Question about Kingston Technologies 512MB DataTraveler I (DTI512KR) Hard Drive
Unlocking write protected pen drive
1 GB Mosearbear pen drive have been unknowingly locked write protected.need help urgently.plz guide me how to unlock it.
I can't format my pen drive because it is write protected. But it has not any
kind of button for unlockin
  • Anonymous Mar 16, 2014
    my pen drive has write protection please give me a solution
  • 94 Answers
Do u have write protection swicth on this drive. if yes than check and correct.
if not than go for replacement. moser bear gives 3/5 yrs warranty ad hence u can demand
Posted on Apr 22, 2008
    President:
  • 1,257 Answers
First try to see is there any lock in your usb pen drive and see if its not locking the pen drive, because some pen drives comes with that option to protect usb .it looks like slide switch .for one end it will lock the media and when you switch to other side you have the full access
but if that's not the reason it might be the problem with registry
Use the Registry Hack to Disable Writing to USB Drives
Here is the link .just download the zip folder and after opening the folder you will find a file just double click on it..
http://www.howtogeek.com/wp-content/uploads/DisableUSBWrite.zip
Low feed backs hurt my ratings and I tried my level best to resolve the issue. so show your appreciation by rating it.
Thanks for using fixya support..You have a wonderful day
Posted on Jun 11, 2008
SOURCE:
My pen drive is write protected. I want to format it . plz suggest me
try to check disk your pen drive.
Steps:
1.)Right click your usb and go to PROPERTIES
2.)Go to TOOLS tab
3.)on Error checking click CHECK NOW
4.)Click the two CHECKBOX and wait for it top finish.
5.)you can now try to format your pen drive.
Rate me if i helped.
Sep 15, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
My pen drive has become write protected and now I want to remove write protection from my pen drive,please help me.
Hi Sir.
Please look carefully at your usb pen-drive to see if there is a small switch on there somewhere that is used to lock and unlock the drive. perhaps you may have accidentally put it in the lock position.
If there is a laser pointer on the drive then using the laser pointer may have caused you to accidentally switch to the write protected mode. most drives have a lock/unlock switch on the pen-drive itself...unless it has a program installed on the drive that has encrypted and locked the drives read/write ability. Please let me know if you have success.
Thank you!
Dec 03, 2010 | Generic Memory USB 2.0 128MB Black Pen...
4 gb pen drive give write protected error
Save the contents in the pen drive (this process will delete all the files in ur pen drive) and then download this http://www.apacer.com/en/support/downloads/Repair_v2.9.1.8A.zip,unzip it n run.....click "Format". Make sure u have connected only the pen drive u wanna recover to computer,this tool is very blind n it doesnt allow u to choose which removable drive to format..it formats the first removable disk (seems so). Gud luckmoz-screenshot.png
Feb 23, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Pen drive shows device is write protected while formatting. So please give me solution so that I can format the Pen drive & use it again. Kingston Pen drive with 4 GB capacity. Using Windows XP...
if you see your pen drive properly you will find a lock that you need to switch to other side for unlock device
this lock make device write protected
hope it helped you
Sep 30, 2009 | Electronics - Others
My pen drive now showing write protected what i do ?
LLFTOOL is a utility for low-level disk drive formatting,
also supports formatting of FLASH cards using a card-reader.
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format pen drive
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Aug 29, 2009 | iLO (2 GB) MP3 Player
Removing write protection of USB pen drive
if u format ur pen drive. then use this step
Check out the registry under:
1)click on start button
2)clik on run dialog box
3)type regedit
4) HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies.
The value 'WriteProtect' should be absent or set to '0' and when you try to format it you have to format it as FAT16
Good Luck!!
Palwinder
Oct 31, 2008 | iLO (2 GB) MP3 Player
Dont permission
Some pen drives have a lock button. Also check if it brings some sofware to unlock it.
Jul 01, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Write protected pendrive
there should be a small thumb guide which will release the lock aspect. looks at the back of package or small instrucion sheet, or go to website for that manufacturer model and use guidance there.
Jun 21, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
hi- some pen drive has a little switch on the ends of it, make sure you have it toggle or positioned on the unlock, look on both ends if it has a black switch to unlock it, if there is none try to reformat the pen drive, reply for any concerns. Yhanks!!
May 16, 2008 | Electronics - Others
Computers & Internet Logo
269 people viewed this question
Top Kingston Computers & Internet Experts
Alun Cox
Mike
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
