Question about Dell Inspiron E1505 Notebook
Dell Inspiron E1505 will power off after 3 seconds
Dell Inspiron E1505 will power on then off after 3 seconds. The CPU fan does not turn on either. The similar response to fix by running a virus scan has NOTHING to do with this problem. Just need to narrow it down to the CPU, the CPU fan or worst cast the mother board. Thanks.
Any real helpful hints ??
  • 3,940 Answers
If the system will not run long enough to run diagsnostics, I'd replace the heatsink and the fan
Posted on May 14, 2010
    Problem Solver:
  • 12 Answers
Could be a power issue. try taking out battery and power on system using the ac adapter only. if you have another battery and ac adapter that you can try, better. If none, need to replace motherboard. include battery and ac adapter to be sure.
Posted on May 15, 2010
My Del Latitude E6400 turns on and the fan starts but then turns off after 3 seconds; afterwards the cap lock indicator blinks 22 times. Any suggestions?
The flashing CPAS lock is an indication of faulty system memory, that means the RAM module is faulty and needs to be replaced.
Hope this helps.
Jul 10, 2011 | Dell Inspiron E1505 Notebook
Dell 1505 fan runs screan blank has two flashing lights
Hi frase809,
The easiest way to fix this problem is to perform a power drain. Please follow the instructions below.
1. Turn off the system completely.
2. Unplug the AC adapter from the power outlet.
3. Remove the battery from the unit.
4. Now, press and hold down the power button for about 15-20 seconds.
5. Put back the battery in and plug the AC adapter.
6. Reboot and observe the system.
Hope it helps.
Thank you for using FixYa.
Feb 05, 2011 | Dell Inspiron E1505 Notebook
Dell inspiron e1505 powers on but nothing happens. The screen is black
You can try the following steps:
1. Unplug the power from the laptop and remove the battery then press the power button of the laptop for 15 seconds
2. Put the battery back in, turn on the laptop without plugging the power to the laptop (If this didn't resolve the issue)
3. Remove the battery and press the power button of the laptop for 15 seconds, after that, plug the power cord and turn on the laptop (if this didn't resolve the issue)
4. Remove the power cord and press the power button of the laptop for 15 seconds, disconnect the Hard drive and turn on the laptop (If this didn't resolve the issue) reconnec the hard drive
5. Remove the Optical Drive and turn on the laptop (If this didn't resolve the issue) reconnect the optical drive
6. Remove the memory chip, if you have 2 memory chips installed in the 2 memory slots (remove both of them) now test each one of the memory to each slots turning on the laptop. (If this didn't resolve the issue) Put the memory chip back in
7. Reseat the CPU and try to make sure that it's installed properly. Turn on the laptop and test if it's gonna work (If this didn't resolve the issue)
8. Reseat the power cords coming from the power supply of the laptop and test the laptop. (If this didn't resolve the issue)
9. Disconnect everything and just leave the CPU installed and turn on the laptop.
10. If all else fails, there's a big possibility that the problem may be with the power supply or the motherboard of the laptop.
(Note: you may try to clean your computer if there is a large amount of dust. You may try to remove the CMOS battery)
regards,
sl4x
Feb 14, 2010 | Dell Inspiron E1505 Notebook
PROBLEM: THE COMPUTOR SHUTS OFF A FEW MINUTES AFTER THE ADAPTER CORD IS UNPLUGED. BATTERY IS NEW AND READS 75 TO 1OO% CHARGED. CPU FAN IS WORKING. WILL NOT TURN BACK ON UNLEES ADAPTER CORD IS PLUGGED BACK...
Activate low power usage in Bios and also check that the power setting iis adjusted so that PC doesnt "shut down when power is low" this can be found by rightclicking on the desktop,choosing properties then power ...
Jan 27, 2010 | Dell Inspiron™ E1505 PC Notebook
Where can i get a schematic for a dell inspiron e1505 laptop motherboard? It was working fine on battery then I plugged in an ac power adapter and now only the 3 lights come on for about 2 seconds then...
ARrrghhh finding clear and detailed schematics on parts today can be a real pain in the south-forty -- luckily, i know a site where you can find what you are looking for quickly.
http://www.user-guides.co.uk/cddownload/Dell/DellInspiron/Dell-Inspiron-E1505-Service-Manual-Remove-Upgrade-841.html
just follow this link and you will find a resource for COMPLETE and DETAILED schematics and more.
Hope i was able to FIX YA!!! Please reply with your feedback if this helped or if you need more anwers.
Aug 12, 2009 | Dell Computers & Internet
Dell laptop inspiron e1505 no boot green light comes on for about 5 seconds, plugged into a working monitor and still no screen, reset ram, and I dont hear any fans or hard drive running.
could be a case of overheating.
for starters clean the fans with a mild vaccum...
If this doesn't help, the laptop needs to be opened and cleaned up internally, also apply fresh heat release compund to the processor.
That will solve it.
Don't forget to rate this answer if it helps
Jul 21, 2009 | Dell Inspiron E1505 Notebook
DELL LAPTOP INSPIRON 6400 MY LAPTOP BATTERY IS SHOWING STATUS ( UNKNOWN ) ON WINDOWS & ON BIOS IT SAYSS BATTERY NOT INSTALLED
Here are my recommendations for this issue:
1. Reseat the battery.
2. Remove All External Components
3. Check the battery connectors on the battery and the system. Examine the connector on the battery and the system. Make sure that there is no physical damage and that it is clear of debris.
4. Remove All External Components
5. Try a known-good battery in the system, if available.
Jun 09, 2009 | Dell Inspiron 6400 Notebook
Dell Inspiron E1505 will not power up - Battery or A/C Power
If you're not ready to take it to a repair shop, there are a few things you can look for yourself. If the power blinks for a quick second before cutting out, which means you most likely have a short. This could be as simple as a faulty power cord, so try moving the cord where it takes the most movement, to see if you can get prolonged power by holding the cord in certain ways (temporarily making the worn wire inside make contact)
If that does nothing, take a look at the mainboard itself. Look for any darkened or discoloured areas, or melted/damaged resistors etc.
May 08, 2009 | Dell Inspiron E1505 Notebook
Dell Inspiron E1505 Will Not Turn on
Hi there.
Try cleaning the system memory and slots with a soft dry clean painbrush and re-seating it.
Also make sure the air vents and fan area is free of dust.
Good luck and thanks for using FixYa!!
Mar 23, 2009 | Dell Latitude D600 Notebook
Dell Inspiron E1505 Notebook Logo
392 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
