Question about HP LaserJet 2840 All-In-One Printer
Getting a 59.4 Error. Turned off and on several times, but no success. Fuser problem?
  • 10,515 Answers
This is a fuser motor error. Turn off the printer, then reseat the fuser assembly. If the same problem is experienced the problem may be with these parts in this order.
The troubleshooting procedures call for the replacement of the fuser motor first, but if it were on My bench I would try a fuser first (RG5-7602). That's the removable part in the back. If you want to replace the fuser motor (RH7-1628-000CN) the replacement procedures can be found on page 110 of this PDF document
http://www.partshere.com/Models/Q3948A/CLJ_2820_Removal_replacement.pdf
The DC controller (RG5-7609-030CN)is also a possibility ( but not probable). The procedures for replacement of this can also be found in the above document. Look over the replacement procedures and see if you feel comfortable. If you do great. If not a repair shop should charge about $60.00 per hour.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on May 14, 2010
Hp color laserjet 5500 error 59 ck printer error
list of error codes
http://www.printertechs.com/printer-troubleshooting/hp-error-codes/195-numeric-error-codes-50-59-hp-laserjet
HP COLOR LASER PRINTERS 4600, 5500 ERROR 59.3, 59.4 1. A fuser motor error. 2. Replace the fuser drive assembly. 3. Replace the D.C. controller board.
Jan 04, 2017 | HP Office Equipment & Supplies
59 co error
An error occurred with the developing
separation-drive assembly.
1. Check that the following connectors on
the driver PCA are seated correctly:
J403, J405, J213.
2. Check that connector J1020 on the DC
controller is seated correctly.
3. Check that connector J5008 on the
fuser motor is seated correctly.
4. Replace the developing separationdrive assembly.
5. Replace the memory-controller PCA.
6. Replace the fuser.
reseat fuser - something may be binding causing error
Oct 08, 2013 | HP COLOR LASERJET CP 3505 N PRINTER
Hp color laserjet cp3525
CP3525-59.FO ERROR. 1. TRANSFER BELT FLAG/ACTUATOR, WORKING? 2. SENSOR CHECK BEHIND CYAN TONER CARTRIDGE, WORKING? THESE 2 ARE IN THE BOOK AND EASY TOO CHECK. 3. MY ISSUES WAS THAT I REPLACED THE FUSER PRESSURE RELEASE MOTOR ASSY, BUT DIDN'T REALIZE GEARS WERE MISSING FROM SECOND HAND UNIT COMPANY ORDERED.:(. GOT MACHINE WORKING, BUT CYAN CAM IS OUT OF ALIGNMENT AND HAVE TO REINSTALL MAIN DRIVE AND CALIBRATE.. THIS ALL STARTING BY NOT USING HP SUPPLIES. BAD TONER CARTRIDGES HAVE TURN THIS JOB REAL UGLEY!!
Apr 17, 2013 | HP LaserJet Office Equipment & Supplies
Laserjet cp3525 error 59.f0
If it helps, I solved the error 59.F0 blowing on the sensors that are on the outer side (right door) under the edge of the transfer belt. You must remove the fuser and transfer. To locate the place to blow, craft and close the door stations toners, we see a long plastic slide guide in the machine with the door movement. Must blow into the small holes that are filled with dust with compressed dry air.
Good luck.
Jan 09, 2012 | HP CP3525N Color LaserJet Printer
I keep getting a "replace fuser kit" message on my
If you replaced with new fuser even getting same error, then check,
>Check the fuser connector (J5001). If
it is broken or damaged, replace it.
>. Check the connector (J1025) on the
DC controller PCB.
>. Replace the DC controller PCB.
Oct 07, 2011 | HP LaserJet 4700 Printer
We were getting fuser error 59. We have tried to get a new fuser assembly but all they send us is the film. Is that what we need for this error? How do you replace it.
Fuser Error means that the device has experienced an internal hardware error.
1.Turn the device off and disconnect the power cord
2.Remove the fuser and then wait at least 20 minutes
3.Rotate the locks on the fuser to the unlocked position,grab the fuser handle and pull the fuser assembly from the device.
4.Using both hands, slow and steadily remove any paper or print media from the device and carefully re-insert the fuser and secure the locks.
CAUTION: The Parts on the internal surface of the fuser are very hot, so to avoid burning yourself,please do not touch those parts.
Reconnect the power cable, turn on your device and wait for it to initialize. If the error persist, Change the fuser assembly or contact HP Customer care. This instructions can also be found n your user manual. i hopes this helps.
Thanks
Sep 13, 2011 | HP LaserJet 2840 All-In-One Printer
Display showing error 59.C0 on Hp Colour lasejet 3600 printer
59.C0 ERROR
An error occurred with the developing separation-drive assembly.
1.Check that the following connectors on the driver PCA are seated correctly: J403, J405, J213.
2.Check that connector J1020 on the DC controller is seated correctly.
3.Check that connector J5008 on the fuser motor is seated correctly.
4.Replace the developing separation-drive assembly.
5.Replace the memory-controller PCA.
6.Replace the fuser.
Jul 11, 2011 | HP LaserJet 3600n Printer
I keep getting a 50.2 fuser error. Turned off
wheb i give the print out, just show error 50.2 fuser error,
pls give me solution what may problems
May 02, 2010 | HP LaserJet 2840 All-In-One Printer
Panasonic Panafax DX-2000 Super G-3
try to do a lbp fuser reset and lbp error log clear and let me know if that helps
Dec 24, 2006 | Panasonic DX-2000 Plain Paper Laser Fax
Error 59
Error 59 normally refurrs to the fuser unit replace and test.
Thanks J
Nov 04, 2006 | HP LaserJet 3600dn Printer
HP LaserJet 2840 All-In-One Printer Logo
67 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
