Question about Casio G-Shock GW500A-1V Wrist Watch
How to set analog hands on a g-shock watch - Casio G-Shock GW500A-1V Wrist Watch
  • 374 Answers
SOURCE: Casio GW-1200BA G-Shock
Try taping it to the inside of your window for a couple days and see if that makes it charge up enough to act right. You might also want to make sure that you don't have the "auto light" on. If the light turns on when you tilt the watch to a 45 degree angle then press the light button for 2 seconds to shut that off. If that doesn't work for you then you are probably going to have to have the battery changed.
Posted on Jul 17, 2007
SOURCE: Casio G-Shock G-7400 Watch
Thought this would happen when I sent you a request to help me simply change the analog time on my watch.
Your repsone to free suppor tis asking me to enter into a arrangement that requires payment.
I've solved the problem from another site free of charge.
I'm very disillusioned with the way you promote your site and will definitley recommending to others to stay clear of it.
COmes across as we can help you free of charge but bottomline is that this won't happen.
Onlty wanted to know how I change the analog time on my watch - could go to the Jewler to do this free of charge - thought the internet would help but your company has prolonged the support immensely.
Regards,
Paul Stirling
Posted on Apr 11, 2008
SOURCE: Getting analog part of Mossimo watch to start
FIXED!!!
As it turned out these Mossimo ANA/DIGI watches use two different batteries, one for the digital part (big) and other for the analog mechanism (small).
Have the watch serviced to change the second battery and VOILA!!!!
Enjoy!
Mivales.
Made in Costa Rica!!
Posted on Sep 24, 2008
SOURCE: setting the analog dials on the casio edifice EFA 120
http://ftp.casio.co.jp/pub/world_manual/wat/en/qw2747.pdf
Go here to get the instruction manual
Posted on Oct 20, 2008
SOURCE: How do I set the
Go to Handset Mode,
Press Adjust, push D button onWatch,
you should also see Digital time also,
Push D button RIGHT >BOTTOM Button,
Set Time Accordingly. OCB
Posted on Aug 19, 2010
I bought this watch in May of last year. For the last 3 months, every 2 to 3 weeks I have to reset the hand home position. Once that is done, I have to then reset the home city and time manually. What...
Hand home positioning normally has nothing to do with time setting.
Just set your local time and date and then you can do the hand home positioning procedure.This will not affect the time setting.If hands,after a while,do not show correctly,this means that the watch is under severe magnetic field, after severe shock or finally watch malfunction.
You must know that on this type of watches analog time follows digital time.
Feb 05, 2014 | Casio G-Shock World Time Analog Digital...
How do I set G-Shock analog time?
"H-SET" is the "0" hands position.To do this right,go to manual (link below) by using the module nbr found on the back cover (4 digit code in a frame).
Timepieces Watches Manuals CASIO
Nov 26, 2013 | Casio Watches
Cant get analog to sync with digital time. I live in SC and I try to set the time for 22:36 but then the analog set it to 12:36 am. :/
First set your local time, date and year and then run the "home positioning" (H-SET) procedure following manual instructions.If no any other problem exists, normally hands will "follow" digital time when watch is set back to time mode.
May 08, 2013 | Casio G-Shock GA-110-1B GA-110-1 Mens...
To adjust the analog time for ga-110hc-1a
Analog time follows digital time.Correctly set your local time and analog time will come up correctly as well.If not, try to run the hands alignment procedure (H-SET) following manual instructions.
Mar 02, 2013 | Casio G-Shock GW500A-1V Wrist Watch
The digital will not sync with the analog hands on my g shock
same problem here.. everytime i adjust the analog clock it moved but the digital clock dont so it means i can correct the analog but i cant correct the digital clock please help us..
Dec 30, 2012 | Watches
How do I set the digital time on a Casio G-Shock AWG-101
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all CASIO watch manuals. Rate me, please
Mar 15, 2010 | Casio Watches
RE: G-shock giez 1050 watch. we are having trouble setting the analog and digital time the same we have digital right but analog is 15 mins behind can you please help
To set the analogue to the digital time press the mode button (lower left until "HS" appears. Then use the two buttons on the right to advance or ****** the hands.
(these instructions are for my watch but I think that your will be the same. If not, go to the Casio web site (casio.com) select support, manuals, watches, agree terms and then watch manuals archive; fill in your watch details and download full instructions.
Jan 20, 2010 | Watches
Wristwatch
Just replaced the battery so the analog (the hour hands and minute hand) works.Your watch has two batteries one for the analog and the other one is for the digital display,that's why only the digital is working..
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Aug 10, 2008 | Casio G-Shock G510D-1AV Wrist Watch
Setting the hands on this watch
press your "mode" button 5 times until it says on lower display "H-SET". Then press the "adjust" button until it beeps.
Now hold the "forward" button and the minute hand is moving.
Enjoy :o))))
Nov 28, 2007 | Casio Green G-Shock Street Rider with a...
Casio G-Shock GW500A-1V Wrist Watch Logo
902 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
