Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
How can I pop the top off of my Whirlpool washer to take a sock out of the tub?
    President:
  • 1,430 Answers
There is a video at www.appliancehelponline.com/servicemanual.html this will walk you thru the process.
Posted on May 14, 2010
2 Suggested Answers
  • 30 Answers
SOURCE: water dripping into the tub. Whirlpool top loading washer
You just need to replace the water vale.
The valve is not closing all the way when its off.
Posted on Sep 05, 2009
How do i get behind the tub to clean
If you need to get inside the enclosure to locate a sock; pull the washer away from the wall, expose the back side. With a hex tool or screw driver, remove the screws. Dislodge the back cover and look for the sock. The edges are SHARP, be aware of that fact. As a rule a sock is rarely the problem.
Mar 25, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool 7mwt9601ww0 top load washer dont open the drain valve
If the tub is full of water you need to empty it. A shop vac with the paper filter removed works good. The drain hose is naturally squishy. Likely there is an object like a sock covering the drain hole in the outer tub. If it's jambed tight enough the back pressure from the pump would collapse the hose. If you remove the hose with water in the tub you will make a huge mess when you remove the sock.
Can't really say more because the mod # you provided isn't correct. Not sure what's wrong, i've tried several combinations but no luck. Perhaps you could recheck it. Make sure it's the model number from the machine.
Feb 05, 2013 | Whirlpool Cabrio WTW6600SBT Top Load...
Will not spin
The drain line is probably clogged. Maybe that a sock or other piece of clothing get between the clothes tub and the outer tub that holds the water. In this case it may then get into the drain hose that's attached to the pump.Remove the hoses from the pump and pull the item out. In case it clean there, check the outer tub port- open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then,try to remove the clothing through the port.
Jul 10, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Front load duet washer is spewing water out of soap dispenser.
The water flow is restricted into the tub by an obstruction ie sock, lint.
Take the top off and the drawer out. The black hose underneath the dispenser that leads to the tub has something caught at the end. Pull the hose off where it enters the tub and examine, you will find the blockage there.
Mar 12, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Spins sometimes and when it does it slow
replace the transmission or may be a sock stuck between the inner tub and outer tub
Mar 01, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Water over flowing in soap dispencer Whirlpool sport duet washer
A sock was in between the two tubs blocking the water going tnto the main tub. This caused the water to backup and overflow in the soap dispencer..and all over the floor I then put my hand in between the two tubs and pulled the sock out. Thanks to the expert group for giving me this solution.
Mar 20, 2009 | Kenmore Elite 45986 Front Load Washer
Sock stuck in outer tub whirlpool cabrio
youll need to "pop" the main top.. then unsnap the outer ring that cvers the outer tub. if you look at the center of "agitator/ or bump plate depending on model" theres a small cap that will come of fand reveal a 7/16 screw remove the screw, and then oyull be able to lift the entire inner basket right out to retrieve any debris.
Feb 14, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Cabrio top load flashing F51
Was a far easier fix for me than all this RPS sensor hunting. For my Maytag's F51 error, there were socks lodged between the inner and outer tubs, causing too much friction on the motor. This led to the computer reading poor performance of the motor. Please consider trying this easy fix before calling out service personnel or replacing circuitry!!! I spent hours under the machine messing with the motor and circuitry until I looked up at the translucent tub and saw stray laundry stuck where it shouldn't be.
* Open the lid. Turn the bottom agitator by hand. Give it a good push. It should continue rolling on for several turns. If not, there is laundry stuck between the tubs causing friction.
1.) Pry open the metal case lid. Take two flat head screwdrivers and wedge them in the crack about 6 inches from the left corner, and use them as levers to pop the metal lid, then the right corner. Lift up the metal case lid and lean it against the wall.
2.) Take off the plastic ring that bridges the gap between the inner and outer tubs. There are many little catches all around the perimeter of the outer tub that hold on this plastic ring. Find those catches and put outward and upward pressure on those to release the catches.
3.) Look down in the gap between the inner and outer tubs for stray laundry. I used a retrieval tool (Lowes 403255) below to grab the socks. There were especially several socks in the back right corner near the pump inlet. Run the drain and spin cycle and look again. There were more strays hiding that I nabbed the second time!
4.) Snap the inner cover on by lining up all those catches and seating them. Snap the big metal lid back on by aligning and giving a good downward thump. Run the machine and be the hero, and don't be too mean to your wife about tossing those socks down in the crevices. Half hour and $3 for the retrieval tool is far better than all that RPS mess.
Dec 15, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
101 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
