I can't get my Monitor to turn on. It is attached to a laptop and earlier my laptop screen wouldn't come on, now my acer monitor won't come on. What do I try?
  • omarty9 May 15, 2010
    My Acerx163w monitor will not come on. I checked my resolution settings, and they seem to be right. What do I do now?
  • 4,924 Answers
Usually it has a hot key to enable the external monitor ..and the short cut for it is for most of them Fn+F4 or F5 for some ...but you can also ..right click on the monitor ..properties..and settings ...there choose advance ..and set the secondary monitor..(enable it monitor No2) and it will work ..
but first try with the short cut I said ..keep the FN key down ..and press F4 or F5
Posted on May 15, 2010
  • 4,281 Answers
If your monitor get power supply then you need to check resolution settings in computer.
For that when you power up the computer press F8 key then enter in "Enable vga mode" then go to start->control panel->display ->settings.
Change screen resolution to 1024*768 then apply and ok.
Then check.
But if your monitor doe'snot show power led flash then you need to repair your monitor because something blown inside monitor
Let me know if you need further assistance.
Thanks for using FixYa.
Posted on May 14, 2010
    I tried your solution to check the resolution settings, and my monitor still won't come on. You said that my monitor may need repair. How do I do that?
    I tried your first solution. My computer settings are fine. What now?
Black screen
first check your display in monitor with the help of vga cable attach your laptop in the monitor,if display comes in the monitor it means your screen faulty .or if display cant seen on monitor it means there is an fault on MOTHERBOARDS BGA CHIP.
Jan 29, 2014 | Lifetime Acer Aspire 4736Z Replacement...
Monitor won't come on when power on
Try unplugging it and then plugging in again, and make sure the monitor is turned on.
Apr 20, 2013 | Acer Aspire 5600 Series 5630-6951 Laptop
E248WFP (external) Monitor Won't Power Off when Laptop Screen does!
this is not a pc problem... this is because the connection loss between pc and monitor... not all pc's have sleep mode in externa vga connection.... it just cuts power off... u can configure monitor of possible to do that..
Jul 09, 2012 | Dell UltraSharp E248WFP 24" LCD Monitor
Want to put a extra screen
You can attach a external monitor to it yes. Once you have purchased a monitor and attached it than you press Fn F4 should be twice to use both monitors. Please make sure you have a video component on your laptop so you can arttach the second monitor.
Hope this helps ^^. Please dont forget to rate, Thanks
Mar 02, 2010 | Acer Aspire One PC Notebook
Monitor receiving signal, but no image
Hello!
I see many monitor with that trouble.
When you turn on comp., you can have a picture on monitor about 10-30 min. and that go in black screen, or If you change resolution again go in black screen.
You must repair monitor or bay another.
Nov 02, 2009 | Acer AL2416W Monitor
Multiple screen laptop set up
Attach the screen maunally go to control panel and attached as a secondary monitor it will surelly work
Oct 31, 2009 | Acer Extensa 4620 Notebook
Acer flat screen monitor, attached to laptop. Turns on and says 'no signal' occassionally works though for a short period. Works when connected to other laptops.
If this monitor works when connected to other laptops, the problem is likely to be your laptop, not the monitor. I would suspect that there are bad comnections at the video connector of the laptop.
Dan
Jul 23, 2009 | Computers & Internet
Tower is beeping and monitor on/off switch is blinking
I have not solved the problem of the blinking on off switch, but I have solved the problem of the monitor attached to my laptop waiting so long to start up. I never shut down the computer and I never hibernate it either. I leave it on 24 hours a day.
May 19, 2009 | Acer Computers & Internet
Attaching external monitor to acer aspire 3682wxmi
I wouldnt put something like that in, sounds like your having a driver issue,
Jan 04, 2009 | Acer Aspire 3680 Laptop
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
