Question about Dell SE198WFP LCD Monitor
Montitor display turns off. Not power, green light stays on.
The monitor displays for approximately 1 second and dissapears. Can turn off and on and it displays each time for 1 second. Green light stays lit (not going into power saver mode).
  • Daniel Hodge May 30, 2012
    Bought a new monitor but still interested in fixing if possible however, I can't see a way to get the monitor open. No screws...I'm assuming it must all snap together?
  • 11,361 Answers
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed Dell monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Similar board: http://www.lcdrepair.us/SE178WFPcinverter-power.html
Posted on May 15, 2010
Proview Monitor Blank display after 3 seconds issue
First place to look will be the power supply section, look for bad caps (bulging tops or bottom seals), the post back what you see so we can guide you further for direction such as voltage checking, see example of failed monitors due to bead caps: http://s807.photobucket.com/home/budm/allalbums
Jan 28, 2010 | Xerox XG-91D 19" LCD Monitor
After display goes black monitor green power light remains ON. Power can be turned of and the display again stays on approximately 5 seconds. Replacing capacitors in power supply did not correct the...
The problem can be the lamps are bad, the only way to tell is to remove the lamps, look for poor soldering works where the wires are attached to the lamps, bad lamps will have very dark color at the end of the lamps, just like bad fluorescent lamp you see when it is worn out, anoher sign of bad lamp is pinkish glow when lamp si first turn on. The transistors and caps are good in the inverter section?
Jan 02, 2010 | Mag Innovision LT782S 17" Flat Panel LCD...
Screen Goes Blank
Ive seen this on other monitors. Look for a 1 and 2. Some monitors do NOT auto detect a signal, and this one might not. Look for a way to set the monitor from Digital input to VGA input. Try that and see.
Jul 21, 2009 | Dell E173FP 17" LCD Monitor
MAG 700P monitor display goes black after 60 seconds
Can you send pictures of the power board to me at tech@ccl-la.com I will check our service manuals for the model and get back with you about a solution.
Buddy
Corporate Computer
Jun 29, 2009 | Mag Innovision LT782S 17" Flat Panel LCD...
Screen goes black,power light stays green. display only stays on a couple of seconds
This happened to me and I was able to fix it. I cracked it opened and found a bad capacitor, bought a replacement at Radio Shack and I'm back in business. Actually using it right now to post this.
-Jon
May 27, 2009 | ViewSonic Optiquest Q19wb LCD Monitor
HP desktop monitor problem
hi try this ,,,
  1. Ensure the video cable is connected (and connected to the correct video port).
  2. Turn off the monitor using the monitor's power button and then restart the monitor.
  3. Cycle the power on the monitor as follows:
  4. Turn off the monitor. The power light on the monitor should be off. Leave the computer turned on.
  5. Unplug the power cord.
  6. Wait 5 seconds.
  7. Plug in the power cord.
  8. Press the power button on the monitor to turn on the monitor. One of two things happens:
    1. The image from the computer displays on the monitor and you can use the computer again. This indicates that the monitor was unable to detect that the computer had awakened from suspend mode. Turn the monitor off when it is not being used or disable suspend mode. For some computers, updating the BIOS corrects these types of suspend problems.
    2. The power light on the monitor comes on but the screen displays one of the messages again. The monitor is not receiving a video signal from the computer that it can detect and use. Continue using these steps to adjust the Windows display resolution to the Monitor's native (default) resolution
    3. Connect the monitor to another computer that you know is working to determine if the monitor should be serviced or replaced:
      • If the monitor displays an image from another computer, you know that the monitor works. Troubleshoot the video connection and graphics adapter on the computer.
      • If the monitor remain blank when connected to another computer, the monitor signal processing hardware may be bad. The monitor should be repaired or replaced.
      hope it will work for u .. little_angel
Apr 30, 2008 | HP Pavilion a305w (DM181AR) PC Desktop
Monitor displays breifly then goes to blank screen
F1 = Fuse 1
You should be able to locate a surface mount fuse at your local electronics store.
Apr 12, 2008 | NEC MultiSync LCD1830 18.1" LCD Monitor
What is wrong with my AL1711
This is possibly an inverter. When the monitor goes out, examine the LCD to see if you can see a faint image of the video being displayed. IF so, replace inverter. If not, possibly a bad LCD or video circuitry.
Dec 07, 2007 | Acer AL1711 17" LCD Monitor
Powers up temporaly displays goes dark
Your monitor has a bad back light. Send it back to your friend
Nov 22, 2007 | BenQ T705 17" LCD Monitor
Monitor sleeps after one second
Try connecting the wires properly. try changing the VGA cable. i had the same problem my screen goes black some times and pink i changed the VGA cable it was absolutely fine!!!
What is VGA cable
VGA Cables Adapters Converters and Devices C2G
visit a computer mechanic for further trobleshooting
Mar 17, 2017 | AcerView F51 15 in. Flat Panel LCD Monitor
Dell SE198WFP LCD Monitor Logo
659 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
