Question about Krups XP7225 Espresso Machine
Error code 3 on our Krups
I have krups xp7220 and now it doing self test and after
that appere on the screen error code 3
what is worng with the machine
can i solve it by myself?
thanks
Drummernick
  • 440 Answers
SOURCE: how to use krups espresso machine
http://www.electrobest.com/krupinman.html
hers ther manauals on these thx nick rate me as fix ya thx
Posted on Feb 07, 2008
SOURCE: i need a manual for krups xp 7240, krups xp 7200, krups xp 7230
I have the manual, send an email to me at inouside@hotmail.com and I will reply to you with the manual in pdf format.
Posted on May 14, 2009
  • 5 Answers
SOURCE: Error Code 9 on a Krups XP7240 Expresso machine
After I changed piston sealing I get the same error 09. It was caused by missing connection to the thermoblock temperature sensor. In my case both connectors for thermocouple were cracked. They are located directly on the body of thermoblock, below two fuses, covered by rubber housing. After I solder them again on the position error 09 disappeared. Unfortunately it is necessary to open at least front panel of the machine. Moreover I tink that there is also important to save polarity of those two cables.
Posted on Aug 07, 2009
SOURCE: krups fnf2: service 8, what does it mean?
On mine, the coffee dispenser had become stuck or clogged with ground coffee. cleaning this and giving it a bit of assistance on the next power up solved the problem. you will need to remove the two TX-15 torx screws at the front under the coffee flap/lid and the water flap/lid. there are also four screws down the back which dont have any screw driver slots in them. you will need a pair of vice grips or similar pliers to undo them. The top then lifts off and you can see down the coffee dispenser enough to clean it out. If you intend to test it with the lid off you will need to tape a magnet on the gray reed switch at the top (to simulate the ground coffee lid being closed). Obviously if you remove the two last screws at the bottom back you can easily remove the sides however in my case this wasn't necessary.
Posted on Mar 08, 2010
What is error code 6 on krups ea850b10 means?
Error 6 means machine thinks it has a leak in one or more of the following
1) Distributor
2) Thermoblock
3) Pump valve
4) Pipe leakage
Repair will involve specialised tools and parts, not really the sort of job to attempt yourself. Contact Krups and get from them contact information for your local service agent.
Aug 03, 2015 | Krups Small Appliances Espresso Machine
Error code 3 on krup xp7220
Direct from repair manual for your model, these are the possibilities
- Fault in the actuator high
position switch (mechanical or
electrical)
- Distributor switch fault
- Faulty electronic boards
connection
- Actuator switch short-circuited
Dec 08, 2013 | Krups XP Coffee Makers & Espresso Machines
Krups xp7220 technical error 05
It cannot be an FNF2 and also an XP7220, they are entirely different machines.
Apr 15, 2013 | Krups Orchestro Dialog FNF2 Espresso...
I need a service manual for KRUPS xp7220
Hi Moti,
did you fix the problem?
where did you gave it to fix in our country?
Sep 25, 2012 | Krups Compact Fully Automatic Espresso...
I have un error code 3 that appear after self test process
the ram not detected in the upper position., if give me photo i can help you. Good luck
Joseph
Aug 18, 2012 | Krups XP Coffee Makers & Espresso Machines
I have a Krups XP7220.The waters commes out cold under the appliance. Is the boiler as the guy from service says ? Thanks Ovidiu
When you brew a cup is the coffee cold? Or is just the excess water that come out into the water tray cold?
Sep 20, 2010 | Krups Small Appliances Espresso Machine
I have a problem with my Krups XP7240, it is
You can just removed the water tank filter (the cylinder inside the water tank) and washed it up. (Actually the filter should probably be replaced). Fix it back in the water tank and tide it safety upon the exit ring.
Don't forget to unplug the machine BEFORE doing this.
Next, restart the machine and let it perform the automatic self testing.
May 10, 2010 | Krups Small Appliances Espresso Machine
Error code 07 on my Krups XP 7220 coffee machine
Error code 07 on my Krups XP 7220 coffee machine what to do? Nick
Oct 26, 2009 | Krups Small Appliances Espresso Machine
Jun 06, 2009 | Krups XP4030 Espresso Machine
Krups XP-7220 Error code 01
Go to krupsusa.com and click on "instructions" they should have the manual to download.
Jan 02, 2009 | Krups Orchestro Dialog FNF2 Espresso...
Krups XP7225 Espresso Machine Logo
756 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
cyfred
Level 1 Expert
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
