Question about Thermos Grill2Go Fire+Ice
I drop my regulator and the can turned completely
I drop my regulator and the dial turns completely around without pushing it in. How can I fix this problem?
  • 494 Answers
Hello there. I am a career LP gas (propane) repairman. Most propane regulators on bbq grills are not field serviceable; meaning if you broke it, you'll have to replace it. Take it to your local propane co and get their opinion. It might not be safe to use as is, so I don't recommend using it.
Posted on May 15, 2010
Oven heats up when power to cooker is turned on ( dial is at off position)
It sounds like the oven thermostat/regulator is faulty, or the dial is not turning the switch off properly, this could be caused by the dial being cracked or broken.
Pull the dial off, and try the switch with a pair of grips or pliers to make sure it is completely turned off.
If it is, then the you need to replace the switch or thermostat as the case may be.
Hope this helps.
Please rate my solution.
Thankyou.
Jan 08, 2010 | Hotpoint Ovens
How can i turn my canon eos 5 SLR film camera on?
On the EOS 5, top left. Push the center button, and turn the dial away from the red L. Always push the center button when turning the dial. If you snap that little plastic thing by turning it without pushing the button, then the dial will not stay where you put it. It will move around freely.
lightspiritphotography.com
Nov 05, 2009 | Photography
I can't the insides of the machine back in, it was opened when the machine was running the dial doesn't match up
Hi
These instructions should help.
To return the brew group to the centered position, you first need to drop the funnel. To do this, look on the opposite side of the brew group from the handle. At the top you will see an object that looks like a sharks fin. If you follow this piece down you will see 2 horizontal bars on the brew group body. Push your finger between these 2 bars and the funnel will drop. Now you can push the puck slide on the left side down and to the center. If you look down through the funnel you should see a piston. This should be centered in the funnel. If not, locate the slide on the left side of the brew unit,(it should be hanging down, a flat rectangular piece attached to the cylinder) and push the slide to the right until it does. Push the press button and you are now ready to reinsert the brew group in to the machine. First you must close the door and turn on the machine without having the brew group in, but you must have your drip tray and dredge drawer in. Turn the machine on. You will hear the motor turn on and when it stops completely, open the door and remove the tray, now insert the brew group and replace the tray.
Oct 30, 2009 | Saeco Incanto Classic Espresso Machine
Starts automatically when I set the timer
This could be a problem with the start button switch (it should click when pressed/released) or with the switch on the motor.
May 20, 2009 | Dryers
Machine will not sew forward without backstitching
You have selected the Stretch Stich (SS) mode on the stitch length regulator, just turn the knob around until you have a number 1 - 5 and that should be it.
The model number will be the last digits on the metal compliance plate with voltage etc.....looks like:
V / 1234 / 123454321 / 2016
www.bargainbox.com.au
This then would be a Model 2016
Nov 25, 2008 | Sewing Machines
I have an Alpine CDA-9815 head unit installed in a 2002 Dodge Dakota. I currently have a 12" DVC sub bridged at 4 Ohms. My head unit's volume goes up to 35. When i turn in past 24-25, the head unit...
It sounds like the sub woofer amplifier is pulling down the voltage level in the truck when it starts to get really loud. It may be the voltage regulator which is probably part of the alternator, or the alternator is not capable of supplying the needed current for the amplifier. If the voltage level drops below a certain level, the radio will see it as if the battery is disconnected. It requires a voltage level of around at least 10 volts to stay turned on. When an amplifier is playing loud, it draws a lot of current. If the current supply does not increase, it lowers the voltage level to compensate and get the current it needs to play at the level the head unit is pushing it to. As the voltage level goes down, the current increases when the voltage is dropping due to increased demand. You could check this with a voltage meter and monitor the level right at the battery and have somebody turn the volume up on the head unit slowly as you monitor the voltage level. The normal operating voltage of a car while the engine is running is about 14.4 volts. It should not drop much at all, no matter how loud the amplifier is playing. if it does drop, you have a problem with the trucks regulator or alternator.
I hope this helps, if you need more assistance let me know.
Dave
Jul 08, 2008 | Alpine Car Audio & Video
Wont turn on
don't know of anyplace that will "fix it fast". U r going to have to send it into casio.
Oct 29, 2007 | Casio Exilim EX-S600 Digital Camera
Dryer won't stay on.
lots of questions spring to mind, but if you have a push button type, it will only continue to turn once the motor is in motion. centripetal action allows a motor switch to keep the dryer in operation. look in that area.if you have a belt tentioner. check for continuity.
Jul 21, 2007 | Kenmore 64952 Electric Dryer
Thermos Grill2Go Fire+Ice Logo
191 people viewed this question
Top Thermos Grilling Experts
paulcarew
jdthefixer
kc5133
Level 1 Expert
Are you a Thermos Grilling Expert? Answer questions, earn points and help others
