Question about Wesco Manufacturing Exercise & Fitness
Making noise My elypitcal is making a screeching sound when using it.
    President:
  • 832 Answers
You may have dry bushing , you may have some help you locate the noise in the moving joints( sounds like my elbows sometimes) and you may have to take the side panels off if not then use light machine used in sewing machine apply to moving parts and may quiet it down. If not then you may have to replace damaged mechanical parts. if not too expensive.
Posted on May 14, 2010
Making screeching sound
is it a loose fan belt this will make a scretching noise thats the cheapest thing expensive things if its a manuel could be a thrust bearing on the gear box or worse still an imput shaft bearing on gear box but i think it will be just the fan belt screeching
Nov 03, 2013 | Mercedes-Benz Cars & Trucks
2006 Chrysler sebring High Pitch Noise Screeching Sound
The belt is slipping or the compressor and/or clutch is bad.
If the compressor won't turn freely with the engine off, it may be locked up which will make the belt screech.
Jun 27, 2012 | 2006 Chrysler Sebring 2.7
My holmes air purifier makes a screeching sound
If you can access the fan, spray lubricant onto the shaft as close to the fan body as possible. It will work it's way into the bearing
Apr 14, 2012 | Holmes Products Air Purifiers
My 500gb wd "my book" is making weird noises and wont show up
The whirring noise is the heads trying to read hard drive and then the weird rubbing screech sound and not showing up in your pc. sounds like the drive is dead.
Jul 14, 2010 | Western Digital My Book Essential 500GB...
1993 nissan altima what could be causing a screeching
It probably is a belt. You should look under the hood and check for a loose belt. Tighten as necessary. You should not be able to deflect the belt more than 1/2" in the center of the span of the belt.
Brakes will also make a screeching noise when they are worn out. This noise will also go away when you stop (of course). The sound is quite different than the belt sound.
Jan 31, 2010 | 1993 Nissan Altima
A screeching sound during agitation cycle only.
sounds like a bad clutch. check the transmission out for ware and inspect the clutch as well. make sure the brake is not dragging as well.
May 22, 2009 | Maytag Washing Machines
Dryer makes screeching noise runs for awhile then shuts off.
The 1,5 year new dryer makes a terrible screaching noise when it has a load of clothes in it. It still dries fine, no problem with the heating element. No noise without clothes, only when it has a load.
Nov 23, 2008 | Dryers
Screeching noise
right click on the speaker icon in your taskbar, select Open Volume Control. If you do not see the Microphone control select options>properties and select it from the list of check boxes. Press OK. Check the mute box for your microphone.
Jan 04, 2008 | Lenovo ThinkPad X60 Tablet PC
Exercise & Fitness Logo
135 people viewed this question
Top Wesco Manufacturing Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you a Wesco Manufacturing Exercise and Fitnes Expert? Answer questions, earn points and help others
