Question about Gateway FPD2275W LCD Monitor
Vetical Line in middle
We get a red, pink or green lines in the middle. It disappears by tapping the center of Monitor to reappear again.
    Scholar:
  • 160 Answers
It may be loose contact inside the monitor
Or
May be the LOT (Line output Transformer) and V-Transformer
If the monitor is under warranty, contact the vendor for getting the replacement
if the monitor is not under warranty get contact the good mechanic for repairing the monitor
Let me know if your problem is solved and rate me as FIXYA!
Posted on Mar 30, 2008
Lcd monitor pink/green tint
Check the cable going into the back of your monitor and the cable from your monitor into your computer, one of them is most likely loose.
Dec 24, 2013 | HP Computers & Internet
A vertical line in the middle of my Acer P221w monitor
dead pixels?? although im told dead pixels are red.
Feb 16, 2013 | Acer Computers & Internet
The P42W46X is 6yrs old and has developed 1" wide
It means that the inverter cable needs to be re-seated or replaced.
Thank you for visiting FixYa! We answer your concerns promptly for FREE. Please spare a few seconds to click on YES button and leave a short comment to let other people know how I help you. Have a good one!
Aug 21, 2011 | Zenith P42W46X 42 in. Plasma EDTV
Intermittent problem a vertical red band (6-inch wide) appears on the monitor can last from minutes to hours before disappearing; then will reappear hours, days, or even weeks later.
Welcome to FixYa,
One of the top reasons for causing these "lines" running across the screen are :
  1. Corrupted video driver
  2. Changes in hardware configuration (display)
  3. Monitor issue (hardware)
In order to determine if it's hardware/software issue, all you need to do is to boot to BIOS and check if the problem replicates. Depending on system, you can go to the BIOS screen by tapping "F2" or "DEL" key repeatedly as soon as you turn on the computer until you see a different screen.
If the problem is present while in BIOS, then definitely the monitor needs to be repaired by an authorized repair center. Otherwise, video driver update or Operating system re-install can resolve this problem.
I certainly hope this helps,
Thank you for using FixYa.
Mar 04, 2011 | HP Vs17 17" LCD Flat Panel Monitor
A line has appeared across the bottom of the screen and also along the middle. the bottom line is white/red.blue and the middle line is mainly green
If your TV is still under guarantee then change it asap, if not you have a problem, the panel has failed, in very rare cases the lines will disappear when the set is at its maximum operating temperature, that said it will never be 100% again, sorry
Apr 19, 2010 | Grundig GU26DVD 26 in. LCD TV/DVD Combo
Pink and green patches on screen
The thin red, green, or yellow/brown line you see running through your LCD is a line of dead pixels. To fix this problem, you will have to get your monitor serviced or, if the monitor is new, replaced.
Sep 03, 2009 | Panasonic PT-52LCX65 44" HDTV
A pink line the whole height of the monitor has
Try setting you screen size to a larger or lower size. and the pixel color. try 32bit instead of 16bit.
Jul 18, 2009 | Acer 22" X223w LCD Monitor
Green line down the middle of the screen
Often times this issue is caused by either a loose or damaged VGA cable. You can verify the issue often times by firmly wiggling the cable and watching to see if the line disappears. If that does not resolve the issue you will need to replace the monitor
Apr 23, 2009 | Computers & Internet
I have a small green vetical line in my sony bravia xbr 52"
Unplug the TV , the hard reboot will cause the line to disappear in a few minutes, must be some algorithm that kicks in
Feb 21, 2009 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
Gateway FPD2275W LCD Monitor Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
