Question about Mitsubishi WS-65513 65" Rear Projection HDTV
Mitsubishi WS-65513 TV with the infamous blinking green LED issue
Hi Techman,
My brother has the Mitsubishi WS-65513 TV with the infamous blinking green LED issue...
I have a technical background and can replace the faulty caps myself. Please send the repair docs and service manual to: rushnrick_2000@yahoo.com.
Thanks in advance for your help with this...my niece & nephew are very bummed out about not being to watch the Disney channel...
Best regards,
Rick
  • 1 more comment
  • gusq Dec 14, 2008
    I have the same problem. Can you also send me the information to fix?
  • fishlou Dec 23, 2008
    Yes I have the same problem with the blinking green light. I would greatly appreciate any help. Thanks Mike mbechter@neo.rr.com
  • scott Dec 23, 2012
    Can you send me the fix also? naz@dslextreme.com
    President:
  • 3,130 Answers
Will do rick.
Posted on Mar 31, 2008
Flashing green light on mitsubishi ws-65513. replaced the four capacitors still have a blinking green light
Hi my name is Roety,
I can help you with your issue ,
Most likey you have a stuck keypad button, unplug the keypad from behind the front panel
If thats not it check for a fluid leak
Voltage checks and a visual would be needed to determine exactly what is bad in your TV
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
Nov 19, 2009 | Mitsubishi WS-65513 65" Rear Projection...
Mitsu 65513
I also have the blinking green light problem with my WS-65513 Mitsubishi TV. I would appreciate any information you could send to help fix this problem. Thank you, Keith. elitemachine @netnitco.net
Nov 04, 2008 | Mitsubishi WS-65513 65" Rear Projection...
WS-65513 Blinking Green Light
I have a Mitsubishi MITWS-65813.
The green led light constantly blinks. I tried the reset button and green light is still blinking. I unplug the tv, waited a few days, then plugged the tv back in, the green light still blinks. I have a lot of experience with soldering. Do you have any suggestions or can send repair directions/protocol for the DM board.
via email? Thank you in advance for your help. Your help is much appreciated!
Sep 29, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Blinking green light of death
You can get the V23 DM repair kit at the following link which has the replacement capacitors and the instalation instructions on Cd which has pictures of the repair. Its listed under the repair kit category.
http://servicemanuals.vstore.ca/
Aug 26, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi WS-65513 green blinking light
Good Day, nixonam;
This a very common problem with model. Don't listen to other comments unless the use the correct replacement parts.
SYMPTOM: Power LED does not stop blinking after plug in.
CURE: replace C9B01, C9B02,C9B10, and C9B11 (1000 uFD 16V) on the DM PCB. Replace them with part # 181P734030 (680uFd 16V).
The DM Board (PCB) is located on the very left side of the TV looking from back. Caution on removing Board and note what cables you disconnect to access the Metal Shielded Board.
Good Luck, big IRISH.
Jul 08, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi TV WS-65713
Please send me the instructions on how to remove and repair the dm board in my mitsubishi ws-65513 tv. The green light keeps blinking. thanks
samzlades@yahoo.com
May 26, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi WS-65513 Green Blinking LED Fix Request
you can obtain the service manual at the following link they email it to you and you will recieve free support and if you request they will send you the step by step proceedure for the DM repair through their tech support program. This is all free when you purchase a service manual. You would need the VZ23 series mitsubishi manual. Here is the link.
Apr 02, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Constant green blinking light Mitsubishi tv WS-65513
Please study the procedure at the following address.....
www.chrisandnat.com/projects/blinkingtv/blink.htm .....
use 1000mf 25v or 35v 105 degree capacitors to replace
original four 1000mf 16v..............if new ones are a little
too high,just lay them over on board........
Look it over..........let me know......................T.
Jan 07, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi WS-65513 65 in Perpetual Blinking Problem:
Replace four 1000mf/25v caps on DM module.....pix's at...
www.Chris@ChrisAndNat.com..................T.
Nov 25, 2007 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi ws-65513
Have you looked at the DM board fix yet that's available here. http://www.fixya.com/howto/h154057-mitsubishi_dm_board_repair Check it out. If the inside of your TV set does not look like this, you will need to get the service manual to disassemble the set and get to the DM board, but use the rest of the guide to repair the board. If you are successful, you will save almost a 1000 bucks! Good Luck
Jul 14, 2007 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi WS-65513 65" Rear Projection HDTV Logo
313 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
