Question about GE JTP20 Electric Single Oven
Oven will not stay heated. F1 light on.
Oven will not stay heated. Turned off breaker for 20 minutes and repowered. Baked a ham (approx 3 hrs) and worked ok. Since then, it will heat for the first few minutes and then shut off. Will not come back on. The F1 light is on.
  • GE Master
  • 3,051 Answers
Hello there:
on most ge models this code it can be either a (f 0) or the (f 1 ) is telling you that the the thermistor controle circuit is going bad or has failed all together. or there is a short in the erc circuit meaning the electronic controle board. ok
So i would recommend have a repairman check out the thermistor first since this is the most common thing to fail then if this passes have them test the controle board or the ecr circuit
and if the oven is still under warranty you might be able to use the warranty to get it fixed ok
Hope this is very helpful for you
Best regards MIchael
Posted on May 14, 2010
I have an amana artc8600 and the error code it has is f1. could you tell what the code means. Also, when i try to turn the oven on no matter what setting it keeps turning off i have to try a bunch of...
HI,
Disconnect power to stove
Gain access to the back of the clock (electronic range control or ERC).
Unplug the pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
Make sure everything is clear and will not short out when power is turned back on.
Turn power back on to stove.
Watch for the F1 and the beep
If you see f1 and hear the beep its the ERC
If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
Thank you for using fixya
Leo Ponder
Please rate me if this helped.
Jul 23, 2011 | Ovens
Can you tell me what an F1 error Message means - 30 minutes into baking, I got beeping and an F1 error message. Canceling did not turn the oven off and the only thing I could do is turn it off at the...
"F1" code clearly indicates that main control board has failed. The possible fix for this kind of problem is you have to replace the faulty circuit board. This is the only solution and you cant repair anything else in this unit when F1 flashes.
Thank you !!
May 30, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
F1 beeping
hello there:
Please read this carefully and follow the tips and this will help you find out what is exactly the problem ok
How to test many brands of Ranges that are flashing a F1 fault code: You have either a bad ERC (clock) or a bad touch pad.
  1. Disconnect power to stove
  2. Gain access to the back of the clock (electronic range control or ERC).
  3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
  4. Make sure everything is clear and will not short out when power is turned back on.
  5. Turn power back on to stove.
  6. Watch for the F1 and listen for the beep.
  7. If you get the F1 and beep, replace the ERC.
  8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
    NOTE: Some models incorporate the touch pad and the clock as one part. * We have seen a few of the newer Maytag ranges with a F1 fault code and the problem was the oven temp sensor, check carefully the wires to and from the oven temp sensor!!
Jan 12, 2010 | GE Profile JTP56 Electric Double Oven
F1 is displayed on Maytag Electric Oven I ran the self-clean cycle on my Maytag Model MER5530 oven yesterday; before it completed F3 was displayed and beeps sounded. I pressed CANCEL, the F3...
Hi
F1 error means that you have either a bad ERC (clock) or a bad touch pad. To check these please follow these simple instructions:
  8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad...
thank u
rate me!!!
Aug 14, 2009 | Maytag Ovens
F1 display and beeping
F1 Power to element relay energized during time of day display.
1. Wiring harness shorted.
2. Or change power relay board (PRB).
Note: for double ovens, change second oven board.
Jul 27, 2009 | Jenn-Air JJW8230D Electric Double Oven
Circuitry may have gotten tripped during clean cycle. Oven will open and electronics work but neither element will heat.
baked control module for heating elements. if you have a volt meter, check for power when oven on, if no juice its the control element, if you do get juice then its the elements
May 28, 2009 | Whirlpool GBS277PRS Stainless Steel...
Won't turn off
Sounds like maybe a wire burned off of an element terminal and shorted to ground. This would bypass the thermostat, so to speak, and continue to heat at 1/4 wattage. The only way to control this failure would be to turn off the power to the oven, but it won't reset until the burned wire is repaired.
May 27, 2008 | Maytag CWE4800A Electric Single Oven
Oven staying hot a long time after it was turned off
Thanks for your reply. I contacted an appliance repair person I have used before and he told me about turning off the breaker, which I did. He suggested using an oven thermostat to see if it was heating to the correct temperature as a first step. It may be the thermostat, I do not know what the controller is as presented by one of the responders. At any rate I learned that my breaker for the oven is by itself and is not attached to the stovetop which is good. I will have to weigh the cost of replacing a part on a 20 year old builder quality oven with microwave on top to a new one. Any ideas on a new problem free model are appreciated!!
Feb 12, 2008 | Ovens
GE JTP20 Electric Single Oven Logo
106 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a GE Oven Expert? Answer questions, earn points and help others
