Question about Samsung Computers & Internet
I have a 27" P2770H monitor that was working, now won't turn on.
I have a 27" Samsung model P2770H that blinked itself off and now will not turn back on. It did this once before and I fiddled with all the connections which did not affect it. Then, it just turned on again.
Fix-4U
  • 293 Answers
SOURCE: Monitor goes black and won't come back
Hi! Trish,
It's seems your Acer monitor backlight inverter are burnt out. Need to replaced a new inverter. Since is a company monitor asked your boss to get you a new one.;) Hehehe...
Posted on Oct 04, 2008
SOURCE: Brightness automatically going low when the brightness is at 100
hello, please make sure the magicbrite option is not set to "dynamic contrast" as this will change the contrast levels by itself, change the settings by pressing the down arrow touch key on the monitor, change it to any other setting, game mode is blinding on my one (when the monitor works, but thats another story!!!) good luck with samsung customer care centre 0870SAMSUNG (uk)
Posted on Apr 09, 2009
SOURCE: Monitor goes blank after 3 seconds -Samsung SyncMaster 920NW
hello i have the same problem, there are 4 lamps (bulbs) inside the monitor when some of them falls the system turn off, cheks and good look
Posted on Oct 27, 2009
lserni
  • 466 Answers
SOURCE: MY SAMSUNG SYNCMASTER MONITOR SCREEN DOES NOT COME
The cable connecting to the PC might be loose, or the part entering the monitor could be.
Try turning the monitor on, and after a few seconds, turn on the computer. You should be able to see the BIOS POST screen text flashing by. If you can't, there is something wrong in your hardware settings.
If you can, however, that's the OS resolution set too high: the monitor shuts down to protect itself. Boot in safe mode by pressing the F8 key immediately after powering up, then lower the video resolution in Control Panel display settings to something safe - 1024 x 768 usually does the trick. At that point you can reboot in normal mode and raise the resolution again to the maximum supported by the monitor (check the manual for that).
Posted on Oct 31, 2009
SOURCE: monitor just turns itself off after 2 sec.
disconnect all the cables except the power cable and then turn the monitor on you would see a test screen if it still happens your monitor is faulty and better buy a new one as repairing is usually expensive .
Posted on Apr 17, 2010
Just shut off and now no power going to it., unplugged and try powering it up with button on tv not remote and still nothing.
TV Appears To Turn Off By Itself
support-us.samsung.com/.../pop_troubleshooting_fr...
Samsung ElectronicsMar 12, 2013 - There are four cases in which your TV either turns itself off or appears ... If you are using the TV as a monitor and the Stand-by light only blinks ...
Easiest TV repair - How to Fix Power [TV turns off, freezes ...
? 6:44
https://www.youtube.com/watch?v=OKklZpTGBGU
Apr 27, 2014 - Uploaded by Keith Fox
I just watch your video my tv won't stay on it keeps turning off I have a ... My Samsung 55" Smart tv suddenly turned off and won't come back on.
SAMSUNG TV REPAIR- TURNS OFF RANDOMLY - YouTube
? 9:24
https://www.youtube.com/watch?v=7Rj22VNhKXg
Jun 25, 2012 - Uploaded by Tampatec
EASY HOW TO FIX SAMSUNG TV- TURNS OFF RANDOMLY Clicking ... Samsung PN64 just started randomly shutting off and on usually with ...
Samsung Smart TV turning off - Forums - CNET
Jan 05, 2016 | Televison & Video
How do I turn off the Samsung sync-master p2050 monitor?
If it doesn't turn off by holding the power button down for 10 seconds, then it cannot be turned off by the power button alone, like most modern lcd monitors. Most modern monitors goes into standby mode. To completely cut power, you must unplug the power cable.
I've enclosed a link to the install manual for reference.
Samsung SyncMaster P2050 User Manual Page 7
Nov 24, 2014 | Samsung Computers & Internet
P2770h monitor flickers. progressed into the monitor shutting down after a few minutes. the monitor power on light flashes in a slow dim.
Is this happening while your are playing games or you are doing a specific task? If not try to change your connectivity cable (HDMI or DVI)
Aug 28, 2013 | Samsung P2770H SyncMaster Widescreen LCD...
Samsung LCD S27B350H blinks during 45 minutes after power on
The backlight is failing, or you have some other power supply problem
Sep 21, 2012 | Samsung S27B350H - SyncMaster S27B350H -...
Samsung T220hd won't turn back on from standby
Power up issues on the T220HD monitor are caused by a failure of the capacitors on the IP-49135b power supply board that this unit uses. The repair is easy, you just need to replace the 7 failed capacitors and the unit should be as good as new. Here is a link to some information showing what needs to be replaced to repair the power supply board.
http://www.ccl-la.com/catalog/product_info.php?cPath=21_33_68&products_id=217
I hope this helps.
Nov 21, 2011 | Samsung T220HD LCD Monitor
Samsung 56" Model HL56A650C1FXZA will
Mine is doing the same... anyone find a solution?
Jul 05, 2011 | Samsung HL56A650 56 in. TV
I HAVE A LCD TV MONITOR, MODEL P2770HD, AND I CAN NOT FIND HOW TO REMOVE STAND FROM TV. SOMEBODY PLEASE TELL ME OR SHOW ME. RON
bobhifi_23.jpgIn the area marked by the yellow line you will find four black screws.Keep the monitor on the floor & remove the screws. now keep both your toes on the base stand and pull up the monitor. If you do not want to stamp on the base ask somebody else to hold it down while you pull up the monitor. Make sure you do not apply any pressure on the front screen. Hold the edges of the monitor
Mar 28, 2011 | Samsung P2770H 27 in LCD TV
Samsung 913N Monitor went out after a power outage.
try a known good monitor on the PC, is the light blinking green or orange?
www.aa1consuling.com
Jul 24, 2009 | Samsung 226BW Monitor
Samsung syncmaster 711p power issue
Its a general fault however all these units are under a 3 year warrantee the dates printed on the back, just call 08706010309 speak to a service engineer and they will arrange a swap out within 5 working days, no need to a receipt as they can tell the units age from the serial. the replacement will be under the same 3 years cover in my case it was for another 6 months
Nov 24, 2007 | Samsung SyncMaster 931B 19" LCD Monitor
Computers & Internet Logo
127 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
