Question about Princeton Digital VL1916 19" LCD Monitor
Reset Monitor back to factory spects.
How do you reset to factory, color contrast est. I pushed to many buttons, now it look strange off color
    Scholar:
  • 125 Answers
Menu
Advanced
Factory Recall
Select
Select
(select must be pushed a second time to start the factory recall.
Posted on May 04, 2008
SOURCE:
I have a Viewsonic VE155 monitor and cannot get the contrast and brightness off my screen how do I get it off? it just started happening
Check to see if you can reset the electronics of the monitor to factory defaults. If no reset button contact viewsonic for a hidden code to accomplish same. If no results then your monitor is a sick puppy. Just to make sure plugh in another known working monitor to make sure that it is the monitor and not your computer.
Sep 19, 2017 | ViewSonic Computers & Internet
Screen appearance
Hello ,
You can accomplish this by unpluggin the tv for 4 hours. When you power it back up the internal software will revert to the original factory defaults.
Mar 30, 2008 | Princeton Digital VL1916 19" LCD Monitor
RESET DELL MONITOR E1709WC
Instructions
    • 1 Push the "Menu" button on the front or side of your Dell monitor. The button's icon resembles a miniature monitor. This will open the main monitor setting menu. Push the button again to exit the main menu and open the OSD menu.
    • 2 Push the "Down Arrow" button on the monitor to scroll through the OSD menu. Stop at "Factory Reset." Push the "Menu" button to open the factory reset menu.
    • 3 Push the "Down Arrow" button to select "Position Settings Only" to reset the monitor's horizontal and vertical screen settings. Press the "Menu" button to activate the setting changes.
    • 4 Push the "Down Arrow" button to select "Color Settings Only" to reset the monitor's red, blue and green color settings. Press the "Menu" button to activate the setting changes.
    • 5 Push the "Down Arrow" button to select "All Settings" to restore the monitor to its original factory settings. Press the "Menu" button to activate the setting changes.
    • 6 Push the "Up Arrow" button to select "Exit" to leave the monitor reset menu. Press the "Menu" button to exit the OSD menu. Push the "Menu" button again to exit the main settings menu.
Aug 02, 2012 | Dell Computers & Internet
Color is very washed out, contrast very bad even after adjusting. Very hard to see lines. Basically the screen is all washed out!
You can try going into the display functions using the menu buttons and performing a factory reset. Good luck.
May 26, 2010 | Westinghouse Electric L1916HW 19" Monitor
My monotor its all black but u can
This should be an (LCD) screen. They are the ones that usually have this kind of problem. You will need to take it to have it checked if the problem is the VGA signal cable leading to the monitor. They will check if it is properly connected or has gone bad. It is very unlikely that the screen is bad. When this VGA signal cable goes bad it could result in a totally blank screen.
Sep 13, 2009 | Dell Computers & Internet
Monitor Reset Instructions
it is a setting button problem. pls checked this button.
Aug 31, 2009 | Canon Pixma MP450 All-In-One InkJet...
Monitor Flashes Colors when system powered down
Reset factory settings. Push the selection button (second button from the left at the bottom of the monitor, next to the AUTO button), then go the the Factory Reset by pressing the minus button. Press the selection button again, and when it asks if you want to reset say YES by using the minus button. It's a quick fix!
Dec 20, 2007 | Dell E176FP 17" LCD Monitor
Screen colors washed out
You can RESET the monitor setting externally by clicking adjustment menu button goto RESET press ok. If contrast and birghtness not set properly light will not be properly visible
Dec 10, 2007 | Samsung SyncMaster 940MW 19" LCD Monitor
Not enough contrast \ user mode?
You can reset it back to factory settings with the auto reset button selection or in that menu switch from advanced.
randy329sgi
Oct 15, 2007 | Compaq CV 7500 17" CRT Monitor
Component color turns yellow
when you say color. Do you mean gray scale like what if you turn off the color completely?? Does the picture look B&W? need to know this?
Jul 01, 2006 | Mitsubishi WS-48311 48" Rear Projection...
Open Questions:
SMADAV customer service phone +[-\@;-{+1'8OO;8O3^1O69}] NuMbEr USA .Anita This SMADAV USA phone number [+1:8OO:,:8O31069] is ranked #2 out of 2 because 7,728 SMADAV USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO:,:8O31069 is to reach the SMADAV USA customer service department for problems like Where to buy, Complaint, customer service, Repairs, Returns. As far as we can tell, SMADAV USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. SMADAV USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O31O69 and ways to call or contact SMADAV USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling SMADAV USA Calling SMADAV USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our service call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from SMADAV USA customer service can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with SMADAV USA's customer service department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare SMADAV USA's phone numbers against each other. Contacting SMADAV USA in General While I8OO8O31O69 is SMADAV USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO8O31O69 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact service for you to look at as well. One thing to keep in mind as you try to reach SMADAV USA help by calling them, is that other customers give their customer service at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact SMADAV USA.Anita
Oct 17, 2019 | Best Computers & Internet
PC MATIC customer service phone +[-\@;-{+1'8OO;8O3^1O69}] NuMbEr USA .Anita This PC MATIC USA phone number [+1:8OO:,:8O31069] is ranked #2 out of 2 because 7,728 PC MATIC USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO:,:8O31069 is to reach the PC MATIC USA customer service department for problems like Where to buy, Complaint, customer service, Repairs, Returns. As far as we can tell, PC MATIC USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. PC MATIC USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O31O69 and ways to call or contact PC MATIC USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling PC MATIC USA Calling PC MATIC USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our service call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from PC MATIC USA customer service can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with PC MATIC USA's customer service department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare PC MATIC USA's phone numbers against each other. Contacting PC MATIC USA in General While I8OO8O31O69 is PC MATIC USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO8O31O69 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact service for you to look at as well. One thing to keep in mind as you try to reach PC MATIC USA help by calling them, is that other customers give their customer service at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact PC MATIC USA.Anita
See all Princeton Digital VL1916 19" LCD Monitor Questions
Princeton Digital VL1916 19" LCD Monitor Logo
1,370 people viewed this question
Top Princeton Digital Computers & Internet Experts
Ekse
Eric Rotmil
Eric Rotmil
Sr. Pelo
Sr. Pelo
Are you a Princeton Digital Computer and Internet Expert? Answer questions, earn points and help others
