Question about GE 30 in. Profile JP350 Electric Cooktop
Infinite switch has failed twice in the last 6 months on my JP350 elec. stove?
    President:
  • 1,430 Answers
This is usually the infinite switch has failed. They are easy to check and inexpensive. There is a video at www.appliancehelponline.com/servicemanual.html that will walk you thru testing this. It may be a different model but the testing will be the same. You can also enter your model # for diagrams and illustrations for your specific model. Not all models are available. All parts come with installation instructions.
Posted on May 14, 2010
All ignitions are trying to light at the same time. Had to unplug. Any clues as to what is happening?
Hi emaly169,
Moisture or water have come into contact with your ignition devices, they just need to be dried.
Please follow my directions on the Tip below on how to do this:
GAS STOVE CLICKING PROBLEM...
Kind Regards
JEDEMEYER1
* If this solution helped you, please rate it
Aug 16, 2011 | GE 30 in. Profile JP350 Electric Cooktop
I have a GE 30 in. Profile JP350 Cooktop. The large, front and right control seems stripped and will no longer control the cooktop. Also, the part that it sits on at the cooktop is not protruding up as...
Hi sounds like you have a busted switch assembly, this is very much fixable the part is around $50, but you would need to remove the top of the stove which requires pulling the unit from the counter, this is slightly more involved, but definitely doable i would also change the knob. A more accurate name would be infinite switch.
Sean
Mar 28, 2011 | GE 30 in. Profile JP350 Electric Cooktop
JP350.. Large burner (front right) only the inner circle lights up no matter where the switch is set (large or small). Bill wjgibbon@syr.edu
Sorry to read about your problem, I hope this helps you out.
you have a defective control board
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
ewrwer
werwer
Dec 23, 2010 | GE 30 in. Profile JP350 Electric Cooktop
The right front burner will only run on high no matter the setting
This is usually the infinite switch has failed. They are easy to check and inexpensive. There is a video at www.appliancehelponline.com/servicemanual.html that will walk you thru testing this. It may be a different model but the testing will be the same. You will need to remove the cook top from the opening to access the switch.You can also enter your model # for diagrams and illustrations for your specific model. Not all models are available. All parts come with installation instructions.
May 06, 2010 | GE 30 in. Profile JP350 Electric Cooktop
Cracked Glass cooktop
the glass top can be replaced.but u want 2 find out the cost of it first.they are pretty expensive and sometimes run almost equal to the cost of new stove.compare it to the cost of a new cooktop.
Jul 18, 2009 | Cooktops
GE Profile JP350 cooktop stopped working
OK, i think the problem took care of itself. definitely got water down in the infinite switch for the lower right burner. let it dry 12 hours and reset the breaker, now works fine. but, i know if i do that again, or if it happens randomly, i will have to replace the switch and seals (available at repairclinic.com)
to do that, you have to remove the cooktop (screwed down by a strap in the back to the back wall of the cabinet) remove the sheetmetal to access the switches and replace. just keep the wiring straight, and ALWAYS replace the seals, they leak over time.
Nov 09, 2008 | GE 30 in. Profile JP350 Electric Cooktop
GE JP350 wiring problems
a to black one
b to red one
d to orange
e to grey
a-e to red two
a-d to black two
a-c to orange two
a-b to grey two
a-a to white
Jan 19, 2008 | GE 30 in. Profile JP350 Electric Cooktop
Inop burner on new jenn-air JEC9530 elec flat cooktop
I'm having the same problem with my jec9530. The dual burner just quit working one day. I called jennair and they sent me a replacement "custom control" for free. 6 months later it quit again. I am now considering attempting to put an infinite switch (dual), part #PS786568 in its place. It is not electronic, and it looks like it is used for the jec9536 middle back dual burner. It is only $35, even if it doesn't work like the electronic one I don't care. My wife usually only uses both burners at the same time anyway.
Sep 04, 2007 | Cooktops
GE 30 in. Profile JP350 Electric Cooktop Logo
162 people viewed this question
Top GE Cooktops Experts
Dan Webster
Dan Webster
Jim London
Jim London
Are you a GE Cooktop Expert? Answer questions, earn points and help others
