Question about Kitchen Ranges
Want to register new range - Kitchen Ranges
  • robert samples May 11, 2010
    whats the brand and model number of thr range
I was looking for the website to register my range. I mailed in the information instead.
Posted on Mar 30, 2008
SOURCE:
New cordless phone showing out of range
Check that it is registered with the base station and check the range coverage. If you are not out of area of coverage and handset is properly registered to base station then your handset may be faulty.
Dec 12, 2014 | Lands Phones
Out of range or no pwr at base
It sounds like the handset has "lost" its registration with the
base ( or a replacement handset is being introduced ? )
Either way, the handset displaying "Out of range..." is now
orphaned and must be deregistered and then re-registered
to the new/current base.
1. To de-register the orphaned handset from the old base:
When the orphaned handset says "Connecting..." or "Out of..."
enter *331734# (menu)
and it will soon beep and display "Not registered"
2. To register the new handset to your base:
press the "Handset Locator" button on the base and hold
it until the "in use" light comes on ( ~ 4 seconds ),
then release the button and set the new handset into
the base phone cradle. After ~ 30 seconds it will beep
and display "Handset #" (next in sequence).
3: Note: the base handles a maximum of 12 handsets.
If your system was fully populated ( ie, a handset is
already # 12 ) you will have to clear all the handsets
from the base and re-register them all in sequence.
( it is the only way to 'rescue' the places occupied
by the lost handsets ).
To clear the base of all registrations:
1. Press and hold the the "Handset Locator" button
until the "in use" light lights and then starts to blink
( ~ 10 seconds ), release the button --
then press it again briefly while the "in use" light
is still blinking.
2. The base will beep and all handsets that were registered
will display "Not Registered"
3. Follow the instructions above for each handset
in turn to re-register them:
press "Handset Locator" ~ 4sec ( in-use light on ),
set handset into the base cradle, etc.
The manual is available from: www.manualslib.com
but does not fully describe these procedures.
Good luck !
Oct 14, 2011 | AT&T TL32100 Cordless Phone
I would like to register my new washer and dryer on line. Where do I do this???
The registration will be with the manufacturer of the new washer and dryer...use google to search for the maker of the washer and dryer and follow their links to register. The registration will ask you for the model and serial number as well as name, address, etc.
Jan 23, 2011 | Kitchen Ranges
I get headaches, sinus, liver pain etc when I use my new gas oven
Get a Carbon Monoxide detector and place it in the kitchen and see if it registers when the oven id running... make sure to get a digital readout one the registers all the time and not just a high alarm one...
heatman101
Sep 13, 2010 | Amana AGS1740BDW / AGS1740BDQ / AGS1740BDB...
When range burners set to low they go out when house furnace fan turns on?
This is a common problem when the furnace register is located in or near the kitchen. You will need to close the register(located in the ceiling) or adjust it so the air is not blowing toward the range burners. They also make deflectors that you can install on the register to direct the air away from the range.
Dec 18, 2009 | Kenmore Kitchen Ranges
Temp guage registering high on 1994 e320 I installed new radiator and new thermostst.still registering high.
check your temp switch to see if operating normally or possiable gauge problem (switch controls fan for radiator if out of range can cause fan to come on later and in turn temp gauge will read higher than normal)may be more than one temp switch to control diffrent speeds.
Oct 20, 2009 | Mercedes-Benz E320 Cars & Trucks
Handset No2 displays out of range message
Please check that you have correctly registered the second handset to the base. It may be necessary to de-register the second handset and then re-register it. "Out of range" just means the second handset is not within range of the base phone it was registered to.
Mar 08, 2009 | Uniden TRU8885-2 Cordless Phone
Uniden Tru8885-2
The older Tru8885 phones will not work with the new base unit. My recommendation would be to ebay those and then buy new ones or find replacements for your new base on ebay also.
Jun 19, 2006 | Uniden TRU8885-2 Cordless Phone
Kitchen Ranges Logo
37 people viewed this question
Top Kitchen Ranges Experts
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
