Question about Bissell Lift-Off(R) Revolution(R) Turbo Upright Vacuum
Does a bissell power force vacum blow out air
4 Suggested Answers
b0sslady2001
  • 357 Answers
SOURCE: I have a bissell power
Try checking the attachment hose for clogs. It should come completely off of the vacuum with just a few screws. Also, check the little hole underneath the brushroll where the dirt goes in. Hope this helps...
Marci
Posted on Nov 25, 2008
SOURCE: I have the Bissell power force bagless upright
I had shortly after posting the question requesting help and then found the product manual.
Thank you very much though.
Posted on Jul 07, 2009
Gabermrz
  • 31 Answers
SOURCE: My Bissell power force vacum
The best thing to is to find a bissell dealer near you. most vacuums are covered under warranty and no one takes advantage of it instead they go out and spend money on something that could have been free. bissell.com would be the best resourse for that.
Posted on Sep 18, 2011
My lift off revolution vacume shuts off
Hi Kathryn! Your Lift-Off vacuum is equipped with a Thermal Protector that will turn your vacuum off if the motor starts to overheat. This can be caused by dirty filter or reduced air flow.
Here's a quick link to troubleshooting steps to assist you:
http://www.bissell.com/FAQDetail.aspx?id=1405&cid=ccsocial
Mar 03, 2013 | Bissell 37604 Lift-Off Pet Bagless Upright...
Vacum wont power on
Hey Troy, sorry to hear about the no power. Here's a quick link to troubleshooting steps to assist you.
http://www.bissell.com/FAQDetail.aspx?id=1457&cid=ccsocial
Jan 28, 2013 | Bissell PowerForce Helix Bagless Upright...
My Bissell power force vacum cleaner release peddle is broken causing the vacum to fall down my husband found that the attachment inside was broken how can I get a replacement.
Sep 18, 2011 | Bissell 3522 PowerForce Bagged Upright...
My bissell helix is blowing out the dirt it picks up
sounds like you have a blockage in the suction hose --- 9 times out of 10 the blockage is at the area of the machine where the hose kinda bends down to the floor unit. remove the bottom plate ( like you were going to replace the belt ) and look up into the hose and see if it is clogged -- use a wire coat hanger to fish out any debris. also check the main filter and tap out and use a brush to clean as good as you can ( a air compressor works best for this ) .. ( some filters are made to be washed in the dish washer,, check to see if your filter can ba washed ),, after all is clean and clear your vacume should be running like new again.
c...
Feb 02, 2011 | Bissell 82H1 Cleanview Helix Bagless...
My Bissell bagless vacuum does not seem to work anymore. It will start to with a suction and then instead of picking up the dirt, it appears to blow the dirt out almost in a cloud of dust and debris from...
this is caused by a dirty air filter and/or a blocked vacume hose ( most of the time the blockage is at the bend where the hose enters the floor sweeper area ) ---
remove and tap out and brush the filter ( or use a air compressor to blow out filter ).
then with the vacume on its side - remove the bottom plate ( like you were going to change the belt ) and use a coat hanger and clean out the hose between the floor sweeper and where the suction hoes attaches. this will restore your vacume to full operation.
c...
Jan 23, 2011 | Bissell 6595 Lift Off Bagless Upright...
Vacum bags
The vacuum that you have is over 10 years old. You can no longer get the bags directly from Bissell but if you call a authorized service center near you, they may still have bags that will fit your vac. So the answer to your question is yes....they use bags. Good luck!
Aug 03, 2009 | Bissell 3065 Power Partner Vacuum
I have the Bissell power force bagless upright vacume and I took the filters off and cleaned them and don't know where the round filter goes to be able to continue vacuming.
Jul 07, 2009 | Bissell Vacuums
I have a bissell power force vacuum and I just pulled the bag out to change it and when I put it back in it began blowing air out the filter on the side and is no longer sucking
Marci
Nov 25, 2008 | Vacuums
Bissell powerforce bagless upright vacuum 6594-w
Be sure when you put the dirtant dust container in place that it is in properly. I have had this and believe it or not this container has enough room to fit without it seating properly. Take the dust container out and reseat it making sure the bottom is secure and then turn the lock lever in place. Try it again. What happens is you get an air gap which allows some air to flow but the vacum does not function properly.
desmjs
Aug 26, 2007 | Bissell 6594 PowerForce Bagless Upright...
Bissell Lift-Off(R) Revolution(R) Turbo Upright Vacuum Logo
199 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
