Question about Fuji Discovery 312 QD Zoom Date Point and Shoot Camera
Initializing 1 g disk for a S1000
How do I initialize disk?
  • kakima May 14, 2010
    What's the disk connected to? I sure hope it's not the Fujica 312 film camera.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Fuji Master
  • 102,366 Answers
Having received no response in over a month, I assume this is no longer a problem.
Posted on Jun 18, 2010
I have a problem Taskalfa 250ci eror code c0640 I think at Hdd problem. But I don't know how to hdd format
Maintenance
item No.
U021
Memory initializing
Description
Initializes all settings, except those pertinent to the type of machine, namely each counter, service call history
and mode setting. Also initializes backup RAM according to region specification selected in maintenance item
U252 Setting the destination.
Refer to *1 of the maintenance mode item list about the item initialized.
Purpose
To return the machine settings to their factory default.
Method
1. Press the start key.
2. Press [EXECUTE] on the touch panel.
3. Press the start key. All data other than that for adjustments due to variations between machines is initial-
ized based on the destination setting.
4. Turn the main power switch off and on.
For errors occurred, turn main power switch off then on, and execute initialization.
Error codes
U024
HDD formatting
Description
Initializes the hard disk.
In addition, the following settings are also initialized by initializing the hard disk.
System menu (user login administration, job accounting, address book, one-touch keys and document box
etc.), shortcuts and panel programs
Purpose
To initialize the hard disk when replacing the hard disk after shipping.
Method
3. Press the start key to initialize the hard disk.
Description
Codes Description
01 Configuration initialization error
02 Counter initialization error
20 Engine initialization error
40 Scanner initialization error
2JZ/2JX/2JV/2H7-5
1-3-23
Apr 15, 2013 | Kyocera Taskalfa 250ci Color Copier...
Initializing scanner
Update the firmware
Restored factory defaults
Initialization of the hard disk.
If it still doesn't work try to clean the scanner head under the glass. Clean the lens with some alcohol but be careful not to scratch the lens.
Mar 12, 2013 | HP LaserJet M5035 MFP Printer
Pxe e63 error while initializing nic no bootable
here we go >
power on your netbook press delete to go to bios setting goto boot or boot device priority then set it to harddisk(your current setting is pxe or network boot) then press f10 to save enjoy
thanks for using Fixya
Jun 01, 2011 | Acer Aspire One Netbook
Looking remove all stored channels from scanner and start over.
Initializing the scanner will erase all programmed information and return your scanner to its original factory settings. To initialize your scanner:
- Power the scanner OFF.
- Power the scanner ON. "Multi-system Trunking Scanner" appears on the display.
- Press 0 (zero) while the above message is displayed.
- Press 1.
- Press ENT. "Initializing please stand by" appears on the display.
DO NOT power the scanner OFF until the initializing process is complete and the display shows "M000 Bank0 Ch00"
Bill B.
Listening in professionally since the 60's
Mar 22, 2011 | Radio Shack Pro-2055 Base Scanner
I have a printer it is modle is Hp LaserJet p4015n, when i start it give me this error: (49.00FF ERROR To continue turn off then on). when I turn off then on it give me agane this error. thanks for help,...
HP 4015 NVRAM & hardrive initialization
Solution
A hard disk initialization will erase and reformat the printer's hard disk. Perform hard disk initialization only if an error code displays on the control panel indicating a disk error. Always try initializing the hard disk before replacing it.
1. Turn the printer on.
2. As the printer performs its power-on sequence, press and hold the Menu button until all three lights on the control panel are lit.
3. Press the back arrow . The message INITIALIZE DISK displays on the control panel.
4. Press OK. The printer initializes the hard disk and continues the power-on sequence.
CAUTION: Initializing NVRAM resets the serial number, the model number, the event log, the page counts, and the EIO card. Use the SERVICE menu to restore the serial number and page counts. You also need to reconfigure any computers that print to this printer to recognize the printer. Initialize NVRAM only when absolutely necessary. In most situations, use a cold reset to return printer to factory defaults but still retain the needed values in the SERVICE menu.
 NVRAM initialization
Before initializing NVRAM, print a configuration page and a supplies status page to gather the service menu values
1. Turn the printer on and watch the control panel display.
2. When the display shows the memory count, press and hold the down arrow until all three lights on the control panel are lit
3. Press the up arrow .
4. Press Menu . The message SKIP DISK LOAD displays on the control panel.
5. Press the up arrow until NVRAM INIT is highlighted, and then press OK. The printer initializes NVRAM and then continues its power-on sequence.
daca aceasta procedura nu reuseste, atunci va trebui sa inlocuiesti formatter-ul. daca nu exista hard disk
Good luck
Dec 12, 2009 | HP LaserJet P4015N Printer
Toshiba qosmio g15 hard drive #2 not showing up on explore
First ensure the drive is seen in the BIOS, if not seen there, it will not be seen in Windows.
If detected and Identified in BIOS, then see if the drive is seen as Drive 1 in Disk Management. CONTROL PANEL, ADMIN TOOLS, COMPUTER MANAGEMENT, DISK MANAGEMENT. If it is listed in Disk Management but not assigned a drive letter, then right click the Disk 1 and INITIALIZE the Drive, then format it (Note: any data on the drive will be lost when initializing a drive)
Jun 25, 2009 | Computers & Internet
HE tratado de instalar CALL OF DUTY , Y PIDE ARCHIVO OPENGL
you need to uninstall the game and reinstall and make sure your disk is clean i have had this myself
Nov 16, 2008 | Tablets & eReaders
Printer takes ages to process
NV RAM and HD
To initialize NVRAM
1. Remove any installed accessories (for example, a stapler/stacker).
2. Turn the printer off.
3. Hold down the DOWN ARROW ( ) button, and then turn the printer on. Continue holding
down the DOWN ARROW ( ) button until all three printer control-panel lights flash once and
then remain on. This might take up to 10 seconds.
4. Press the UP ARROW ( ) button.
5. Press the PAUSE/RESUME button. The display should show SKIP DISK LOAD.
6. Press the UP ARROW ( ) button until NVRAM INIT is highlighted.
7. Press the SELECT ( ) button. The printer initializes NVRAM and then continues its poweron
sequence.
Hard-disk initialization
CAUTION A hard-disk initialization erases and reformats the printer hard disk. Perform a hard-disk
initialization only if an error code on the control panel indicates an EIO disk error. Always try
NOTE Before performing a hard-disk initialization, print a menu map and a configuration page (see
Menu map and Configuration page). Use the information on the configuration page to reset
any customer-set printer configuration values that the hard-disk initialization procedure
changes.
1. Turn the printer off.
2. Hold down the PAUSE/RESUME button, and then turn the printer on. Continue holding down
the PAUSE/RESUME button until all three printer control-panel lights flash once and then
3. Press the BACK ARROW ( ) button. The display should show INITIALIZE DISK.
4. Press the SELECT ( ) button. The printer initializes the hard disk and continues its power
Mar 12, 2008 | HP LaserJet 2420 Printer
System initializing
This is straight out of p. 67 of the user's manaul, available on iRiver website (it may not work if the computer does not recognize the device):
Initializing H10
67
Additional information
Firmware upgrade
66
What is firmware ?
It is the operating system that works in the H10.
iriver provides you with the latest and best features through Firmware upgrade.
You can choose manual or automatic upgrade function.
For information on automatic upgrade, refer to the iriver plus instruction manual.
Manual firmware upgrade
Select [Option - Firmware Upgrade] from the menu in iriver plus.
Do not disconnect H10 during firmware upgrade.
Internet must be connected for the "Firmware Update" function.
Change to "Player must be connected to the PC for Firmware Upgrade function.
Note
Please initialize H10 player in the following cases.
All music, pictures, text, and data will be erased from the player during this initialization.
- if there appears to be corruption on the internal hard drive.
- if an error message displays and the player doesn't boot properly.
1 Connect the player and PC using the cable supplied with the player.
Open iriver plus.
Select [Option-Portable Device Initialization]. 2
Click [Start] to begin initializing.
Initializing H10
Dec 18, 2007 | iRiver H10 MP3 Player
San Disk Sansa m 230 512 MB
Your problem is probably beacause you accidently deleted "AudibleActivation.sys" from your "Audible"-folder. Format the sansa and then use "reset to factory settings" to make the file appear again. It might be a good idea to make a backup on your hard drive, just in case, and make the file hidden.
Oct 31, 2006 | SanDisk Sansa m230 MP3 Player
Fuji Discovery 312 QD Zoom Date Point and Shoot Camera Logo
24 people viewed this question
Top Fuji Photography Experts
Jax Planet
Jax Planet
Are you a Fuji Photography Expert? Answer questions, earn points and help others
