Question about La Pavoni Europiccola EPC-8 Espresso Machine
Espresso comes out of comes out of spout before handle is raised
My La Pavoni has been in storage for a couple of years and now trying to get it up and running. I opened it up and checked all the gaskets, and they seem to be in good shape. However water or espresso drips out of the spout once the machine comes up to pressure. Less so with the espresso in there but if the basket is not loaded then water will flow out fairly quickly. The gaskets on the plunger look ok, I adjusted the nut on the top of the plunger that connects to the handle and helped a bit.
Still I don't recall water flowing out of the while the handle is down.
Any thoughts would be great, its diving me crazy and searched all over for an answer.
    Scholar:
  • 36 Answers
Hi there, i am Mr La Pavoni and am based in Glasgow, Scotland. I service and repair these machines all day every day and basically it could be a couple of different things. If it is pre 2000 then it could either be the piston gaskets or the piston shaft has come slightly unscrewed from the piston head. If it is post 2000 then it could be any of the above but also in these models there is an additional sleeve inside the group head which may be cracked or the seal on this part may need replacing. It could even just be a tiny bit of debris on one of the piston gaskets. If you have removed the shower plate and gasket and then taken out the piston assembley then you should really replace these gaskets anyway. You can purchase the parts on my website www.theespressoshop.co.uk which are all individually priced and every part is available for the lever machines. If you require any further assistance then please do not hesitate to get in touch at domesticespresso@live.com
All the best
Mr La Pavoni
Posted on Jun 02, 2010
I'm looking the right part (portafilter or handle and cups) for my La Pavoni Duet PA-1315.
try this link
if not listed use contact us or ask
some parts may have been discontinued
La Pavoni Parts
Oct 11, 2016 | La Pavoni Coffee Makers & Espresso...
Why water drop before lever raised until top position?
\\this might be caused by a worn piston seal. see here how to replace seals.
dr pavoni
May 15, 2014 | La Pavoni Europiccola EPC-8 Espresso...
Water leakage through grounds when lever is raised on my La Pavoni Europiccola.
Hi your grind is to course and or your tamp is to loose. Even with the right grind and tamp water will filter down through the puck eventually.
all the best
Dec 20, 2013 | La Pavoni Europiccola EPC-8 Espresso...
Handle problem
The bigggest pavoni dealer I know of is crossroads espresso 15413444600.
May 02, 2010 | La Pavoni Club Combo Duet PA-1315 Espresso...
La Pavoni high pressure also, but all of a sudden
check pipe for pressurestat and pressurestat,maybe just gauge is not corect
Aug 01, 2009 | La Pavoni Professional Black Base
I only get foam after 4 Shots
The only thing that comes to mind is descaling. To me it seems that most of the boiler room is being lost to minerals, so there is less water in there. Try descaling the machine.
May 31, 2009 | La Pavoni Europiccola EPC-8 Espresso...
Our La Pavoni Lusso machine has not been used for a couple of months. We put water in to prime the pump, and nothing comes out. We can hear the pump going, and the heater indicator light is working. Any...
Try opening the steam nozzle while trying to pump the water through as this will get rid of any air locks. Otherwise it may be a build up of scale in the boiler or the pump itself. Try that and descale if you can.
All the best
LaPavoniBoy
Mar 07, 2009 | La Pavoni Lusso PL-16 Espresso Machine
Leaking water from the group and steam spout
You will need to take the machine apart completely as there are more gaskets inside the group head. You can buy an old group service kit at www.theespressoshop.co.uk for about £20 and it comes with an exploded diagram so you can see what goes where. Don't worry there is no technical mechanical solenoid like the last comment stated. I repair these machines for a living and all it needs is a good service.
All the best
LaPavoniBoy
Nov 13, 2008 | La Pavoni "PROFESSIONAL Chrome" 16Cup
La pavoni professional
Make sure your filter is clean.
Jul 21, 2008 | La Pavoni PC-16 Espresso Machine
Lever pressure
clean up time use a product to remove calcium how many time i saw that calcium ruining very good machine hard water is a killer of those beloved machine dont use vinegar not strong enough and dont forget to rinse the machine very good that stuff is very corosif dont forget to rate this good luck cheers
Jan 16, 2008 | La Pavoni Europiccola EPC-8 Espresso...
La Pavoni Europiccola EPC-8 Espresso Machine Logo
254 people viewed this question
Top La Pavoni Coffee Makers & Espresso Machines Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
noel
noel
matt
matt
Are you a La Pavoni Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
