Question about Linksys Wireless-G WRT54G Router
Homegroup name change unable to rename original network name defualted to old one..
    Guru:
  • 257 Answers
IF THERE IS ANY PROBLEM ON NETWORKING AND YOU HAVE TRACE ALL POSSIBLE AREAS THE BEST SOLUTION IS FOR YOU TO RE-START THAT TROUBLESHOOTING METHOD SO YOU CAN ACHIEVE WHAT YOU WANT FAST TRY TO UNINSTALL THE ROUTER INTERFACE AND RELOAD IT AND START YOUR SETTINGS AFRESH THEN ALL WILL BE DONE LIKE THE FORMAL ONE YOU DO. OK
Posted on May 14, 2010
Cant get a desktop and laptop to "see" each other in the network so I can use a printer for both.
Make sure both are members of the same homegroup, check the homegroup name and code is the same on both machines.
Dec 15, 2013 | Microsoft Windows 7 Ultimate for PC
HP1020 problem with a livebox and WIN7 configuration
I found it somewhat difficult to completely Unshare files and folders on my HomeGroup Network and still allow Printer sharing in Windows 7 (Home Premium).
Initial UnSharing still allowed files like those below to be viewed on other home network computers:
C:/Users/
{user x} (folder)
AppData (folder)
Default (folder
Public (folder)
desktop.ini (file)
Other computers on the home network could step through many levels of hiarchy in the AppData folder and appeared to have "Delete" access!!
To completely decouple the computers, I had to go through the following several different Sharing/Unsharing assignment locations, till I could completely break the linkage.
I would appreciate any clarifications or simplifications.
File UnShare Confusion on HomeGroup Network
There are several different Network Sharing/Protection assignment locations in Windows 7.
To prevent all sharing between computers on the Homegroup Network, but allow Printer Sharing:
1) Start->Control Panel ->Network and Sharing Center->Choose Homegroup and sharing options.
Uncheck sharing boxes that you don't want to share. Save changes.
2) Start->Control Panel ->Network and Sharing Center->Choose Homegroup and sharing options->Change advanced sharing settings.
Click "Turn off Public folder sharing (people logged on to this computer can still access these folders)".
3) Start->Control Panel ->Network and Sharing Center->Choose Homegroup and sharing options->Change advanced sharing settings.
Choose Media streaming options.
Click "Block All" button. Turn off. Click OK.
Anomaly Note: You have to close Control Panel and repeat all step 3 again for the change to take effect.
4) Open Windows Explorer.
a) Select "C:/", select "Users" folder with single click, then click "Share with" in toolbar.
b) Select Advanced sharing.
Under Sharing tab, select Advanced Sharing. Uncheck box labeled "Share this folder". Apply and close.
5) Open Windows Explorer.
Select "C:/Users/", select all folders and files under "Users", then click "Share with" in toolbar, then click "Nobody".
6) Verify success by going to other home network computer(s) and trying to access your files and folders. You should only be able to see there is a computer and not be able to see any folders of files.
smooth printer service
Dec 16, 2012 | HP LaserJet 1020 Printer
Can I use networking between the two computer, the one computer has the operating system which is windows XP while the other computer has the operating system which is the windows 7?
Yes you can network XP and 7 together. The trick to this is during network setup you have to change the workgroup name on your XP computer to match Windows 7. The default workgroup name on 7 is homegroup. Change the name to homegroup in XP. Next during network setup on your 7 computer when you reach the workgroup options the setup will generate a password to access your homegroup. Write this password down and don't lose it. It's kind of hard to retrieve if you misplace it (speaking from experience :) ) You should now be able to share your router and files. Hope this was helpful.
Mar 30, 2011 | Acer Computers & Internet
I'm unable to rename any file in win XP,a message appears displaying "If you change a file name extension,the file may become unusable" Plz help to fix this
Go to control panel then go to folder option then click on view tab. On the list you'll find a option named "Hide extensions for known file type". Enable this option and click OK. Now you can rename your files easily.
Mar 13, 2011 | Computers & Internet
How to conect a printer
Install a printer on a home network
There are two basic ways to make a printer available to the PCs on your home network:
  • Attach it directly to one computer and share it with all the others on a network.
  • Connect the printer as a stand-alone device on the network itself.
This article explains how to do both in Windows. However, you should always first consult the information that came with your model for specific installation and setup instructions.
Setting up a shared printer
Traditionally, the most common way to make a printer available to a home network has been to connect it to one of the PCs and then tell Windows to share it. This is called a shared printer.
The advantage of sharing a printer is that it works with any USB printer. The downside? The host PC always has to be powered up, otherwise the rest of the network won't be able to access the shared printer.
In previous versions of Windows, setting up a shared printer could sometimes be tricky. But a new home networking feature in Windows 7 called HomeGroup has greatly simplified the process.
When a network is set up as a homegroup, printers and certain files are automatically shared. (To learn more about what homegroups do and how to use them, go to the Windows website and search for "HomeGroup: Recommended links.")
If you've already set up a homegroup and want to access a shared printer from another homegroup PC, just follow these steps:
To manually connect to a homegroup printer
  1. On the computer the printer is physically connected to, click the Start button ?id=4f6cbd09-148c-4dd8-b1f2-48f232a2fd33, click Control Panel, type homegroup in the search box, and then click HomeGroup.
  2. Make sure the Printers check box is selected. (If not, select it, and then click Save changes.)
  3. Go to the computer you want to print from.
  4. Click to open HomeGroup.
  5. Click Install printer.
  6. If you don't already have a driver installed for the printer, click Install driver in the dialog box that appears.
    Note
    • After the printer is installed, you can access it through the Print dialog box in any program, just like a printer that's directly connected to your computer. The computer that the printer is connected to must be turned on to use the printer.
Setting up a network printer
Network printers-devices designed to connect directly to a computer network as a stand-alone device-were once found mostly in large offices. No more.
Printer makers are increasingly offering inexpensive inkjet and laser printers that are designed to serve as network printers on home networks. Network printers have one big advantage over shared printers: they're always available.
There are two common types of network printers: wired and wireless.
  • Wired printers have an Ethernet port, which you connect to your router or hub via an Ethernet cable.
  • Wireless printers typically connect to your home network using Wi-Fi or Bluetooth technology.
Some printers offer both options. The instructions that came with your model should tell you exactly how to install it.
  1. ?id=microsoft.windows.resources.shellexecutetopiciconClick to open Devices and Printers.
  2. Click Add a printer.
  3. In the Add Printer wizard, click Add a network, wireless or Bluetooth printer.
  4. In the list of available printers, select the one you want to use, and then click Next.
  5. If prompted, install the printer driver on your computer by clicking Install driver. ?id=18abb370-ac1e-4b6b-b663-e028a75bf05b If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
  6. Complete the additional steps in the wizard, and then click Finish.
    Tips
    • Make sure that you have permission to use these printers before adding them to the computer.
    • You can confirm the printer is working by printing a test page. For details, see Print a test page
Feb 14, 2011 | Acer Aspire One PC Notebook
Need to rename my router because changed security code I pod or lap top wants look for the old code under the routers current name.
ok use the software you use to change the security code and where it says network name click on it, it should highlight then just type over it.
Feb 09, 2010 | Linksys Wireless-G Broadband Router
When i turn on my bluetooth this error msg appears " unable to perform bluetooth operation".
You will get this message when you try to send a system file. Rename first the file name,its extension and send it. After transferring it to the other phone, rename it back to the original file name and its extension.
Dec 15, 2009 | Nokia N73 Cellular Phone
Renaming networked HP laserjet 4350n printer rename
Restart the computer in safe mode and try and delete the printer. If that doesn't work download the the Kyocera print driver seleter from kyoceramita.com and use it to delete the driver.
Jan 06, 2009 | HP LaserJet 4350n Printer
HOW TO CHANGE PHONE LOCK CODE
The defualt code of sony ericsson phones will be 0000
Dec 13, 2008 | Sony Ericsson K530i Cellular Phone
Unable to access the network
There are two things you can try, one is renaming the SSID in the Wireless settings from the default (WLAN) to another name then release and re-new the IP addresses. If that does not appear to work try uninstalling the Wireless USB network adapter(s), reboot and reinstall and that should solve the problem.
Feb 16, 2006 | Belkin (F5D6230-3) Wireless Router
Linksys Wireless-G WRT54G Router Logo
95 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
