Question about Homelite Mighty Lite Lawn Trimmer
UT22600-need to take off the spark plug-what do I use? my standard spark plug wrench is too thick for the space around the plug. The housing is held on by some strange star shaped screws-not phillips head....
  • 843 Answers
The star shaped screws are called Torx. They sell the bits at the hardware store, and they come in different sizes, so take your trimmer with you to the store. But it might be easier to just buy a thin-wall socket. Take your trimmer with you to try that too. Hardware store might not have them, but Home Depot, Lowes, and Sears do, they would have the Torx bits too.
Posted on May 14, 2010
Steps to change a spark plug
easy job replace one spark plug at a time.you need buy new set of spark plug wires and spark plugs.reason need new wires possible old ones will break from inside plug boot when you remove plug wires.you need basic 3/8 ratchet wrench.you need long short extensions.need spark plug socket.need spark plug gap gauge.need a universal joint connect to the extensions to reach sharp angles.make sure engine cold when replacing spark plugs could damage heads.use a 12 inch piece vacuum hose to help aid in installing sparks in hard reach spaces with out damaging crosss threading plugs threads and cylinder head threads to plug.
Apr 25, 2013 | 1998 Pontiac Grand Prix
Tip
Replacing A ChainSaw Chain Drum/Sprocket
Outboard drums (drums on the outside of the clutch) are held on by a nut or e-clip.
Inboard drums are held on by the clutch which is threaded onto the crankshaft. And there is the challange.
***NOTE all chain saw clutches have LEFT hand threads, so, rightey loosey, lefty tightey. (just backwards from everything else)
*** NOTE #2: DO NOT USE AN IMPACT GUN
this will most certainly shear the flywheel key or damage the flywheel !!!!! (after 35 years, you can ask me how I know that, LOL)
1) Use a piston stop to hold piston from moving: THIS IS A MUST !!!
Ok, so you do not have one, let's make one.
a) remove the spark plug
b) insert a piece of recoil rope into the cylinder hole, leaving a tail to remove it by. (rope, large shoe string, anything that is soft, that is aprox 1/4 to 5/16 in diameter to place into the spark plug hole to help the piston to stop it's travel by filling up the empty space. Just make sure you can remove it later)
c) secure the saw (extra set of hands may be needed) and with a suitable wrench on the clutch center, rotate the clutch to the right until piston comes to a stop. With a hammer, tap the wrench to aid in rotation. This can be very difficult, and may take several taps.
d) after removed, inspect and grease the drum bearing before re-assemlby.
e) upon re-assembly of clutch, tighten by hand only, NO hammer required. The force of the chain will tighten the clutch.
f) remove the rope, and re-install the spark plug.
on Dec 06, 2009 | Garden
Tools in replacing 1996 honda odyssey spark plugs
the only specialty tool your should need is a spark plug socket and an extension for the ratcheting wrench.
Other than that, metric wrenches and sockets should work just great.
Jul 06, 2012 | Honda Odyssey Cars & Trucks
How do i change the spark plugs on a mercedes E430 1999
It is a bit of a chore, but no real tricks involved. Just lots-o-tight spaces.
You will need a few special tools, including a slim profile spark plug socket.
I used a Stahlwille socket#51, a 16mm socket with rubber insert.
A T27 Torx bit and a Low Range torque wrench (for the Torx screws- 8Nm),
and a regular range torque wrench for the Spark Plugs (28 Nm).
Another tool that made the job easy, was MB part# 110 589 01 01 00, aka
Hazet # 2771. You use the wrench to pry the spark wire off the plug.
Other helpful items were 3" and 5" extensions, and a U-Joint.
In all, it took around 3 hours. A preatty straight forward procedure.
Although the coils and plug/block areas ARE marked with A & B, I was paranoid, and just did one plug/plug wire at a time, JUST IN CASE!
Feb 16, 2012 | Cars & Trucks
206gti spark plug change //
You must remove the Coil connector rack and under the coil rack are the individual coils for each spark plug, carefully lift them out, t wist them back and forth to break the rubber boot seal on the top of the spark plugs which are down in well under the coils the valve cover, the ignition coil connector rack is held down by two machine screws, 10mm head I think. You will need a medium 3/8" drive socket wrench extension to get the plugs out and of course a 5/8" spark plug socket and ratchet wrench. Below is a picture of the coil connector rack.
Jan 04, 2012 | Cars & Trucks
Cant get a tool to get the ohter bolt on thermostat housing to get off..the manifold is in the way ..and i cant get to it..what your suggestion.for a 97 chevy malibu
Hello walkerbaby, you will find it much easier to complete the job if you remove the throttle body. The throttle body is held on by 3 different 13mm bolts. (There is a fourth nut if you remove the bracket for the throttle cables) The third bolt in the lower right corner of the throttle body is hidden behind the 2nd bolt. It is difficult to work with because of the limited room, but a open/closed ended wrench should be fine. There are also two small hoses connected to what looks like a heater line, they too are difficult to remove, but a little force will help. With the throttle body unbolted you can move it out of your way (no need to unhook the throttle cables, just unbolt it so you can move it) you should be able to get to the 2nd bolt holding the thermostat housing in place. The instructions above will guide you through the rest. Also, you may want to also remove the air filter and air filter housing for additional room. The torque specs on the throttle body and thermostat housing are 18 pounds...getting a torque wrench in there is another chore, so i use the old, it's feels tight enough to me method, like i would on a spark plug....
Be careful not to destroy your gasket on the throttle body. One less expense. New thermostat should come with new rubber seal, if not buy one and replace it.
Tools Needed for the Job:
- Deep metric socket set
- Standard metric socket set
- Various size flat head and Philips head screw drivers
- Gloves
- Open and closed metric wrenches (sizes 8mm - 15mm)
- New thermostat and housing seal.
- Beer is optional.
Good luck, i hope this helps and thanks for using FixYa!
Jul 07, 2011 | Chevrolet Malibu Cars & Trucks
Homelite Gas powered Trimmer will not start. Tried clean air filter....changed spark plug... no spark produced when removing plug from housing and pulling starter rope. Do I need a new ignition kit ? ...
The body of the spark plug has to be "grounded" to the metal on the engine when you remove it and test it. If you did it that way, OK. If there is no spark then (and it should be a nice blue color, not orange or yellow), the the "air-gap" between the ignition coil and the flywheel needs to be checked. Some disassembly is required to get to it as these parts are under the front engine cover. The air gap should be around .010" (or about the thickness of a standard business card). If the gap is too wide, the spark will be weak. If the gap is too close, the legs of the ignition coil may slightly rub on the flywheel. If you indeed have no spark, after properly testing, then check the air-gap.
If this is a fuel related issue, post back and we will address that as well.
May 14, 2011 | Garden
Cannot figure out the size of the socket wrench needed to remove spark plugs. It needs like a slim socket to get it in the socket well.
You are always best off using the wrench that Honda supplies in the tool kit. It is designed to fit in your motorcycles head and has a grabber to lift the plug out of the spark plug hole. Provided a previous owner did not keep the tool kit or forget to put the spark plug wrench back in the kit . If you do not have a tool kit , you can purchase one at a Honda dealer or , if they want too much for the kit , you can order the spark plug wrench by itself , probably for around $10.
Nov 07, 2010 | 2002 Honda VT 1100 C2 Shadow Sabre
How do I change the air filter and spark plugs on my xvz1300a
The air cleaner is underneath the fuel tank, above the carburetors, in a housing that basically resembles a coffin. The housing is held to the carburetors by four flexible clamps at the bottom of the carburetor joints, and the housing halves are joined by ten phillips-head screws. Remove the fuel tank, loosen the flexible clamps, remove the housing from atop the carburetors, remove the screws from the top housing, split the housing halves; the air cleaner may now be removed and replaced. Reassemble in reverse order.
The rear spark plugs may be removed with a 3/8" socket wrench, a 3"-4" extension and a 12mm spark plug socket; the front spark plugs require removal of the motor mounts, do ONLY one side at a time with the same tools you used in the rear. take extreme caution to avoid getting dirt and debris into the cylinders while removing and replacing the spark plugs. The motor mounts require an 8mm allen wrench.
Dec 02, 2009 | 1996 Yamaha Royal Star XVZ 1300 A
Need location of ecm/ecu on 88-93 buick regal. parked car next day would not start,no spark , center coil bad , replaced it car ran fine for about 2 weeks, now car won't start no spark but coils test good,...
my name is David ,I live in Austin Texas and do alot of mecchanic / technician work around town. I do have my certifications and have work at dealerships and Autozone as well...with all that being said... if you are not getting spark on this vehicleand it is not likely the coils or the module. The crank position sensor the device responsible for reading the angle ( timing ) of the crankshaft. The crankshaft has notches in it that pass either through or near the crank position sensors magnetic tip. The ignition module then interprets the signal and allows signal ( electrical current) to pass into module and on to ignition coils...then on to spark plugs via spark plug wires/cables. The crank position sensor is located on the back side of the engine in the gap between the engine and transmission housing. it is held in place by one 8mm (metric size) or 5/16 standard size bolt. Use a wrench though unless you have small hands or a 1/4 drive socket set. 9.99 times out of ten it will start if there are no other issues... your welcome
Mar 30, 2009 | 1989 Buick Regal
Homelite Mighty Lite Lawn Trimmer  Logo
182 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
