Question about Maytag HAV2557 Top Load Washer
When I start a small load, the water keeps going and will fill up almost to the top then it starts coming out from under the machine. How do I fix this?
  • 159 Answers
Hi eileen.Like marka19 said the pressure switch may be the problem but i would also suggest that there is a thin tube running from the side of the bowl to the pressure switch wich can develop a tiny air leak causing the machine to fill past the low level.Now i dont know if the water leaking is from the bowl actually overflowing with water or you have a more sinister problem with a centre tub seal.
Posted on May 28, 2010
    President:
  • 1,430 Answers
The problem is the pressure switch has failed. These are usually inexpensive and are very easy to replace. There is a video at www.appliancehelponline.com/servicemanual.html this will walk you thru the inspection and replacement of this part. You can also enter your model # for diagrams and illustrations of your specific model. All parts come with installation instructions. Not all models are available.
Posted on May 14, 2010
Does not sense clothes
most top loaders fill to the setting you enter into the program l( medium low high etc ) as the clothes absorb the water it will keep filling until a level is reached at which point that is the amount of water for the clothes and the machine will start you just have to think about how many clothes you are washing and how big they are ie blanket will be a big load and nickers will be small load
Jun 09, 2013 | Washing Machines
I bought a top load washing machine model number WF T7239 UL on 05Nov2010. Water sensor does not seem to work. Water just keeps filling up the drum and starts overflowing once filled.
Your pressure switch stops the water and allows it to start the next cycle. It's a switch either in the control panel or at the top of the tub with a small tube connected to it which goes down between the inner and outer tub. As the water level increases the air in the tube is compressed until there is enough pressure to make the switch stopping the water from filling. This tube can get clogged and the switch won't work. Remove the tube and clean it out. Blowing on the tube when it's still connected to the switch will make the switch if it's working and clear.
If it fills with water and starts the cycle and the water keeps running in then your water inlet valve on the back where the water supply comes in is sticking. It needs replacing.
Nov 06, 2010 | LG Washing Machines
Water over fills and machine does not start washing
put the washer on warn and start to fill,turn washer off,if it keeps filling then you need a new water valve,if it does not stop filling your water level,hose has come loose or the water level switch is bad-mike
Feb 09, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Machine started filling with water - then stopped and flashed F
I have the f51 code filled up with water and stopped. They are coming today to fix it. Called whirlpool and they are fixing this at their expense. I have the extended warrenty they said they are fixing codes f1 and f51
Oct 18, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Leak from under the washer
tub seal has gone bad, will only get worse. Expensive fix,
Jul 02, 2009 | Maytag PAV2300 Top Load Washer
Continous water filling
HI, the water level switch is damaged on this unit. you will need to replace this switch. this will fix your level issue.
May 27, 2009 | Frigidaire Gallery GLWS1339EC Top Load...
Washer keeps filling with water...
you hae a stuck float switch, it shuts water off when it reaches a certain height, fixing it involes removing the top of the washer (not easily done)
Jan 11, 2009 | Kenmore 22422 Top Load Washer
HELP ME WITH MY PROBLEM
if water stops when knob pushed in raise console (probably screws under each end cap just pull caps toward you to remove )remove screws lift console ck small hose going to water level switch to be sure it is pushed on ..if water will only shut off when faucet turned off replace fill valve
Dec 12, 2008 | Kenmore 22422 Top Load Washer
Water keeps running.......
i assume washer never starts running if not suspect water level switch or connection hose also be sure small hose to switch is not plugged or mashed flat even a small hole in hose may cause it not to get pressure to tell switch drum is full ..if washer does start running suspect bad water valve may not be shutting off
May 19, 2008 | Frigidaire FEX831CS Top Load Stacked...
GE top load washer leaks on floor
Check your hoses mostly the small hose going from the side of the tub to the water switch these come off a lot. you need to look and see if the seal is leaking from the center of the tub you do this by putting water in the tub and just looking around the bottom of the tub and transmission
Dec 29, 2007 | Washing Machines
Maytag HAV2557 Top Load Washer Logo
60 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
