Question about Canon PowerShot S50 Digital Camera
My cannon SD750 got wet with few drops of water..the lens does'nt open..i've tried hair dryer,vaccum,placing a peice of paper in between lens...but no use..
  • Canon Master
  • 13,433 Answers
Hey,
hair dryer won't do it, you need a heat gun, and take the camera apart, completely dry all parts of the camera.
Another solution is to take the camera apart as much as possible, put its parts into a air tight container and fill it with rice, leave it sitting for a day or two.
that will get rid of the water and moisture, put it back together and hope it works, if it doesn't it might be a lost cause.
Posted on May 14, 2010
Dropped alcatel phone in water, what do i try to get back on?
Keep it in direct sunlight for a few hours then turn it on it wont be harmed or it wont trouble
Jul 15, 2017 | Alcatel Cell Phones
OmomI have a panasonic digital camera model DMC TZ5 It came in contact of water when it was dropped into bucket of water. I immediately recovered and soaked the water from outside dried it through a...
If it was dropped in water ,it must've fried the power chip.This Can Not Be fixed with a hair dryer...if you take it down to a computer repair shop they coul replace the chip for a price of around $400 (depend whether other parts or circuits have been harmed) I've done this before on my t100 and I spent at least $500 for the chip and the LCD screen.
Jul 04, 2011 | Video Cameras
Water went in my cnon powershot sd750 camera and i was getting dull and blurred images and when i turned the lens it stopped workingit became dead.its just blank now.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} You would need to take out all moisture trapped in the camera: Dry the camera, battery, any accessory, etc. with cloth and wrap each piece, camera and accessories, in newspaper. Place a few handfuls of rice into a plastic bag and then place the wrapped camera in the bag with rice. The newspaper wrapping avoids direct contact of rice with your camera because the dust from the rice can get into the small areas of the camera. The newspaper and rice will absorb moisture. Leave it there (with the bag open) at least 24 hrs.
May 21, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
Waterlocked
  1. THE BATTERY HAS NO PROBLEM
  2. THE INTERNAL SWITCH HAS DRAINED OUT
  3. YOU SHOULD GO TO A MOBILE REPAIRING SHOP
  4. PROBABLY THEY CAN REPLACE THE INTERNAL PROBLEM
Jul 19, 2009 | Cell Phones
Hi! My grandson dropped my cannon sd750 while the
The lens cover is not really needed, but you can replace it yourself if you can find that other part. If you can't find it, just remove the lens cover entirely and just be careful with your lens. Here's an example:
http://camerarepair.blogspot.com/2007/11/repair-of-stuck-lens-covers.html
Jun 08, 2009 | Cameras
Water behind lens of Canon Powershot
If you can see condensation, then please do not switch on the camera.
Let it dry off. You could mildly use a blower(hair dryer) to dry , but not very powerful.
Once the condensation is dried, then if light spot remain and does not interfere in the quality of the photgraphs, it might go away in time. But if it is bothering you. Then you better take it to the nearest Canon service center, who will open and service your camera.
Best of luck.
Let me know if you need any help. Thanks for using FixYa!
Mar 08, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
I have an Telus LG 210 phone and got it wet, and when i turn it on all i get is the LG letters and the symbol beside it and the phone never starts up. It just keeps shutting off and turning back on at...
Normally the extent of the problem will depend on the amount of water seepage. I don't know the details of this particular phone but in general it is the moisture trapped under the keypad that can cause the problem. If you can open the keypad and run a hair dryer on low heat across for a few minutes that might help. It is also possilble the battery is discharged because of the drain of current due to water causing internal short circuits. Take out the battery, dry off the phone with hair dryer and put the battery in. Connect the charger and hope for the best. By the way I am not a phone technician.
Jul 27, 2008 | Lands Phones
Lens cover stays open
Try blowing lots of compressed air around the open lens shutter to clean the mechanism. Or use a hair dryer for a few seconds (don't want to heat up the camera). Also with the lens barrel extended and pointed downward, tap the lens barrel with a pencil while you extend and retract the lens by powering the camera on and off. A grain of sand in the mechanism is usually the culprit, and you want to try to dislodge it.
You can open it up, but only as a very last resort. The above procedures usually work if you try them enough. But for those particularly nasty stuck mechanisms, here's an example repair on a Canon Powershot A400 (do this at your own risk, and it will void your warranty):
Oct 30, 2007 | Sony Cyber-shot DSC-W55 Digital Camera
Lense Cover Stuck
You can open it up, but only as a very last resort. The above procedures usually work if you try them enough. But for those particularly nasty stuck mechanisms, here's an example repair on a Canon Powershot A400 (do this at your own risk, and be aware this will void your warranty):
Oct 01, 2007 | Canon PowerShot SD750 / IXUS 75 Digital...
Canon PowerShot S50 Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
