I have a XMS 68cm TV Never had any problems at all Turned it on today and its not showing a picture It has wavy lines over the whole screen
  • 790 Answers
Only if your comfortable with the fact you my brake it by doing that.
I suggest you call a T.V. repair place but if you really want to D.I.Y. then I found some sites for you. http://www.instructables.com/id/HOW-TO-F...
http://www.ehow.com/how_2034877_fix-tv-t...
Posted on Mar 30, 2008
  • Kanth raj
    Kanth raj Mar 30, 2008
    Convergence amplifier ic's is what's wrong with it.
    If you know how to solder good, then maybe you could do it.
    These ic's have about 20 pins on each, and there are 2 of them.
    I'd stay away from it if I were you. An honest tv guy would do it for 200 bucks or so...it's not a big deal.
  • Kanth raj
    Sir u gotta rate it sir!!!
    Anyways thanks for using FIXYA!!
    Guru:
  • 1,894 Answers
Its due to your horizontal IC turning BAD
  • dewan nafees ahmed Mar 30, 2008
    yes smile maker was right..
    also i would like to add a point..
    dont try to do it yourself unless you are experienced with such stuffs..
    even after this you are trying it then you must be able to do that at your own risk
    thank you
Tv had thin black line when turned on today whole screen scrambled
need to access the ez menu to reset the parameters u will need a tech to fo this
Jul 19, 2013 | Vizio VF550M 55 in. LCD HDTV
Split screen, kind of inverted w/white wavy lines
It is a calibration problem, let me see if I can find some schematics for your tv.
Jul 19, 2008 | Panasonic CT-32SL14 32" TV
Mitsubishi rearTV has intermittent wavy lines running throughout
Do you have anything to test it in 1080i? Does it do it on all connections or just one? I had a similar problem with my TV that turned out to be a bad input board. Mine would only display 1080i through the Component connections. All others would show pink and green wavy lines. It cost me around 500 to fix it. Unplug the TV. Remove the back cover for the TV. Using a NON-metal object, or gloves, wiggle the input board (that has all the video connections on it) slowly back and forth and see if the problem comes and goes. You will have to have someone watching for you. If something is loose on that board, the problem should show itself. Narrowing down the problem will probably save you money on repair bills.
May 13, 2010 | Mitsubishi WS-65809 65" Rear Projection...
Picture is wavy and double vision
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 06, 2010 | Hitachi 46F500 46" Rear Projection...
Toshiba Rear Projection TV Picture Problems
The convergence circuits need to be replaced Sometimes it is just the matter of 4 capacitors and an IC but often than not ythe whole board has to be replaced.
Sep 02, 2009 | Toshiba 57HX81 57" Rear Projection...
We have a samsung rear projection tv with the same problem of fine wavy lines across the whole screen,more visible with light and dark colours, its like watching the tv with fine rain, sometimes the...
Your convergence ICs could be going Bad if so TV will shut down if the one that starts it goes out first STKs big black ICs also 2 resistors l;ow ohm 2.7 ohms near ICs.
Aug 14, 2009 | Samsung Televison & Video
Colored wavy lines on screen
This is a Logic board problem, not so easy to replace in Hitachi but well worth the repair if I had your zip code I could recommend a person or three. But the problem is a problem in the logic board and will beed replacement, Thanks for using Fixya.com
May 14, 2009 | Hitachi P42H401 42 in. Plasma HDTV
Apex gb5108
'I to am getting only wavy blue lines, no sound, doesn't even show channel indicators. TV was off for 4 days, came home turned it on and ten minutes later this screen appeared, it wont even show the menu screen, different channels or video inputs no sound either.
Jun 21, 2008 | Apex Digital GB5108 51" Rear Projection...
TV picture was warped, no it is black, but the power light remains on...
the problem you are having is in the power supply you can go ahead and take your set to a repairman o look at your set good luck.
May 02, 2007 | Philips Magnavox MS3652S 36" TV
Televison & Video Logo
55 people viewed this question
Top Televison & Video Experts
Electro Med Services...
