Question about Vestax Pmc 280 DJ Mixer
Headphone channel is broken, outputs fuzzy, needs service
Where do i get my vestax mixer serviced in london
    President:
  • 1,137 Answers
I'd try this company:http://www.wdgreenhill.com/ I had good service from them and I live in Canada. They are in Rochford Essex.
Posted on May 18, 2010
How do I fix my mixer 32fx out put
If the mixer output shuts down as you describe, some part is over heating and once it cools down you can turn it back until it happens again. This will not be user serviceable. Here is the link to Peavey Support who can provide a service center contact and schematics.
peavey com
May 21, 2016 | Peavey 32fx USB 32 Channel Mixer
Dropped mixer about 400 mm from speaker to floorsound comes up to headphones output but not to main mix socket
Open unit. 1. Look for cables knocked off. 2. Using bright light look for circuit board cracks and broken solder. 3. Look for broken pots, especially the main slider. All of these problems are repairable by competent electronics tech.
Jul 20, 2011 | Samson Audio MDR1064 Compact 10 Channel...
I have a midas venice 320 mixer, there is no output on the four auxlilary sends, but i have an output on other outputs and headphones.
You must have aux sends on each individual channel and each AUX MASTER turned up for output and each of those outputs must be going to separate amps.
Apr 12, 2011 | Road Ready Mixer Case for Midas Venice 320...
No sound
There can be any number of reasons for this problem - solve it diagnostically by starting with something that you know is working and work through systematically to the other end.
  1. Test a microphone on a separate amp to make sure it works okay. Check amp and speakers working. Check that all output cables from mixer to amp are working by testing separately.
  2. Plug microphone into a channel on mixer. Also plug in headphones and turn headphone volume control up.
  3. Make sure input sensitivity knob is turned up a bit (say half way) and main output faders (yellow) are up.
  4. Check that channel is turned on (little button just above the channel fader- needs to be pressed down)
  5. press pfl (pre-fade listen) button (next to button to switch channel on)- do you get any sound on main output or headphones or any indicator lights on mixer to show signal is getting that far (eitehr the individual channel metering lights or the main ones in the central section)?
  6. turn off pfl - make sure channel fader (slider) is up - normal position is ) - about 3/4 of way up. Check lights again on individual channel and main output section - any signs?
  7. Is the sub mix button for the channel pressed down - in which case you will need to bring sub mix (red) output faders up as well as main faders.
  8. If you have got signs of signal on the individual channel but not main see if the channel has been routed somewhere odd (like a subgroup of channels).
  9. Plug a working amp and speakers into one of the auxiliary outputs and use the relevant auxiliary send knob (on each channel just above the faders and pfl switches) to pan some signal to that auxiliary out - do you get anything? There is also a headphone socket for listening to the auxiliary channels (with a selector switch /knob to determine which one - make sure it is in the right position) try listening to the auxiliary output with headphones - anything? If yes the problem lies in the main output section.
  10. Check that there is not a jack plug in the insert socket (to route signal through an external effects unit) without a matching return jack being plugged in - if appropriate is relevant effects unit switched on and correctly set up - if unsure remove the insert plug to take it out of the system.
  11. Make sure any mute buttons are not switched in on main outputs.
You can download a full user manual here http://www.allen-heath.com/gl/gl2400
Feb 22, 2011 | Allen & Heath Allen and Heath GL2400-32...
The right output channel on the right side of my pmc 05 pro 4 has very low output. I can hear both right and left output channels in the headphones when I have the cue selected but when I try to monitor...
I assume you swapped thee output leads as well as the inputs which you di mention, to verify you amps and cables...
The Vestax schematic I have is NOT your same model, but the companies often re-use circuitry. In the schematic I have it appears that the two channels go through two levels of NJM2068L op amps.
In these two levels there is both a master gain control. It is important to know whether the gain control varies the output level of the right, even if it is low. Also in this gain control area is a master balance pot which varies the ratio of the left and right and is CAPABLE of taking either channel to near zero output... IF you have that control check it for sure !!! The pot is a dual employing both an A taper and C taper which is a reverse of the A.
The right tool for troubleshooting this is an oscilloscope, but first an inspection looking for board cracks around the output and pot area is in order.
Jan 01, 2011 | Vestax PMC-05PRO IV PMC-05 PRO 4 DJ MIXER
Had m mixer unplugged not in use for about 4 days and when I turned it on line 1 phono1 ans mic1 only output through the right channel.. all the rest of the channels are fine any ideas?
if it was unplugged then not much could go wrong, unless you have small kids around the house, so maybe you should check the panning pots to see if they have been changed.
Feb 10, 2010 | Vestax Pmc 280 DJ Mixer
Left channel out on behinger ub2222fx-pro could use a service manual. Thanks in advance
Behringer only give the manuals to their authorized service agencies I am told.
Mixers are very symetrical and have lots of diagnostic capability from the outputs.
If you headphones work, chances are the moxer biss es are OK which probably focuses the problem on the output drivers.
Use headphones to see what jacks work... Remember that a stereo headphone will only have sound on one side for the mono jacks you test.
If your mains have a dedicated slider, one half of the slider could be bad. Usually you can tell those by a rougness as you slide them.
Feb 07, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
Headphone output distorted on one side. Replacement jack?
studiospares (in london) or radioshack in USA, unscrew and get busy with a soldering iron, its not too hard, only 4 cables.
Jan 22, 2010 | Behringer DJx700 5-Channel Pro DJ Mixer...
Vestax Pmc 280 DJ Mixer Logo
173 people viewed this question
Top Vestax Music Experts
Vito Vacirca Jr.
Are you a Vestax Music Expert? Answer questions, earn points and help others
