Question about Dell Latitude D600 Notebook
Just had new hard drive installed.got home it is not working
Only says no rebootable devices found. Options key F1 or F2 this does nothing.
  • 3,940 Answers
Insert you windows CD in the optical drive, then reboot at the Dell screen press F12 and select the optical drive, then you can install Windows to the New drive.
Posted on May 14, 2010
My dell 5125 indicates internal hard disk drive not found. it asked me to reseat the drive...than it indicates no bootable devices- i'm strike F1 to retry to boot and F2 for setup utility....nothing...
Try accessing setup utility and verify there if it still recognizes your hard drive, if not then that means your hard drive had crashed. If you have important files on the drive, you can try to recover it by going to a local service provider and have your files recovered, and of course you have to get a new hard drive for your dell.
Sep 13, 2010 | Computers & Internet
Computer starts up but nothing comes up on the screen
Depending on the type of computer you have, when rebooting keep hitting the F1 key or F2 key or the F10 and when the options come up select the main hard drive (c:\ )and hit enter.should boot up to main drive. If it a Mac, take out battery and plug in power adaptor and hold start up key until machine starts up. once booted plug battery back in.
Sep 05, 2010 | Gigabyte GA-8PE800 PRO Motherboard
My Laptop MODEL COMPAQ M2000. LAPTOP HUNGING PROBLEM . ERROR IS PRESS F1 RESUME & F2 SETUP . PLS. GIVE ME SOLUTION .
Try Pressing F8 while booting to go into Advanced Options Menu. 1) Choose Last known Settings that worked.
2) If that does'nt work, Remove any USB or Other NEW DEVICES that have been added recently. Then press F2 to enter Bios. Go to Boot Order Option and make sure that the #1 Boot Device is your CD/DVD Drive & #2 is your Hard Drive on the list. Then Save/Exit & Reboot.
Jul 22, 2010 | Compaq Computers & Internet
The motherboard is a MSI MS-7184 in a emachine model t6524 and what is happening is when you turn on the computer, it starts and the lights on the keyboard light up and shut off, then it brings you to the...
Hello
Try f2,then let the screen come up.This is your bios settings,dont change anything.
Next hit the esc key,answer yes or y key.Pc should reboot normally.
If this doesnt work hit the f10 key and select your hdd or hard drive in the options,and reboot.
Apr 29, 2010 | eMachines T6524 PC Desktop
Primary Hard Disk Drive Not Found, Fixed Optical drive Not found
Reseat both the Hard Drive and Optical drive and see if they detect. If they do not, then a HDD failure is most likely. The I8000 is quirky in that if the HDD fails, the Optical drive will not work.
If reseating doesn't resolve, Replace the HDD and the optical drive should work. (Controller is a serial design and neither drive will function if the other fails)
Jan 19, 2009 | Dell Inspiron 8000 Notebook
Turn on, after intital screen with setup options the following appears: "SMART Failure Predicted on Hard Disk 4: SAMSUNG HM121HI - (S1) WARNING: Immediately back-up our date ....... Afailure may be...
Have you installed or attached any Software /Device since then.
Please unlug any device attached and then try. Also try tapping F8 key during bootup.
Check BIOS with F2, DEL or ESC key during Bootup.
Best of Luck & Regards Puneet
Oct 05, 2008 | HP Computers & Internet
I've installed a new hard drive and put in more RAM on my Desktop. Now i get this message WHAT DO I DO. The amount of system memory has changed. Primary hard disk drive 1 not found Strike the F1 key to...
Strike F2 to go to the bios to run the setup utility
Don't touch anything , save and reboot
If primary hard disk still not found
reboot press F2 to re-enter the bios
Look for Auto Detect Hard Disks
if the computer shows a hard drive is detected
set the drive to LBA if possible
save and reboot
Az.
Sep 15, 2008 | Computers & Internet
Dimension 3100 Won't Boot
Make sure your HD Cables are all firmly plugged in, and that all drives are starting when you turn on the computer. You can tell with harddrives as they will slightly whine, and have a small, steady vibration to them. If they are all starting, and all cables are fully seated, check in your Setup utility that the drives themselves are Auto-Detect. If none of this fixes your issue, you may have to refer your computer to a computer repair shop.
Hope this helps!
-Backu
Jan 16, 2008 | Dell Dimension 3100 PC Desktop
How to change the boot option in IBM 6578-PBU desktop
I searched for hours for a solution to this. Here it is:
1). Restart your computer, NOT using ctrl - alt - del
2). Press F1 when guided to.
3). When you get into the config menu, select Start Options, then hit enter twice.
There are all the options you need! Cool, huh?
Aug 26, 2007 | IBM NetVista A40 PC Desktop
Dell Latitude D600 Notebook Logo
mukhtar21 shaikh
mukhtar21 shaikh
