Question about Hayward 2001 Series Millivolt Gas Pool Heater 200000 BTU ()
Can/ how to adjust millivolt seeting for a lower power pump?
My 2001 model heater is about 15 years old. It worked when first installed. A couple of years ago we bought a new pool pump which has only one speed. The pump does not generate enough pressure to cause the heater to light. Is there a way I can adust the millivolt setting so that the heater will light? If yes, please describe the adjustment that I need to make.
thanks,
  • 8,404 Answers
Before you do anything, check with Hayward as to the minimum flow they require to maintain safe temperatures in the heater. You may have to throttle the heater back. They may have a lower value pressure switch you could use, too.
Posted on May 16, 2010
Testimonial: "Good idea to check with Hayward, thanks"
  • A Miller May 18, 2010
    welcome ... good luck with your heater ... thanks for the 3 thumbs up
THE PILOT LITE IS LIT BUT HEATER WILL NOT FIRE. I JUMPED THE THEMOSTATE BUT STILL WONT FIRE. THE HEATER IS ONLY TWO YEARS OLD? IT IS A MILLIVOLT HEATER 206
You have a "Standing Pilot" system with a thermocouple which generates millivolts to energize the solenoid on the gas valve causing it to open. This allows the gas to enter for heating.
The majority of the time this thermocouple goes bad and needs changing.bobicehouse_4.gif
Jul 13, 2011 | Honeywell Heating & Cooling
How do you convert a remote thermostat to a directly wired digital thermostat to a vulcan powerhouse 100 central heater unit
First, you need to know how many millivolts the Thermopile (aka Pilot Generator) on the the furnace's pilot assembly millvolt terminal. Then you find a wired digital thermostat, that meets the same millivoltage that the Thermopile Generates or has a lower requirement. You have to run millivolt wiring from the furnace's pilot assembly millivolt terminal block (the wiring should be connect to the TH & the TPH terminals, to where you want to place the digital wall thermostat. In most cases, it can not be more that 15' away from the furnace. In other words, no more than 15' of wiring can be involved.
Hope this helped you. Please let me know. Thanks.
Jun 20, 2011 | Heating & Cooling
Heater starts and runs for several minutes and then turns off
Since the unit runs for a couple minutes, I would first check for proper water flow. Find the pressure switch. It is usually round with two wire terminals and a copper/metal tube attached to it. With the wires attached, use a jumper wire to bypass the switch. If it runs longer check for flow problems.. (WARNING don't jump the switch for too long!!! Just enough time to see if the run cycle improves). Clean all the skimmers baskets, pump basket, backwash the filter (if a cartridge filter clean the filters). Try firing the heater again. If it still shuts down, replace the pressure switch. I never recommend adjusting it. Adjusting it too low can damage your heater and/or cause injury.
Jul 21, 2010 | Hayward 250K BTU NATURAL GAS POOL HEATER...
Timing chain is loose how do I replace or tighten
You need to pull out the timing cover. 4-6 hours of work. Here is the step to remove the Cover, then you need to remove the Sprockets.
  1. Remove the oil pan.
  2. Remove the power steering belt if so equipped.
  3. Remove the air conditioning belt, compressor and bracket if so equipped.
  4. Remove the fan clutch (fluid coupling), with the fan and water pump pulley.
  5. Matchmark and remove the crankshaft pulley(s). This bolt will be very tight. Use the counter-holding bar, properly installed, to hold the crankshaft while loosening the bolt. Use the pulley extractor or gear puller to remove the pulley from the shaft.
  6. Remove the water bypass pipe.
  7. Remove the fan belt adjusting bar. If necessary, remove the lower power steering bracket for access.
  8. Disconnect the heater water outlet pipe.
  9. Unbolt the timing chain cover assembly. Be careful to loosen only the correct bolts.
To install:
  1. Install new gaskets over the dowels on the timing chain cover. Slide the cover assembly over the dowels and pump spline. Insert the retaining bolts and tighten them. Tighten the 8mm bolts to 9 ft. lbs. (13 Nm) and the 10mm bolts to 29 ft. lbs. (39 Nm).
  2. Temporarily install the adjusting bar to the alternator. Install the adjusting bar to the chain cover and tighten the bolts to 9 ft. lbs. (13 Nm).
  3. Install the heater water outlet pipe.
  4. Install the water bypass pipe.
  5. Install the crankshaft pulley and bolt. Use the counter-holding tool to hold the pulley and tighten the bolt to 116 ft. lbs. (157 Nm). If equipped with air conditioning, install the second crankshaft pulley.
  6. Install the water pump pulley and fluid coupling with the fan.
  7. Adjust the tension on the drive belts.
  8. Install the air conditioning compressor bracket, compressor and belt if they were removed.
  9. Install the power steering belt and adjust it.
  10. Attach the oil pan.
  11. Install the radiator.
Jun 04, 2010 | 1987 Toyota Pickup
Changing a water pump on a 1981 ford f100 pick-up
Ford Pick-Ups/Bronco 1976-1986 Repair Guide Water Pump - REMOVAL & INSTALLATION
6-300 Engines
  1. Drain the cooling system.
CAUTION When draining the coolant, keep in mind that cats and dogs are attracted by the ethylene glycol antifreeze, and are quite likely to drink any that is left in an uncovered container or in puddles on the ground. This will prove fatal in sufficient quantity. Always drain the coolant into a sealable container. Coolant should be reused unless it is contaminated or several years old.
  1. Disconnect the lower radiator hose from the water pump.
  2. Remove the drive belt, fan, fan spacer, fan shroud, if so equipped, and water pump pulley.
  3. Remove the alternator pivot arm from the pump.
  4. Disconnect the heater hose at the water pump.
  5. Remove the water pump.
  6. Before installing the old water pump, clean the gasket mounting surfaces on the pump and on the cylinder block. If a new water pump is being installed, remove the heater hose fitting from the old pump and install it on the new one. Coat the new gaskets with sealer on both sides and install the water pump in the reverse order of removal. Torque the mounting bolts to 14-18 ft. lbs.
V6-3.8L Engines
See Figures 1 and 2
Fig. 1: V6 water pump installation
Fig. 2: V6 water pump bolt torque sequence
  1. Remove the air cleaner.
  2. Remove the bolts securing the fan shroud to the radiator, if so equipped, and position the shroud over the fan.
  3. Disconnect the lower radiator hose, heater hose and by-pass hose at the water pump. Remove the drive belts, fan, fan spacer and pulley. Remove the fan shroud, if so equipped.
  4. Loosen the alternator pivot bolt and the bolt attaching the alternator adjusting arm to the water pump. Remove the power steering pump bracket from the water pump and position it out of the way.
  5. If necessary, remove the air conditioner compressor and bracket. The refrigerant lines should remain connected.
  6. Remove the bolts securing the water pump to the timing chain cover and remove the water pump.
  7. Thoroughly clean the mounting surfaces of all gasket material.
  8. Install the water pump in the reverse order of removal, using a new gasket. Torque the bolts to 15-22 ft. lbs. in the sequence shown.
8-360, 390
  1. Remove the bolts securing the fan shroud to the radiator, if so equipped, and position the shroud over the fan.
  2. Disconnect the lower radiator hose, heater hose and by-pass hose at the water pump. Remove the drive belts, fan, fan spacer and pulley. Remove the fan shroud, if so equipped.
  3. Loosen the alternator pivot bolt and the bolt attaching the alternator adjusting arm to the water pump. Remove the power steering pump bracket from the water pump and position it out of the way.
  4. If necessary, remove the air conditioner compressor and bracket. The refrigerant lines should remain connected.
  5. Remove the bolts securing the water pump to the timing chain cover and remove the water pump.
  6. Install the water pump in the reverse order of removal, using a new gasket. Torque the bolts to 20-25 ft. lbs.
8-351M, 400, 460
  1. Disconnect the battery ground.
  2. Drain the cooling system.
  2. Remove the fan assembly.
  3. Remove the fan shroud.
  4. Remove the accessory drive belts and water pump pulley.
  5. Remove the alternator and brackets.
  6. Remove the compressor and bracket and lay it aside. DO NOT disconnect the refrigerant lines!
  7. Remove the power steering pump and brackets. Lay it aside. DO NOT disconnect the fluid lines!
  8. Disconnect the heater hose and lower radiator hose from the pump.
  9. Remove the bolts securing the water pump to the engine and lift off the water pump.
  10. Clean all gasket mounting surfaces thoroughly.
To install:
  1. Install the water pump in the reverse order of removal, using a new gasket coated with sealer. Torque the bolts to 12-18 ft. lbs.
  2. Install all remaining parts in reverse order. Fill the cooling system, start the engine and check for leaks.
continue...
Mar 25, 2010 | 1981 Ford F 100
Heater will not stay lit!!!
Lets start with safety. Check your vent pipe for obstructions, mainly outside at the vent cap. The safety of this unit will not allow it to operate if there is anything blocking the vent. If all is OK, then next we will light and observe the pilot with it on the pilot setting on gas valve. The pilot flame should consume the tip of the generator point by 1/2 to 5/8". If it does not, then screw off the pilot adjust screw cover on the gas valve. This is clearly marked on the top of the valve. Inside you will have a much smaller screw. Turn it counter clockwise to raise the pilot level, clockwise to decrease. Never consume more than 5/8" of the generator tip. Hopefully your problem will be resolved here at this step. If however it is OK, then take a millivolt meter and read the generator millivolts, at the gas valve with the thermostat contacts closed. It should read 140 millivolts. You need this much power to properly operate the heater. If it is lower than 140, then replace the pilot generator....Rob Just a note...Do not remove or take apart any part of the Gas valve, other than the pilot adjust screw cover...Good Luck.
Dec 29, 2009 | Williams 3003622 Ceramic Wall Mounted...
Need flow rate and pressure adjustment proceedure for an old raypack 266 not electronic.thanks murray
The maximum flow rate for that heater to be installed in without a bypass is 125 GPM. The owner's manual can guide you thru gas pressure adjustments or adjusting the set point of the water pressure switch. Please note that unless you are installing the unit below or significantly above the water line you should not have to adjust the pressure switch. Whenever you do adjust it, be certain to turn the pump on and off several times to be certain the heater reacts to the pump condition...failure to shut down when the pump does can be a serious and dangerous condition.
Dec 15, 2009 | Raypak Millivolt Gas Pool Heater 266,000...
Model-88h-300-top element works no power to lower
Check again. Is there power to it but it's not working? If so, the bottom element is the one that always fails first because the sacrificial anode gets used up and deposits collect on the bottom creating a blanket of "insulation", making it not heat water and causing it to overheat (elements MUST be submerged, or they will burn up.) Chances are your element is bad. Replace, or if the water heater is more than 15 years old, get a whole new water heater. Good luck.
Nov 30, 2009 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Coleman Gravity Floor Furnace need millivolt gas valve & pilot ki
Go to www.grainger.com and look for a "power pile generator" this is a millivolt thermocouple that may be just what you need to make your heater work again
Nov 12, 2009 | Heating & Cooling
I have a Raypac C155A LP spa heater. won't light
I would agree with you. The pilot generator has probably degraded over the years and is only proving enough millivolts to power the pilot but not enough to run the gas valve for your main burners.
Replacing the pilot generator, preferably the entire pilot assembly, will fix the problem.
Sep 05, 2009 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Hayward 2001 Series Millivolt Gas Pool Heater 200000 BTU () Logo
96 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
