Question about Marantz SR4002
My Marantz S4200 began to shut down frequently with a protect feature and now will not power up at all. The red light on the front just blinks contstantly. I tired the reset function but the unit needs to be on to do that. What could be the problem?
  • 1,525 Answers
Hello it sound like the output amp my have blown or there could be a pop capacitor or bulged capacitor
regrads
shaun
Posted on May 15, 2010
Why marantz receiver 2328b sterophinc shut down?
Protective circuits have shut down unit to protect other wiring. Probably a power supply or out put amp issue.
Mar 09, 2015 | Marantz Audio Players & Recorders
How do I reset the protection circuitry on Yamaha RX-A820?
press and hold the 'tone control' and 'info' buttons and press power. This will release the protect. The first thing that show on the display will be the protect code to tell you why it shut down. If it turns right back off, then you most likely have a short in the amp that will need to be repaired.
Jan 25, 2015 | Yamaha Audio Players & Recorders
What can i do to stop the red light blinking for marantz sr5007?
Turn off the power using X.
2 Press X ON/STANDBY while simultaneously pressing PRESET CH + and PRESET
CH -.
3 Once the display starts flashing at intervals of about 1 second, release the two
buttons
Aug 09, 2014 | Marantz SR5007 Home Theater AV Receiver
Red power light blinking on my denon avr 1907, tried reset procedure, no speakers hooked up now and it still goes from green light to blinking red light and shuts off...Any clues?
This is a protection mode. The receiver protection circuit detects an internal problem like missing power supply voltage or blown channel and shuts down the receiver. You need to bring the unit to a repair facility.
Sep 26, 2011 | Denon AVR-1907 Receiver
The power light blinks red! it can't turn On!
"If your 8002/7002 goes into protective mode (red power light flashing at two times per second) the receiver will not operate until it is reset. First try the reset procedure on the bottom right corner of page 81 in the manual.
If that doesn't work, press and hold the following three buttons on the front panel until the unit resets:
Pure Direct
7.1 Ch input
Clear
This latter procedure is not in the manual and I can't fathom why, as it can save the inconvenience of a trip to the service center."
Feb 03, 2011 | Marantz SR8002 7.1 Channels Receiver
Bad color then no power on 51'' panasonic cinemavision
Check the power light for blink code--usually if this model shuts down the power light will blink in a sequence--3 blinks a pause and 3 blinks is short protection--usually means a convergence circuit problem.
Let me know what you find--I am here to help.
if this helped you rate this solution as I do this here for free.
SD TECH
Dec 17, 2009 | Panasonic PT-51HX41 51" Rear Projection...
Power shuts off 1 second after tv is turned on
Good Day,
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times.
1 - 2 = no error detected
2 - 1 = X-ray protect (high voltage or beam current)
2 - 2 = Short protect (short protect monitors low voltage supplies)
2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection)
2 - 4 = Vertical protect (usually loss of vertical from the source)
1. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR LEAKY C9A60 470 PF 1000 V PART # 154P400030, PARALLEL TO D9A57 ON THE POWER PCB (NOT SHOWN IN THE SCHEMATIC).
2. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR OPEN FUSES F9A04 AND F9A05 PART # 283P043090 ON THE +24 AND -24 VOLT LINES. IF THE FUSES ARE OPEN THE CONVERGENCE OUTPUT CIRCUIT WOULD BE SUSPECT.
3. SELF-DIAGNOSIS INDICATES SHORT PROTECT. CHECK FOR A SHORTED IC4B01 PART # 270P261020 (VERTICAL OUTPUT) LOADING 24-VOLT SUPPLY LINE. LOCATED ON THE MAIN PCB.
I hope this was helpful, BIG IRISH.
Dec 16, 2009 | Mitsubishi WS-55819 55" Rear Projection...
I push power button and my 1080 series 42 in. mitsubishi big screen shuts right back off.
Most of these sets have a self check feature:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ON FOR A MOMENT AND GOES OFF.
PRESS AND HOLD “device”(device sometimes is called input) and “menu” buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC’s is blown---set will detect no voltage to convergence IC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES AND THEN TO GET IT TO REPEAT MORE YOU HAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
Let me know what you find and I will tell you what it means.
If this information helped you rate this solution as I do this here for free.
SD TECH
Dec 14, 2009 | Mitsubishi Televison & Video
I was watching it and it just shut off when i turn it on 3 seconds later it shuts off again
this set has a self diagnostic feature:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
PRESS AND HOLD “device” and “menu” buttons on front of tv for at least 5 seconds and then release both together.
If this has been helpful I would appreciate a vote from you here; if you need direct help:
etower.766@netzero.net
Aug 14, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Marantz SR6001 AV Surround Receiver - Blinking Standy Light
Try pressing the power, and multi speaker button at the same time. But first turn the unit off...then press the above buttons at the same time...This is for the SR6001... GH
Feb 16, 2008 | Denon DRA-395 Receiver
Marantz SR4002 Logo
498 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
