Question about IBM NetVista A30p PC Desktop
I need to connect all the wires to the motherboard
I recently got a desktop with all the wires and such in a bag. i need to connect all the wires to the motherboard and what not. Any ideas on where everything goes?
    Champion:
  • 218 Answers
Yes i can help but far more easer to use the guides i have provided on youtube go to www.youtube.com and type in wiring up a new pc hope this helps
Posted on May 15, 2010
I cant find battery in cemos
It's CMOS Battery. Complimentary Metal-Oxide-Semiconductor,
http://en.wikipedia.org/wiki/CMOS
The CMOS Battery is a small watch type battery. (Like a desktop CMOS battery CR2032)
It is in a small plastic bag, and has two wires coming out of the bag.
The wires have a small white connector on them, which plugs into a small white connector on the motherboard.
It's on the BOTTOM of the motherboard. The laptop has to be completely disassembled, and motherboard out, to access it,
http://netbookitalia.it/samsung-n150-n150-corby-giallo-guida-disassemblaggio.html
The last photo at the bottom of the page show the CMOS Battery.
To the left of the middle.
Black roundish bag, Red and White twisted wires going to a small white connector.
(Might have just come unplugged)
[DON"T forget to use an ESD wrist strap, and connect the alligator clip to a good ground source. {Electro Static Discharge}
One example of an ESD wrist strap,
http://www.radioshack.com/product/index.jsp?productId=2103245
For additional questions please post in a Comment.
Regards,
joecoolvette
Mar 04, 2012 | Samsung N150 Netbook
To remove motherboard from laptop e-system ei3102
To remove the motherboard you need to remove power from the back, lay the computer on it's side, wear an anti-ESD wrist strap, remove the left side cover (looking from back of computer). Mark and record all connections (a video helps while you disassemble). Pull all connectors off by grabbing connector NOT wires. Some have locks. Remove all adapter cards (little circuit boards plugged in motherboard). Remove RAM by pushing on locks on each end. Remove the CPU fan and heat sink but PULL UPP CAREFULLY in case CPU stays attached. If cpu is still in socket, carefully lift locking lever and lift cpu straight up. Remove all screws. Board will need to slide forward slightly to get out of case. Take old board to store to make of proper replacement and take cpu also. Both should be in anti-static bags but DO NOT use ziplock bags. Install in reverse BUT cpu should fall into socket WITHOUT pushing, it has one corner of pins different from others. Make sure that you have wrist ******** at all times working inside the tower. Respond for further details if needed.
Feb 09, 2010 | E-Machines eMachines Refurbished EMA...
Need to re-attach power button cable, hard drive
The manual for your computer is available from emachines, p.168 shows the info you need (replacing the front I/O panel)
http://downloads.emachines.com/userguides/8511279_eM_NG3_chassis_HW_ref_en.pdf
The good news is that you can't harm the computer by connecting the wires wrong and the bad news is they just won't work the way they are supposed too if not connected properly. The LED's must have the correct polarity to work.
In general, if you look real close (as in magnifying glass and flash light) you will see the ID for each set of pins is printed on the motherboard (pwr,rst,HDD,pwr sw,speaker) Just match what it says on the motherboard to what it says on the wires. Don't worry if you get the polarity wrong. If a light doesn't work just swap the two wires. The colored wires should be positve (+), though. The reset (rst) and power switch (pwr sw) wires don't require polarity.
These instructions are for most computers in general, YMMV.
Nov 30, 2009 | E-Machines eMachines Desktop PC
Front Panel help for Dell Dimension 4600
Go to dell site and query for *********** board specs. Then query for the pinouts on the board. Or goodle dell optplex+motherboard+hardwire connections. good luck
Jun 17, 2009 | Dell OptiPlex 170L PC Desktop
Need proper wiring for the J9C2 connector pinout
The User Manual for this m/board (E210882) can be found at :- ftp://download.intel.com/support/motherboards/desktop/d865glc/BFLC_English.pdf
you will need adobe free reader to view it. refer to pages 40 thru 46 for the front panel header and isb info.
Apr 01, 2009 | Dell Dimension 4600 PC Desktop
I have an MSI Motherboard 845E MAX and i lost it`s manual, and i have recently disconnected it`s LEDs and the onboard power switch wire, and i cannot remember the way they were, so the motherboard doesnt...
Hai,
There is a Small Written word will be there on a mother board where you have removed the wires please check that and connect it ok it'l work.
Jan 08, 2009 | Computers & Internet
Connection of wiring to board
6a98a1a.jpg For the usb connectors you can follow the diagram above:
For the rest of the connectors I need to know the model number of your motherboard
Nov 23, 2008 | Computers & Internet
Reset and power switch connection on motherboard
find the make and model of the motherboard and download the user manual, the power connection wiring schematics wiil be in the manual
Nov 14, 2008 | E-Machines eMachines T3830 PC Desktop
Emachines 420 audio connections
u can test them all, nothing bag will happen .... green is usually the output....
Jun 29, 2008 | E-Machines eMachines Desktop PC
This link will take you to the download page first download is bios second is manual
Mar 29, 2008 | VIA Jetway V4MDMP MB AMD SKTA MATX/ KM400/...
IBM NetVista A30p PC Desktop Logo
104 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
