Question about Carrier 38BRC036 Air Conditioner
Control panel problem
I have having a problem that seems to involve the starter system and control panel on the condenser unit. Could this be caused by dust and moisture on the control panel as it looks like it is not very protected from the elements?
  • Brian Niten May 14, 2010
    What kind of problem are you having?
  • dubbartlett May 14, 2010
    the condenser would not start until after power was removed from the control circut for a while (to remove memory?) The compressor runs now but sometimes when it shuts down it seems to monemtairly step down to a lower labored speed.
  • 674 Answers
The unit not starting until you removed power from the control board suggests you had some kind of fault. Where there any blinking lights on the control board before you turned it off. These would give you an error code and help in diagnosing the problem. I'm not sure about it sounding labored before it stops. You could check on that by connecting a clamp on ammeter to 1 of the compressor wires and checking the current draw when it stops normally and stops sounding labored.
Posted on May 15, 2010
What causes both cooling fans to not run?
Hi Naomi , there is a lot involved in the control of the cooling fans on your vehicle ! There are three fuse's , three relays an a fan control unit !
1. radiator fan main relay , located in underhood relay box A
2.condenser fan relay , located in underhood relay box A
3.radiator fan relay , located in underhood relay box C
4.Cooling fan fuse # 47 20amp. underhood fuse / relay box
5.condenser fan fuse # 50 20amp in underhood fuse / relay box.
Any one of these could cause them to not work, rather then just replacing parts an wasting money you should take it to the repair shop !
Apr 06, 2015 | 1997 Acura RL
Trane xr90 leaking water from behind inducer
You have a condensing furnace, clean out the condensate drain line.
Nov 30, 2013 | Aprilaire Heating & Cooling
Fuses panel described in English
Hope this helps your out. I know the diagram and locator is a bit blurry but hopefully it gets what you need.
Drivers kick panel:
Front wiper 20A - Front wiper system Cigar 15A- Cigarette lighter Audio 10A- Audio, remote control mirror Air Bag 10A -Air bag diagnostics Stop lights- 15A -Rear brake light, high mounted stop light ECU B+ 10A - Shift lock actuator, transaxle controle module, radio, engine control module Room 10A - Interior light, clock, ignition key reminder, rear cargo area light switch ABS 10A- Anti lock brake system control unit ECU IG1 10A - Transaxle control module, shift lock actuator, ABS control unit, DRL unit Meter 10A - Instrument panel, back-up switch, electronics time control module, inhibit switch Turn signal 10A- Hazard switch ,front and rear turn lights, turn indicator IGN1 20A - Ignition switch ABS 30A- ABS pump motor TNS 30A- Tail light, license plate light COOL/FAN 30A- Cooling fan Cond/Fan 20A- A/C condenser fan Starter 15A- Start signal , Fuel pump Blower 25A- Blower Motor SR/ACC 10A - Ignition switch Hazard 15A - Hazard and turn signal light D/Lock 25A- Door locks ABS 30A - Anti lock brake system control P/W RH 20A- Power window motor right hand P/W LH 20A- Power window motor left hand IGN2 25A- Ignition Switch
Engine compartment :
Head 25A- headlights IG 2 30A- Ignition switch IG coil 15A -Ignition coil, condenser,generator IC regulator, diagnostic connector. O2 down 10A- Rear O2 sensor O2 up 10A- Front O2 sensor Fuel pump 10A -Fuel pump unit Injector 10A -Fuel injector ,camshaft positioning sensor, purge solenoid valve, EVAP, IAC actuator, Mass Airflow sensor, EGR stepper motor. fuel pump relay coil, vehicle speed sensor. A/Con 10A - A/C compressor controls, cooling fan BTN 30A- Brake light , high mounted stop light. Tail light LH 10A- License plate light, tail light , rear combo light, instrument panel illumination Tail light RH 10A-License plate light, tail light , rear combo light, instrument panel illumination Head low 15A- Headlight Head Hi 15A-Headlight Horn 15A- Horn jlmacman.png jlmacman_0.png
Mar 07, 2011 | 1995 Kia Sephia
The refrigerator not as cold as before
Things to check - door gasket seals for leaks, dirty condensers that need to be cleaned and dust removed, proper clearance to the back and sides of your unit.
Is your evaporator fan in the freezer functioning normally ? is your freezer cooling normally ? You might want to check at the back of your freezer panel for overfrost on the evaporator that will impact cooling performance. You can shut down your unit and try manually defrosting and melting the ice and then run your unit for a couple of hours to see if cooling is back to normal........ if it is, then your defrost system is malfunctioning and you will need to have the control board and/or defrost system components checked.
Otherwise, if overfrost and door seals and dirty condensers are not an issue and you have also tried raising the cooling dial up and compressor run-time is excessive then you may have a sealed system issue but rare and not the common causes. Most common causes are overfrost on the evap / defrost timer problems and damper (flaps that do not open properly).
you will need to have those checked if all else fails.
Sep 23, 2009 | Imperial Refrigerators
Vacuum condenser light of sub zero 650 is on - how to clean it
We recommend vacuuming your condenser every 3 - 6 months. Cleaning the condenser is important for the overall operations of the unit including cooling functions. A dirty condenser may lead to warm temperatures in the refrigerator and freezer. It may also cause the unit to run excessively. It may contribute to condensation or frost inside of the compartments. If the condenser is not cleaned properly it may even cause premature failure of mechanical components in the unit. Condenser Cleaning - All Models Before cleaning the unit, shut the electricity off at the control panel. When you clean the condenser, wear gloves to avoid injury from the sharp condenser fins. Use a soft bristle brush and vacuum to remove dust and lint from the condenser. To avoid bending the condenser fins, be sure to vacuum in the direction of the fins, up and down. Clean the condenser every three to six months or sooner if you have pets. 600 Series Framed and Stainless Steel louvered grilles: First remove the grille screws located at the bottom of the grille. Tilt the top of the grille forward and release the springs from behind the grille, then lift off. Overlay Panel Grille: To remove, lift up then pull out at the bottom and down to release from its mounting bracket. Remove the two black screws in the lowest louver of the grille. Tilt the bottom of the grille out and away. It will release from the top of the grille. Model 601RG Stainless Steel Grille: Remove in a similar fashion as the overlay grille panel. 700 Series All Units: At the bottom of the unit, remove the four screws holding the kick plate/grille in place. It will then slide forward, giving you access to the condenser area. 400 Series 424/424FS At the bottom of the unit, remove the screws holding the kick plate. The condenser is located behind. 427/427R: Remove the four screws holding the kick plate/grille in place. It will then slide forward, giving you access to the condenser area. 430: First remove the screws located at the bottom of the grille. NOTE: These screws (Phillips head) are accessed with the door open. Tilt the top of the grille forward and release the springs from behind the grille, then lift off. 200 Series 245, 249, 315W Remove the kick plate at the bottom of the unit, giving you access to the condenser area.
May 30, 2009 | Sub-Zero 650 / O Bottom Freezer...
NOT HEATING, DOES NOT SEEM TO HAVE CONTROL VOLTAGE FROM UNIT INSDE HOUSE
You should have a unit with a heater built in on a dedicated circuit because of the amp draw involved. i would check the breaker panel.
Apr 10, 2009 | Heating & Cooling
Lg bottom freezer is always unpredictable!!?!? many times its on a defrost cycle that we cannot figure out WHY??!!! we are upset opening the freezer to again see all of our frozen foods not so frozen!...
The LG fridges are all controlled by the board. Depending on the year of your unit, the unit will go into defrost once every 12 hours on the older boards, and once every 24 hours on the new ones. The older boards, were 12 hours, these were also the ones that had the problem. On the back of your unit, open the panel that covers the board, if it is 6871JB1375A it is old and could be the cause for the problem. You will need the xxxx1375D this is the modified board that should solve the issues.
Sgt 48
May 25, 2008 | LG LRFD22850 Bottom Freezer Refrigerator...
Unit no longer heats
If ur AC is not coolling properly thn u must go for replacing a fuse, resetting a circuit breaker or checking to see if the thermostat is set properly. If an electrical problem isn't the cause, the refrigerant may be low if the system still runs but does not cool properly. This can be corrected by having an EPA certified technician add necessary refrigerant. Most likely, if the problem involves any major part, such as the compressor, you would hear strange noises similar to those of any mechanical equipment not running correctly, or the unit might not run at all.
Go for replacing both theoutdoor condensing unit (which includes the compressor) and the indoor coil on my central air conditioning system at the same time
Matching a new condensing unit with a new coil is the only reliable way to be certain you are going to get the rated efficiency of the new equipment. Matching a new, high SEER (seasonal energy efficiency ratio) condensing unit with an old indoor coil probably would not result in optimum efficiency.
Goodluck,
Dont forget to rate me as fixya..
Jan 30, 2008 | Heating & Cooling
Carrier 38BRC036 Air Conditioner Logo
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
