Question about D-Link ADSL2/2+ Modem/Wireless Router 4-Port Switch, 802.11g, QoS (DSL-2640B)
I lost my dsl password n i cant find the installation cd
I have forgot my windows password and cant get on my laptop
Forgot Windows password? You can create a password reset CD/DVD or USB flash drive to reset the password, i have created a password reset USB with the tool Windows Password Breaker and reset my administrator password successfully.
Feb 09, 2012 | Computers & Internet
I forgot my password i cant lost the pic of my familly help
You can reset a lost or forgot Windows password with 4 methods below:
1. Another valid administrator account which can normally log on.
2. A password reset disk or a repair disc.
3. Third-party software to create a bootable password reset CD/DVD or USB, like Windows Password Breaker.
4. Re-install. Will lose data.
Jan 13, 2011 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
We bought the AT&T Motorola DSL Modem today, and we're trying to connect to wireless on a laptop and the connection isn't showing up. How do we fix this ?
  1. Ensure that your AT&T DSL self-installation kit is complete. At minimum, it should contain a DSL modem, an AC adapter, an Ethernet cable, a telephone cable, several telephone filters and an installation CD.
  2. Install the telephone filters on each telephone jack that you have a phone plugged into. Install a dual phone adapter on the jack closest to your computer if you have an answering or fax machine, telephone or analog modem in the same room. Then plug your telephone equipment into the filters. Connect the telephone cable that was provided with your installation kit into an unfiltered telephone jack.
  3. Insert the installation CD into your CD-ROM drive. If the installation program does not start automatically, click Start > Run > and browse to the CD-ROM drive directory to find the installation file.
  4. Connect the telephone cable that is attached to the unfiltered wall jack to the back of the DSL modem. Connect the Ethernet cable to the back of the modem and to the Ethernet network interface card port on the back of your computer. Connect the AC adapter to the back of the modem and plug it into an electrical outlet. Power the modem on.
  5. Check the modem lights. There should be at least two lights lit. These will have labels such as "Power" and "Ethernet." However, these labels may differ depending on the model of modem you received in your installation kit.
  6. Complete the software installation. Enter your chosen username and password when prompted. Check your modem to see if the light labeled "DSL" or "Internet" is lit. Open a web browser window to see if your DSL service has been successfully installed.
Oct 25, 2010 | AT&T High Speed DSL Modem
Belkin f5d 7230-4 How can Change Password for Homepage Login?
As you are unable to access the web interface of the device your only option is to perform a factory reset of the router using the reset switch built into it as per link below:-
http://en-us-support.belkin.com/app/answers/detail/a_id/48/kw/password%20f5d/r_id/166
Nov 29, 2009 | Gateway Belkin F5D7230-4 802.11g Wireless...
I lost my linsksys install cd (model WRT54G)
contact the manufacturers website you will find all drivers and application related to it
Sep 03, 2009 | Linksys EtherFast Cable/DSL Router
No activity on my new speedstream 4200
Ethernet and DSL lights are indicating you have ADSL available on your line, and that you have computers connected to the router.
What has probably happened is that Optus did not set up the new router with your username and password. Go to thw following website for details on how to setup the modem.
http://help.optuszoo.com.au/help/dsl/connected/windows/optus_modems/speedstream_4200
Manual Modem Settings The Optus DSL Broadband self-installation CD configures all the necessary settings for your DSL Broadband service. You do not need to manually configure your modem if you have run the self-installation CD. While the following information is provided for your reference, using the self-installation CD is the recommended method for configuring your modem.
The Siemens SpeedStream 4200 ADSL modem can use either USB or Ethernet to connect to your computer.
  • If you are connecting via USB you will need to run the self-installation CD to install the USB driver before you connect your modem. The Siemens SpeedStream 4200 ADSL modem supplied by Optus has been customised for the Optus DSL Broadband service. Only the USB driver supplied on the self-installation CD will work with the Optus service. If you do not have the self-installation CD, you can download the latest drivers from the Siemens website.
  • If you are connecting via Ethernet it is possible to manually configure your modem without the self-installation CD. Only a web browser is required.
After connecting your modem there are two key steps to manually configure your modem for the Optus DSL Broadband service:
  • PC settings - Configure your computer's Ethernet network interface.
  • Configure Your Modem - Set the password in your modem's configuration pages.
top
PC Settings Step by step instructions are provided for each of the supported Windows operating systems:
  • Windows 98/Me
  • Windows 2000
  • Windows XP
  • Windows Vista
top
Configure Your Modem To configure your modem settings you must now access the configuration manager using your web browser. This is done by entering the IP address in the address bar of the browser window as follows:
Note: If you are updating the password in your modem, please complete steps 1 to 3 only.
Step 1 of 5
  • Enter http://10.1.1.1 (Default IP address of the Optus Supplied Siemens SpeedStream 4200) to access the modem Configuration software. You may wish to add this page to your Favorites for easy access later.
  • The following modem System Summary screen will appear.
ss4200_home_disconnected.gif Step 2 of 5
  • Click on the word Setup in the green menu of options on the left side of the web page. An expanded set of options will be displayed.
  • Click PPP in the list of options that appeared below the word Setup.
  • The ISP Password page will appear:
  • Replace the default username (john_citizen@optusnet.com.au) with the username provided for you by Optus DSL Broadband.
  • Replace the default password with the password provided by Optus DSL Broadband in the Password field.
  • Note: You will find your Optus DSL Broadband username and password on the letter you received with your self-installation kit.
  • Save these details by clicking the Save Settings button.
Step 3 of 5
  • The next screen will ask you to disconnect and reconnect to the Optus DSL Broadband service.
  • Click the link to return to the System Summary page.
  • Click the Disconnect button to disconnect the modem from the Optus DSL Broadband service. The text on the button will change to Connect.
  • Click Connect to reconnect the modem to the Optus DSL Broadband service.
Step 4 of 5
  • Click the word Mode in the green menu of options on the left side of the web page.
  • Confirm that Optus Bridge is the selected operation mode.
  • If Optus Bridge is not selected click the radio button next to Optus Bridge to select it.
  • Click the Apply button.
  • Click the Reboot button to restart the modem using your saved settings.
  • After about a minute the modem will return to an operational state and connect to the Optus DSL Broadband service.
ss4200_reboot_3.gif Once the modem has rebooted and the ADSL connection has been successfully established the DSL LED indicator will light steady green.
Your modem is now connected to the Optus DSL Broadband service.
Jul 25, 2009 | Siemens SpeedStream 4200 (13A4200001)...
Install 2wire 1701hg without installation CD
1. pull up browser(ie internet explorer)
2. type 192.168.1.254/setup or http://homeportal/setup in the address field. (click on i forgot my password if you forget it. then if you can't figure out the pw with the hint provided then go click on " i still forgot my password". you can then reset the system password)
3. setup your 2wire 1701 page, double check if key codes are there. it should be 522P-22P4-6262-22AT-F2NV
4. In time zone page, just choose the one then click next.
5. setup connection info page, just make sure the username is your primary email address with your ISP and also the correct password. fill out the username and password and confirm password fields ONLY then click next. And you're DONE!
you just have to wait till it successfully establish a connection.
if you're still having problem after doing that maybe twice or more then i suggest giving your ISP a call. they can also send you the 2wire cd if your ISP supports 2wire modem. AT&T does.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Dec 06, 2008 | 2wire (1000-100052-000) 802.11g/b Wireless...
Lost installation cd
The installation CD is actually just a guide. It does not install any software on the computer. You can configure/reconfigure the router even without the installation CD.
If you need help reconfiguring the router, please let me know.
Please provide also the following info:
1. Who is your Internet Service Prodiver?
2. What is the model/brand of your modem?
Aug 10, 2008 | Linksys Wireless-G WRT54GS Router...
Speedstresm 5100 modem
check for physical setup between your modem and the wall jack
if u don know how exactly the physical setup is pls contact your isp for help for u to run through the steps
Jan 29, 2008 | Efficient Networks SpeedStream 5100 Modem
D-Link ADSL2/2+ Modem/Wireless Router 4-Port Switch, 802.11g, QoS (DSL-2640B) Logo
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
