Hi i have a kdfe50a10 i just replace the lamp and i still have the red standby light
  • jluckett54 May 14, 2010
    excellent thats why your expert thank you now in can watch the play offs in hd
  • 10,594 Answers
Let me know does standby red light blinks in your Sony KDF-E50A10
If yes, how many times it blinks? There would be 3 seconds big pause between blinks so count pause to pause please.
If standby light blinks 3 times, than check lamp cover as it has not been fixed properly after lamp replacement of lamp in tv. make sure lamp cover is in its position securely.
Thanks.
Posted on May 14, 2010
    standby flashes 3 quick times then stop for 3 to 4 sec then starts flashing again
  • Shahid Electronics
    Shahid Electronics May 14, 2010
    Standby light flashing 3 times.
    This is an error code that shows that lamp cover is not placed back in its position after lamp replacement as it was first thing that was removed to pull out old lamp from tv.
    Make sure lamp cover is fixed back in its space because it engages safety switch inside that sends signal to system control chip that all is OK.
Sony Kdf-e50a10 keeps shutting off and on.......Power/standby blinks during this time.....No Lamp Light
The blinking light is typical of a failed lamp and they last commonly between 2-5 years tops in these sets. You should replace the lamp. The link below is to the lamp for your set.
Replacement Lamp: Sony KDF E50A10 KDFE50A10 Lamp with Housing XL2400
Jan 24, 2014 | Sony Televison & Video
I have replaced the lamp block and now the power stand by red light is going on and of (this was a new lamp block). Do I need to reset some how?
If standby red light is blinking 3 times after three second pause then check lamp cover that has no been fixed in its place correctly, it is first thing that you removed from tv cabinet to replace lamp, make sure lamp cover is back in place properly and tight.
If standby red light is blinking more or less then 3 times, let me know to diagnose problem.
Thanks.
Sep 04, 2010 | Sony KDF-E42A10 42 in. LCD Television
Powers off with a blinking standby light for 45 blinks
Yes, its clear symptoms of weak lamp that is going to end of its working life, soon tv will show you lamp light.
Replace lamp to solve the issue, lamp replacement procedure is easy and written in user manual.
Please buy Sony original lamp for good picture in tv.
Thanks.
May 25, 2010 | Sony KDFE50A10 50" HDTV
Tv wont power up Standby light keeps flashing.
First step in any Sony LCD projector repair is bulb or lamp replacement. Fixes 95% of problems.
Taking apart and trying to measure things without a known good bulb is a waste of time and effort.
easyab
ConvergenceRepair.com
Feb 26, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
My sony kdfe50a10 keeps going into standby then
Mine would power up. It would then shut down with green light flashing and then repeat cycle. Lamp indicator was off. However, I replaced the lamp anyway and cleaned out the housing. It now works great. I got the lamp directly from Sony. Easy fix.
Sep 24, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony kdfe50a10 blinking green light
did you find out the answer to this problem as we have the exact same issue? thanks
Sep 22, 2009 | Sony (XL-2400) Projector Lamp for...
Tv went off while watching a program power standby red light blinks 6 times then pauses then repeats tried unplugging unit waiting a few minutes then replugged same results nothing. can anyone help me ?...
Here's an excerpt from the Sony Manual online. And the link - http://esupport.sony.com/US/perl/webtree.pl?template=EN&mdl=KDF55XS955&content_id=68&category_id=11&problem_id=52
The POWER/STANDBY (red) indicator flashes three times
If your power/standby indicator is flashing in a pattern of three flashes, this may indicates that the lamp cover is not attached securely. Follow the directions in the Operating Manual under changing your lamp that related to closing and securing the Lamp Cover. Ensure that the Lamp Cover Door is securely fastened by tightening each screw.
The POWER/STANDBY (red) indicator flashes continously
If your power/standby indicator is flashing continuously, and the lamp cover has been secured, your TV may be in need of service.
The POWER/STANDBY indicator is lit up green (not flashing)
A sustained green light indicates your TV is on.
The POWER/STANDBY indicator is lit up red (not flashing)
A sustained red light from your power/standby indicator simply indicates that your TV is in standby mode. This shows you that your TV is ready to be turned on with the remote.
Is it the power light and not the lamp light? If the lamp light is flashing then replace the lamp.
Apr 07, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Televison & Video Logo
109 people viewed this question
Top Televison & Video Experts
