.
Put a small amount and apply to those pinhole.
Just be sure before you buy, look for those non-toxic material that is not hazardous to health.
Thanks for asking.
Jul 01, 2011 | Refrigerators
I have a pontoon seam that may be leaking on my 20' pontoon boat. If so, how can I repair it? It's made of aluminum and I have a boat lift so can raise it out of the water. Something like "Liquid Steel" or...
I should think that if it is only a leak and not structural weakness or damage that epoxy of some sort would do the trick. make sure you dry and clean the metal well and degrease before applieing the material weather you apply in inside or out.
Jun 01, 2010 | Boating
I recently had the radiator in my 95 chevy cavalier replaced.I am still having to put water in every week even though we see no leakage.The heater was working exvellent until now.Now I have moisture on my...
Your heater core has a small leak. You can try to fix it with some rad sealant, the kind you put in your radiator, like "Barsleaks" or something. I find the aluminum filing type work the best. When your rad is low, mix the filings in a few cups of water, and then add to the radiator, and let it run for a while. If the leak is more than a pinhole, it probably won't last long, and the heater core will need to be replaced.
Jan 24, 2010 | 1995 Chevrolet Cavalier
Reseting from Small Pinhole
For sansa clip, there is not "small pinhole" to reset. A small hole you see on the cover of the device is microphone for voice recording only. To reset device, you have 2 ways
1. Normal reset: Settings >> reset >> yes
2. Hard reset: press and hold power button for 10 to 15 seconds.
Dec 19, 2009 | SanDisk Sansa Clip MP3 Player
One of my pontoons leaks off fairly quickly, Its is leaking around the seam of the valve how do i fix or replace it?
With a leak kit supplied by the company that make the pontoon. They are either rubber or neoprene so the patch needs to be the right material and the glue needs to contain the right solvents. Cut a circular patch and use a punch to make a nice round hole to fit over the valve. Glue following the instructions.
Up here in Canada, both Canadian Tire and Bass Pro Shop do repair kits.
Nov 28, 2009 | Sportsstuff Venture Pontoon 52 1720
I was told I have a small oil leak (lost 1/2 quart of oil after going 5400 miles by the Jiffy Lube staff. Is this something my normal mechanic can fix?
Yes a regular certified mechanic should be able to fix any oil leak without to much trouble.Some leaks can be a bit more extensive and costly to repair but on the norm ANY mechanic should be able to fix it..
Jul 30, 2009 | 1999 Jeep Cherokee
I need a new inflation valve for my colorado pontoon boat
Check E-bay -
Item number: 310151809453, Pontoon Boat Boats Outdoor Parts Repair Kit Kits black
What is your problems with pontoon bladder
Thanks for reply
May 30, 2009 | Sage Colorado Pontoon Boat
Sage Colorado Pontoon Boat Logo
316 people viewed this question
Top Sage Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Sage Boating Expert? Answer questions, earn points and help others
