Question about Pioneer AVIC-F900BT Car GPS Receiver
I HAVE A F900BT WILL IT FIT IN MY 2010 CHEVY TRAVERSE? AND IS IT ALL PLUG & PLAY
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 35 Answers
It will fit, but the parts are expensive and it is not plug and play.
Parts needed:
Dash kit- Metra 99-3305 About $15-$20
Antenna adapter- Metra 40-CR10 (Chrysler antenna adapter) Yes GM uses Chrysler parts. About $10-$15
Wire harness/Interface- GMOS-LAN-01 (non bose or onstar) About $100
GMOS-LAN-02 (bose/onstar) About $120
The reason for the pricey harness is to retain data features on the vehicle and to interface with Onstar (GMOS02).
This is the right way so don't cut corners because it can cause issues on your brand new vehicle.
All of your safety chimes run through the stereo and not using the correct interface can cause issues with your gauges
www.metraonline.com or www.scosche.com are good sources for install parts info
Posted on May 15, 2010
How do i wire up a trailer light harness to a 2010 chevy traverse?
Get a plug and play kit. They are usually available from your local parts store. This will save a lot of time and make the install much easier for about $30 us.
Rigid Connector
Oct 07, 2016 | 2010 Chevrolet Traverse
Ihave a 2011 equinox. The ac panel stoped working. I checked all fuses inside and out. Is there a relay thac controls this?
Chevy Traverse Forum: A/C won't change positions and passenger won ...
www.traverseforum.com > Chevy Traverse > Tech Section > HVAC
Apr 6, 2013 - 20 posts - ‎11 authors
I have a 2009 Traverse LT (w/ 42k miles... ) and we just ... Turn the car on, but DONOT TOUCH the HVAC controls. The AC will come on and ... Dual Climate Control not working properly ...
Sep 5, 2014
Front power outlet (cigarette lighter plug ...
Mar 1, 2013
2009 Traverse Heat Selector Switch Not Working
Nov 13, 2012
Air conditioning problem with 2009 Traverse
Jun 30, 2011
More results from www.traverseforum.com
Compressor : Chevrolet Equinox Common Heating & Air ...
repairpal.com > Problems > Chevrolet > Equinox
GM Recalls 2010 Chevy Equinox and GMC Terrainwww.autoevolution.com > News > RecallsDec 29, 2009 - "The software in the center instrument panel can cause the heating, air conditioning defrost, ... I have a 2007 Equinox, just had the fuel injectors cleaned out..... On 1 February 2011 at 23:32 UTC, al (gonzo) said: .... 60,000 miles I wonder if that will be covered under this recall? does say ac may stop working.Ac Problem: I Have a 2007 Equinox. the Air Conditioner Will ...www.2carpros.com/questions/2007-chevrolet-equinox-ac-problem
Dec 21, 2015 | AC Cars & Trucks
Where is the camshaft position actuator solenoid located on a 2010 Chevy Traverse 3.6 l
Start by removing the Battery Negative Cable, as its an Electrical component, and will also clear the check engine light at the same time, after replacement of the Actuator.
OK its really looking at you at the middle right side below the Engine Plastic Cover between the two corrugated cable wires. One 10mm Bolt, then UN plug the electric from the old Actuator, lubricate the O-ring of the new and may be a bit of dielectric grease on the electrical connection holes of the plug, and re install the new... its an easy task. Similar or exact picture...
Feb 18, 2015 | 2010 Chevrolet Traverse 1LT
2010 Chevy traverse liftgate will not open...feels stock
The latch motor is bad. On the inside there is a plastic plug at the bottom of the panel. Remove it and insert a screwdriver, pull up on it. You want to pull the release arm up( there is an rod you need to catch). Then open the hatch. Remove the panel and remove the latch.
Oct 16, 2014 | 2010 Chevrolet Traverse
How many gallons of antifreeze does chevy traverse take 2010
Most systems will take 3.5 gallons completely empty.
Sep 02, 2014 | 2010 Chevrolet Traverse
Chevy traverse 2010 ac is blowing hot air
try the ac fixes(freon recharge) found at your local autoparts store if that works for a little while you have a leak in the ac system if it makes no change it is most likely the ac compressor or the ac pulley is not engaging
Feb 19, 2014 | 2010 Chevrolet Chevrolet Traverse LTZ
Replace cabin air filter on chevy traverse 2010
2009 chevy traverse- where is the cabin air filter located. It definatly has one but ??? where.
Jun 18, 2012 | 2009 Chevrolet Traverse
How to change headlight vulbs for chevy traverse 2010
look in the front wheel well there will be a round hatch to take off.. u might have to turn ur front tire hard over or take it off
Apr 02, 2011 | 2010 Chevrolet Traverse
Pioneer AVIC-F900BT Car GPS Receiver Logo
177 people viewed this question
Top Pioneer GPS Experts
David Burbee
David Burbee
Are you a Pioneer GPS Expert? Answer questions, earn points and help others
