Question about ASUS EN8500GT HTD DDR II, PCI Express Graphic Card
Asus a7n8x MB and ram
Can i use 2x1gb ddr400 pc3200 ram with my asus a7n8x motherboard and 3.2gb xp amd athlon cpu?
I have checked several online ram specialist and they all
recomend 2x1gb ddr33 pc2700 ram.
My motherboard manual states that it's max is 3x1gb ddr400 pc3200 ram and because this is a very old pc asus are not too quick at responding to my query.
  • 111 Answers
I just checked & yes you can from what i was reading
Posted on Mar 30, 2008
SOURCE:
Hyhcan i fit a bigger processor to the asus K8V-MX Motherboard and more ram
Your motherboard can take any AMD Athlon CPU (this does not include the newer multi core or Athlon 2 CPU's), as well as up to 2 gigabytes of DDR400/333/266, ECC, non-ECC, un-buffered memory. That memory has to be split between 2 dimms as the motherboard will not work with a single dimm of that size. Also, ensure that when you do put memory in that the 2 memory sticks are exactly the same.
Mar 17, 2011 | ASUS K8V-MX Motherboard
What must I do into the bios To changes the cpu
NOTHING THE MOTHER BOARD AUTOMATICALLY DETECTS CPU SPEED
Apr 17, 2010 | ASUS A7N8X-X Motherboard
Abit NF7-s - hynix ram support problem
The problem probably is you mixing fsb speed, all the cards should
be pc3200 or all of them should be pc2700.
You don't mix.
Feb 13, 2010 | Computers & Internet
My AMD 3200+ 400/333 chip has died, what can I replace it with? The motherboard is an Asus A7N8X.
Anything in AMDs Socket A line of processors should work.
The AMD Athlon XP 3200 was one of the best processors that would work in that board. Good luck finding one though.
Oct 10, 2009 | AMD Athlon XP 3200+ 400MHz FSB CPU...
Memory upgarade
Yes, it will work. Remember that all memory will operate at the speed of the slowest memory though so unless you're completely replacing the memory it won't increase the speed of the memory.
Jul 21, 2009 | ASUS A7V400-MX Motherboard
I want to add more ram in my pc km400/km266
Oddly enough this board has the following specs: The board supports both Althon and Duron processors up to Athlon XP 2800+ (3000+ with a BIOS update). It can handle 3 GB of DDR333 RAM (or 2 GB of DDR400, but not all types are supported).
That's the older 184pin DDR ram in PC2700 or PC3200 guises. I can see no reason why it would only accept 2gb of the faster Ram.
Why not go over to www.crucial.com  and run the online scan to get the true story on your board?
Jan 05, 2009 | AMD Via KT400 Athlon(XP)/Duron SktA DDR...
Max. AMD for Asus A7N8X-X
Find the manual online.  Also, your question is foolish in light of the much better efficiency of new multi-core systems and general inavailability of AMD Athlon XP 3200+ in socket-7 form; it's not like you'd save money changing CPUs, or your system would merely fake it for a few days if you put in an XP 3200+ (in the socket that fits!) you had set aside, and it did work.  On the other hand, XP2600+ overclock pretty well.
Sep 10, 2008 | ASUS A7V8X Motherboard
Can't install a driver
i've lost my driver cd for my asus wl -167g, can i download it for free?
Apr 03, 2008 | ASUS (WL-167G) 802.11g/b (wl167g) Wireless...
Pc upgrade !
IAN.S
Where you need to be is on Asus web site. Your board can handle ONLY; Athlon XP 3200+(400 MHz FSB)(Model 10)(Barton), AXDA3200BOX
With that CPU you must also have bios version 1004.
Check PCB and BIOS versions before flashing BIOS!
asus A7N8X supported CPU click here; http://support.asus.com/cpusupport/cpusupport.aspx?SLanguage=en-us&model=A7N8X
Since you seem to need your manual. Click the link:
http://dlsvr01.asus.com/pub/ASUS/mb/socka/nforce2/a7n8x/e1859_a7n8x.pdf
You do not have an intergrated video card. You have a 1.5v 8x
AGP video slot.
I suggest you call Asus & make sure your CPU model AXDA3200DKV4E will be supported over model AXDA3200BOX.
You can call Asus tech M-F EST at 812-282-2787.
Good luck & Have a great day!
Mar 16, 2008 | ASUS A7V8X Motherboard
Cpu size
Hi handydak
For your Mobo
VKM400 AM-S Try this link it will tell you what max size CPU & Memory you can install to improve performance.http://download.aopen.com.tw/Default.aspx
Regards,
ajb2000
Dec 28, 2007 | AOpen vKM400Am-S Motherboard
Open Questions:
MALWAREBYTES ANTIVIRUS i*855*536*5666 Malwarebytes SUpPoRt Helpline nUMber O&' Malwarebytes Antivirus Tech Support Number @+1855 536 5666 tMICo resolve all Malwarebytes Antivirus products. Malwarebytes Antivirus is an American multinational company which was founded by Michael Malwarebytes Antivirus using its company headquarters in Round Rock, United States of America.Contact Malwarebytes Antivirus for Setup & Installation Malwarebytes Antivirus Setup Support & Installation Malwarebytes Antivirus Helpline number Connect is a utility carrier that lets in you to print and scan from anywhere. The Wi Fi characteristic in it makes it very on hand and easy to use. So, when you have in the end determined to head for Malwarebytes Antivirus Connect, Malwarebytes Antivirus Helpline Phone Number you'll be searching out Malwarebytes Antivirus Connect setup as well. So, here we're with all cthe setup process and for your to Malwarebytes Antivirus Connect. Get Malwarebytes Antivirus Setup Instant Support Malwarebytes Antivirus Customer Service Phone Number Usually, the setup Customernique takes a number of time. One Customernique if accomplished incorrect, they could break the entire manner and you may should do it again. That's why here you may Malwarebytes Antivirus locate the approaches simplified to help you even if you aren't Customer savvy. Let us undergo the method Of Malwarebytes Antivirus Connect setup for Windows and for Mac Out. So, Outright here we go vikki
Oct 14, 2019 | Carrier Computers & Internet
See all ASUS EN8500GT HTD DDR II, PCI Express Graphic Card Questions
ASUS EN8500GT HTD DDR II, PCI Express Graphic Card Logo
104 people viewed this question
Top ASUS Computers & Internet Experts
Ekse
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
