Question about Maytag Dryers
Maytag Dryer drum not turning properly after cleaning
Maytag SDE4606AYW Clothes Dryer
We just opened up the front of our dryer and cleaned it out. There was a lot of lint a debris inside the dryer as well as in the blower. We put it back together and now the drum isn't turning normally. It will spin fine until we put clothes in it. It will barely turn with the clothes - but when the weight of the clothes are removed - it turns properly. Wondering if we disturbed the settings for the pully system? How do we remedy this? Thanks in advance!
  • 494 Answers
Make sure the drum belt is positioned properly. You may have disturbed it when you removed the front door panel. It should be a tight fit on the drum. You should see the wear pattern on the drum where the belt was. Check the condition of the belt and make sure it's not cracked or stretched and slipping. Did you disconnect any wires when you opened it? Double check that you didn't rehook the wires wrong and make sure the door sensor switch is in proper position. Hope that helps.
Posted on May 15, 2010
Maytag dryer clothes gray soot around the drum and door
Sounds like drum belt is out of alignment and rubbing. Check the rotation/alignment with pulleys and drum. If belt is worn replace it. Hope this helps.
Feb 17, 2014 | Dryers
My Maytag Performa electric dryer heats and tumbles, but the clothes take multiple cycles to dry, and water is pooling next to the left front foot. We cleaned the vent, replaced the vent hose, and opened...
two things come to mind; 1. although drum is rotating perhaps it is slipping under load. Change drum belt, and, 2. perhaps the problem isn't in the dryer, it could be that your washer is not spinning out properly leaving an inordinate amount of water in your clothes which would tax the performance of the dryer. Just a thought. good luck!
Aug 19, 2013 | Dryers
My dryer is squeaking loudly when I first put clothes in it, quiets down after 10 minutes or so. What do I need to do to fix it? Do I need a new belt of some kind. Can't find manual:(
The dryer needs to be dis-assembled and the drum removed.
Then remove and clean the drum support roller wheels and shafts.
Inspect the front drum glides for wear.
Also remove and clean the tension roller shaft wear the belt rides at the motor.
Inspect the drum felt seal for tear and wear.
Feb 20, 2011 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag dryer is leaving black marks or rings on clothes
If your clothes get marked or torn in your dryer, check these: Rollers Rear seal Front glides Front seal Rollers Your dryer may use rollers, or wheels, to support the rear of the clothes drum. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the rear of the dryer interior. When the rollers wear out, you need to replace the whole set. Rear seal Your dryer may have a felt-like seal at the rear of the drum. If this seal is worn, torn, or missing, clothes can get caught and torn in the space between the clothes drum and the rear of the dryer interior. When the rear seal wears out, you need to replace it. Front glides Your dryer probably uses nylon or plastic glides at the front of the clothes drum for support. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the front of the dryer interior. When the glides wear out, you need to replace them as a set. Front seal Many dryers have a felt-like seal at the front of the drum. If this seal is worn, torn, or missing, the clothes in the dryer may get caught and torn in the space between the clothes drum and the front of the dryer interior. When the seal wears out, you need to replace it.
Aug 01, 2010 | Maytag Dryers
Overheating dryer - motor replacement???
Good day,
You said "The dryer is still overheatng". If your not describing the motor but the whole machine then that problem will have to be resolved.
Maytag's build lint up badly in the blower housing area and the duct between it and the filter. Requires disassembling the front of the dryer and cleaning that area as well as determining if the blower wheel is loose on the motor shaft requiring replacing.
If the overheating is the motor itself, then replacing it would be a common item on that brand.
May 14, 2010 | Maytag Dryers
My clothes have brown marks on them that look like burn marks. has this been a problem with maytag neptune dryers? if so, what is going on?
Rollers
Rear seal
Front glides
Front seal
Jun 29, 2009 | Maytag Neptune MDE4000 Electric Dryer
Grease type substance inside
Hello. I know exactly what is wrong with your dryer.
Rollers
Rear seal
Front glides
Front seal
Jun 07, 2009 | Dryers
Black Film on the inside of the dryer drum. Transfers to clothes.
The gas is not mixing properly with the air. You could have a blocked or restricted vent which has caused lint to back up in the machine thus giving you a poor burn. Check your venting and if it is clogged you may need to dismantle the dryer to clean it out inside. :)
Apr 09, 2009 | Dryers
Black carbon/soot on the door and lint filter of my dryer
I have the same problem with a Maytag Performa gas dryer. My husband took our dryer apart and found that the burner tube which leads from the burner to the back of the dryer was full of soot (which was getting blown back into the dryer drum with the hot air.) We are cleaning it out now but would like to know how to prevent this from recurring in the future.
Dec 16, 2008 | Kenmore 62602 Electric Dryer
Hi I am trying to clean my drain unsder my washer. I do not know how to pull the cover off.?? It appears I need special alan wrenchs for two little screws..?? any ideas??
Though the idea of repairing a clothes dryer can be pretty intimidating, the truth is that some types of repairs are surprisingly easy. Yes, dryers appear to be built like huge, impervious metal boxes, but they are typically pretty easy to open and relatively simple to fix.
As shown at How Clothes Dryers Works, a clothes dryer has a motor that turns a big drum containing the clothes, a heat source for blowing warm air into the drum to dry the clothes, and controls for operating the motor and heat source.
Some dryers have an electric element to do the heating while others utilize a gas flame; the latter must be vented.
Clothes dryer problems generally occur because the heat source doesn't heat properly or the motor fails to turn the drum.
If a gas dryer doesn't dry properly, the first thing to check is the pilot light or igniter--it may not be lighting the burner. The second thing to check is the dryer's vent-if it is clogged with lint, the heating system won't work properly.
Pay attention to basic safety measures when working on a dryer. Always unplug the dryer, and turn off the gas supply to a gas dryer at the appliance shutoff valve.
As with most appliances, maintenance will keep your dryer purring. Clean the lint trap after every load, and clean the vent system once a year.
Dec 13, 2008 | Whirlpool LTE6234D Top Load Stacked...
Dryers Logo
170 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
