Question about Kenmore Dryers
I have a Kenmore Dryer model 110.60922990. after starting it within five minutes I saw and smelled smoke. I have pulled the front kick plate off. On the heating element, the coils are not broken in any spot. the metal is discolored in one spot on both sides. I took a shop vac and removed alot of lint. It was black on top from the heat. My question is could the element still be bad even if the coils are not broken?
  • 131 Answers
SOURCE: Dryer runs but doesn't heat up when sttings call for heat.
You may need to do some troubleshooting. This can be done with the machine unplugged - you may have to activate the start switch, belt switch (if it has one) and the motor centrifugal switch manually.
Tip for troubleshooting 220v systems - clip one lead of a ohm meter to either L1 or L2 on the terminal block. It doesn't matter which one. According to the tech sheet (under console) follow the path for current from your clipped terminal, through the heating element, to the opposite terminal. All the readings should be less than 100 ohms, until you reach the failed part. Confirm failure by disconnecting a lead from the suspected part, and test only that part.
Live troubleshooting is sometimes slightly easier, but much more dangerous than the procedure described above. - It is definitely not recommended for beginners, or for professionals, if it can be avoided.
Posted on Mar 10, 2008
Master_Tech
  • 770 Answers
SOURCE: dryer smelling hot and smoke detector goes off
clean the venting going to the outside and the dryer really ahould be taken apart and delinted to avoid a fire if the unit is older
Posted on May 12, 2008
Washer_tech
  • 164 Answers
SOURCE: I HAVE A MAYTAG ATLANTIS GAS DRYER STOPS HEATING ABOUT 5 MINUTES IN
the flame going out is normal. the heat cycles on and off as called for by the thermostat. If the heat doesn't come back on i would start by changing the gas coils.
Posted on Nov 04, 2008
jsrock516
  • 5911 Answers
SOURCE: Dryer Top Hot / New Heating Element Smell
Any time you perform work inside a dryer, lint can get kicked around and settle on components. It is common to have a slight burning smell for a day or so. However, your dryer getting too hot to the touch concerns me. Improper air flow is the number one cause of dryer overheating problems. You may have cleaned the lint out of the interior of your dryer, but did you check the air blower and vent duct lines? In addition, was the heating elements actually bad? Or, did you assume it was bad, because your dryer wasn't drying properly? The following link can explain:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
Pay particular attention to the paragraph that discusses proper ventilation. I would recommend you remove the vent hose from the back of the dryer and attempt to dry another load. If the dryer dries more efficiently and the top panel does not get scorching hot to the touch, then you have a vent clog somewhere EXTERNAL to the dryer. If the dryer air flow exiting the dryer is weak and the dryer still gets too hot to the touch, you have a clog INSIDE the dryer.
Follow these steps, first and see what you find. If you verify your ventilation is clear and not kinked or clogged anywhere, then you might assume you have a component malfunction. I would hope to try to save you from purchasing parts you may not need. I hope you find this information helpful. Let me know if you require additional assistance.
PS Make sure you are using semi-rigid (metal type) vent ducting. It is crush resistant, heat resistant, does not kink easily, and resists rodents. It is what most manufacturers recommend. If you haven't replaced the dryer vent in a while, this may be a good time.
Posted on Nov 18, 2008
  • 530 Answers
SOURCE: Kenmore electric dryer shuts off after 5 minutes and won't restar
when you try to start it again do you hear a humming comeing from the motor? can you jump start it by turning the drum while holding the start button? If you say yes to these questions you have a bad motor.
Posted on Jun 21, 2009
Kenmore elite front load dryer squeaking and burning smell
you have a bearing in the drum support that has frozen and now the rubber wheel is burning up. The bearing needs to be replaced ASAP. You could damage the dryer if you continue to use it.
Feb 16, 2014 | Dryers
How do you remove the front kick panel
Here are the steps.Hope this helps.
Insert a putty knife between the top of the kick plate and bottom of the front panel near the center of the washer, if you have an older model top load washer. Move the putty knife blade in and out in that area until you feel an obstruction. The obstruction is the kick plate retaining clip
Press the putty knife blade over the spring clip until you feel the clip disengage. Let go of the putty knife and grab both ends of the kick plate with your hands. Pull the kick plate away from the washer
ift the front of the washer with help from a friend, if you have a front load model Whirlpool. Slide a block of wood under the front of each side and gently lower the washer Remove the three hex head screws on the bottom edge of the washer kick plate with a Phillips-head screwdriver or nut driver. Pull the kick plate away from the washer.
Jun 19, 2011 | Kenmore HE2 Plus Front Load Washer
Kenmore Electric Dryer Series 80 Model
Disconnect the dryer from your vent completely,. pull dryer out 3 ft. from wall and test to see if the smell continues, You have to test for a few minutes to clear out any burning lint from vent restrictions. If the smell hoes away then you know you have venting problems. Also check on the grate that covers the element( the part you look through when you see the orange glow from the element) sometimes plastic or clothing burns onto this grate and needs to be cleaned off. I the smell remains, you will have to tear down the dryer to see if you can find the cause of the smell.
Sep 21, 2009 | Kenmore 62802 Electric Dryer
Kenmore dryer shuts off after five minutes
The vent box inside the dryer still has lint in it. You need to reach way inside to get at it. Turn power off.
Jul 22, 2009 | Dryers
Where are the gas solenoids on a Kenmore gas dryer and how do I get to them?
If your dryer has a bottom kick plate pull it off and the gas solenoids are on the left side can’t miss. If you don’t have the kick plate the front of the dryer must come off. The whole front will come off very easy just lift the top up from the front and the remove two screws on each side hold the front on and lift the front up and off be careful of wire’s to the door.
bobby18rg@hotmail.com
Jul 14, 2009 | Kenmore 74832 Gas Dryer
Whirlpool dryer front panel
I located a video on youtube.com free of charge. I removed the lint screen, and removed the two screws located in the lint screen housing. Then I pryed the top off near the front of the dryer, which has two clips. Then I remove the two screws locate on the top of the front panel, but they are located on the inside. I removed the door lid swich by removing the two screws. Lastly, I pulled the front panel outward and pulled up lightly. The front panel was off. The issue I had was the dryer would heat up and then got cool after five minutes. The solution was to replace the coils. Important point is that the coils ohm readings were within specifications, but I did located information on the web that indicated this was a potential solution to the issue, and I replaced the coils even though the resistances were within specification. Total cost $22.95 plus tax.
Mar 24, 2009 | Whirlpool Dryers
Dryer heats up cools down in few minutes? Kenmore gas
we need to take a look at the heating system and exhaust,,where going to start with simplest ok..your filter is cleann...check exhaust from back of dryer leadind all way out house make sure that path is clear...next pull exaust off and run dryer,,if not good,,let me know ,,onthejob
Jan 10, 2009 | Dryers
Burning smell
you can unplug the unit , and reomve the lower aces panel (3 screws along the front bottom of unit) youll probalby see an excess of lint built up in which case you can vacuum it out, and then check/clean and or replace your dryer vent
Nov 16, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Dryer Model 66801692
at leas 15 yrs old??? think it's done its time, its a great machine andwould reccomend replacing with a whirlpool/kenmore unit again.no tworth servicing in my opinion, average call here in new york 150-225, anbd those are for simple issues. id rather put money into new unit! bit be sure to check your venting id say 85% of dryers taking too long to dry are vent related issues
Nov 13, 2008 | Kenmore 62872 Electric Dryer
Dryers Logo
145 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De GO PATS
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
