Question about Kenmore Drop-In Bobbin 16231 Mechanical Sewing Machine
When I sew the thread gets caught up underneath fabric in the feed dogs. I have taken the bobbin out, face plate off, clean dust from area and replaced the needle. It still does it. Is this common?
  • 92 Answers
One of the tentionsis to loose or the thred must be behinde the foot that rest on the feed dog. pull the thred to the back and then sew. Willem SA
Posted on May 14, 2010
Singer touch tronic 2000 feed dog will not advance fabric
Confirm the feed dogs are raised. Make sure the feed dog teeth, area under the needle plate and the bobbin area are clean of any debris, thread, or buildup. Some machines also have a presser foot pressure adjustment that increases the pressure the presser foot applies to the feed dogs. The feed dogs could be worn (never run the sewing machine without fabric between the presser foot & feed dogs).
https://www.manualslib.com/manual/508740/Singer-Athena-2000.html
Or, the machine has not had a thorough cleaning and oiling recently and the feed dogs are sticking from old oil.
Wheel on right side that controls the needle up and down is very tight...
Jul 30, 2017 | Singer Sewing Machines
My thread is getting caught under the plate by the bobbin casing when I'm trying to make a buttonhole. Also my fabric is a little thick and my feed dogs will not pull the fabric through, so then I have a...
If you have an a self wind bobbin make sure the bobbin winder is all the way down and no thread caught under it, your machine should be able to cope with thick fabric, slacken the pressure on the presser foot
Oct 03, 2013 | Singer Touch Sew 7462 Mechanical Sewing...
The bobbin is not preforming properly. It jumps around when I sew and then on the back of the fabric there is a ton of excess thread.
Change needle
Clean under needle plate where feed dogs are for lint
Clean bobbin area for lint or loose threads
Rethread machine top thread make sure to get every thread guide
& bobbin
Check tension 3 or 4 is usually good
if the bobbin is top loading they will flop around some when the start getting close to empty
if it's a bottom loading bobbin & case then it's not inserted correctly
Nov 24, 2010 | Singer 7442 Mechanical Sewing Machine
Loose thread on bottom of fabric and locks up needle
Change needle
& bobbin
Nov 23, 2010 | Toyota STF17 Sewing Machine
I have had a singer prelude 8280 for a year now with no problems. now all the sudden the thread is catching in the bobbin casing. The thread on top looks normal, but when you turn over the fabric...
change the needle
clean under the needle plate where the feed dogs are for lint
make sure the thread has not come off the thread take up lever
rethread the machine
Nov 20, 2010 | Singer 8280 Mechanical Sewing Machine
When i start to sew on my Janome sewing machine model Sewist 525S it does a couple of stitches on any stitch type then bangs then sews then bangs then stops. I look to see the problem and the bobbin and...
There has to be a problem in your threading or your needle. You may have the needle inserted backwards, flat side has to face rear or the needle is bent. Totally unthread your machine and make sure that there are no tangles and that it feeding the right way. Watch how they show your for threading and winding the bobbin, plus threading the bobbin. Good luck, but I truly think it is in your threading.
Sep 25, 2010 | Brother LS-1217 Mechanical Sewing Machine
My sewing machine will not pick up the bobbin thread. It sounds normal and pulls the fabric through, but the threads do not intertwine. I had been having problems with the bottom thread clogging and...
when the needle pulls the fabric into the feed dog you dont have enough fabric behund the neelde when you srart, and the fabric gets caught in the feed and the bobbin case underneath clean it out anf change the needle they often get bent after they get tangled in the thread and fabric
Dec 10, 2009 | Bernina Sewing Machines
Top thread gets stuck around bottom bobbin and jams machine
have you tried oiling it after you clean out all the dust and thread ends, you can take the feed dog plate off and clean under there as well. hope it helps
Jul 22, 2017 | Euro-Pro Shark 80 - 7133
Thread balls up underneath my feed dog when straight sewing. Why?????
Could be needle/hook timing. With machine off do the following to check timing -
remove bobbin and bobbin case.
push needle all the way to the left.
Turn handwheel toward you watching the needle and bobbin housing hook. The point of the hook should line up right above the eye of the needle.
If not timing, clean bobbin area and thread cutter area, removing lint and thread.
Check bobbin tension, should get slight resistance when pulling thread.
Make sure using only Husqvarna Viking bobbins -- most are green but they have new colors now. All will have the Husqvarna logo on them (an H). Make sure the bobbin is unwinding counter clockwise when going through the bobbin case.
Remove fabric. Pull extra long bobbin thread (about 3 inches). Hold upper thread tail in left hand, turn handwheel toward you for 1 revolution. Is the bobbin thread caught by the top thread and pulled through the opening of the needle plate?
If you are still unable to sew without thread balling up, take to an authorized Husqvarna Viking dealer for service or have them send to Husqvarna Viking (SVP) Technical Service Dept for repair. A list of dealers close to you can be found at the Husqvarna Viking website - http://www.husqvarnaviking.com/us
Good luck.
Sep 24, 2009 | Husqvarna Designer I
Not picking up the Bobbin thread
Sounds like you have to take off the throat plate and clean out threads under it.  Sometime they ball up and prevent the needle from going down and catching the bobbin thread. You can't see themuntil you take off the plate.  Follow the directions.  It is easy.
Dec 28, 2008 | Baby Lock Ellure
Kenmore Drop-In Bobbin 16231 Mechanical Sewing Machine Logo
292 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
SewTechWayne
SewTechWayne
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
